Results 1 to 24 of 24
Thread: Bang and Olufsen Icepower tech support?
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    Anyone know if B&O will give tech support on their Icepower products? I have a 700asc/x in my Ashdown Retroglide 800 that goes into protect mode because of Zobel network oscillation but only with some speakers. The website for the Icepower division doesn't have any contact info for tech support, and only contact for sales outside of Denmark. I'll probably give the Americas sales office a call tomorrow and ask, just wondering if anyone has any experience.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,427
    Received: 2,517/7
    57
    Seems if I recall properly, some amplifier OEMs who use the ICE units do not even get schematics and documentation. As far as I know they intend the boards to be replaced like a part.
    1 Not allowed! Not allowed!
    Lifetime Member
    4,473
    Received: 458/1
    Given: 3/0
    22
    Add to or mess with the values on the Zobel. Can't hurt, can it?
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    Quote Originally Posted by R.G. View Post
    If I can't get any support that is what I will do. Looks like this board may have been early development, there is quite a bit of hand rework around the class D driver ICs, and there are already two big caps that have been added in parallel to the originals in the Zobel network. Want to find out if they have figured out a better zobel recipe or if this is problematic early production maybe they will replace it with a newer model that is more stable at something less than full retail cost.
    Sep 2011
    Pace, FL
    3,630
    Received: 1,317/102
    Given: 183/36
    12
    Quote Originally Posted by glebert View Post
    I would check with AShdown first. The rework you are talking about could be their handiwork for the speakers they included with the amp.
    nosaj
    2 Not allowed! Not allowed!
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    Quote Originally Posted by nosaj View Post
    nosaj
    I guess it is possible that they would have reworked, but it didn't seem like there was ever a specific cabinet associated with this head (Retroglide 800). Maybe Ashdown can at least confirm if there were any issues with this head, but it seems like it was pretty short lived and low production.
    Sep 2011
    Pace, FL
    3,630
    Received: 1,317/102
    Given: 183/36
    12
    Well they had to test the head with something. Sometimes short lived and low production is just turning away from a bad design.
    nosaj
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,468
    Received: 337/2
    Given: 122/3
    16
    from the board's manual
    here
    seems like this is a bit of their secret sauce, but they imply a symmetric circuit, what values do you have?
    Is it the powered board AS1 right?
    Any trend on speakers what "don't" vs do work?
    These amps can be very touchy on outputs they aren't "power anything" IME.
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    Quote Originally Posted by tedmich View Post
    here
    Looks like the top side "stock" cap values are .68 and .1uF, resistors look like 3.3 ohm (?). The back side added caps (in parallel to the .68uF) are 1uF. Check my values, I have gotten too used to just reading off a schematic.
    I don't know what the AS1 powered board means, this board has the smps from the mains and the class D sections.
    Don't see much of a trend on what works and what doesn't. A little 6" 10 watt 8 ohm speaker is fine, my SWR Jr. 2x10 4 ohm is fine, 12" Peavey Scorpion Ultra is fine, but a Boss Chaos 15" speaker or some cheap PA speakers send it to protection (there was another bass cab I had that did it too, maybe a Fender Rumble 410). I am measuring 50Vpp at about 62kHz (which is about half of the class D switching freq) probing on the big red caps when it is protect mode, nothing there when it is not in protect.
    Someone on MEF had given me a contact at Ashdown to try, I emailed him and will see if he has any info on this.
ID:	54482Click image for larger version.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    The Zobel is "symmetrical" because itīs a bridged amp, so each half needs its own.
    Modding just one half but not the other will not work.
    In any case, try to make it work with the customerīs cabinet and leave it there.
    As Enzo says, "we are here to repair, not to reengineer".
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    In any vase, try to meka it work with the customerīs cabinet and leave it there.
    Ay, this customer is a real PITA (hint, it's me )
  12. #12
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Well, I do
    Those are all *speakers* .
    that is just car audio crap.
    Do you REALLY expect a serious amp to drive that?
    * Impedance will probably drop below 1 ohm at some frequencies to win car SPL competitions.
    * half pound copper voice coil inductance will be high enough to filter a Twin Reverb power supply.
    * dynamic energy accumulated in that high Q (to win car SPL competitions) voice coil + *heavy* cone must send back flyback pulses high enough to electrocute a mouse.
    Your amp entering Protection is its way of crying FOUL!!!!!
    those with 7 piezos in parallel?
    Just use a real speaker and all will be fine.
    And donīt waste time solving a problem which does not exist.
  13. #13
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,682/2
    Given: 1,210/1
    18
    'Tis a silly speaker indeed. 2 ohm if you parallel the voice coils. Resonant frequency an idiotic 26Hz. The unimpressive 86dB sensitivity is telling. The gap must be 3/4"+ to accommodate 2 voice coils wound of romex.
  14. #14
    Sep 2011
    Pace, FL
    3,630
    Received: 1,317/102
    Given: 183/36
    12
    So the final synopsis is that USE guitar speakers and not anything else an you'll be ok.
    nosaj
  15. #15
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,682/2
    Given: 1,210/1
    18
    ...... or a REASONABLE bass speaker.
  16. #16
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    Got a reply back from Ashdown, he said that the added caps were done after if left the factory, as neither they nor B&O have done any mods on this module, and that they have had no problems with it at all. He suspects that someone blew the module and did a home repair on it and then had to add the caps to get it stable. There are no schematics available to see if the FETs match up with design, there definitely has been rework around the class D driver chips. His thought is that the module will have to be replaced. I think I may give it a bit of a torture test with a resistive load, and then just use it as a practice amp with an expendable bass cab. I'll be curious to see what kind of power I can get out of it into a resistive load, it has always felt a bit weak-kneed to me.
    Thanks for inputs.
  17. #17
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Cool.
    Please measure it, the old way, which matches "our" PA/Stage use.
    I read Class D amp datasheets end to end and most say something like:
    "500W RMS 1% distortion" ... cool.
    "After 30 seconds 400W RMS"
    After 5 minutes it may self turn off for thermal reasons
    **Continuous** power available: 275W .
    WTF?
    As of the disposable speaker: no need to if you add a DC protection board with a relay or at least a TRIAC crowbar , Peavey style, between power module and speaker out terminals.
  18. #18
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    As an update, I ran this into my space heater load (10 ohm) and was able to maintain 50 vrms clean, maybe 53 at the onset of clipping, so it can put out full amplitude at some load (I haven't gotten around to making a second load to get down to 5 ohm). I ran a few different sine wave freqs and no stability issues or drop in power. I had it at that level for at least 5 minutes. Seems like it will be good enough for my use, as long as I am careful with my load and avoid cheap speakers.
  19. #19
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Cheap by itself is not the problem; but weird impedance is.
    B&O, Ashdown, all other users are not fools and must have extensively tested the modules with all kinds of reasonable speakers.
    Just guessing, but problem seems to be weird impedance, which must trigger all kinds of protections.
    In any case, copy the Peavey Triac crowbar, cheap and simple.
    Just thinking aloud, but since that is a bridged output amp and the crowbar does not really need reference to ground, I bet you can wire it "floating" across the speaker, so "just one" protects speaker from DC across terminals, no matter where that comes from, including two amplifiers driving it.
  20. #20
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    Was working on my latest class D bass amp, an Acoustic BN6210, and noticed that there was a small circuit board before the piezo tweeter. I did not verify if the amp module was B&O, but it looked very similar to their 500W Icepower module. I am guessing this board is to keep the class D amp from seeing the impedance of the piezo, which I think looks mostly like a capacitor. The Icepower module does have a capacitive load spec. I hadn't paid much attention to it since it said "purely capacitive" but maybe that means something different in German.
    I think this would support Juan's assertion that cheap speakers with multiple piezo tweeters are inappropriate for class D amps. BTW, those speakers have been sent off to the thrift store in hopes of frustrating some garage band's dreams of stardom.
  21. #21
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Thanks.
    Piezo being capacitive, typically .1 or .22uF and sometimes up to.35uF (depending on piezo disk diameter) and even worse in cheapie multi piezo PA/DJ cabs, I have seen some with 2 "midrange horns" and 5 round Tweeters ... all in parallel, just do the Math, they can make a MESS with Impedance.
    Doubly so with Class D amps which even without signal in have a full rail to rail signal out at switching frequency ... anything from 33kHz to 500kHz ...... a perfect storm
    So cheapest solution is to add a series resistor, most common value being 47 ohm ... I see 3 of them there plus a toroidal inductor and 2 caps.
    If you still have it outside, please add a copper side picture so I try to draw the schematic; if not, donīt worry.
  22. #22
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    flipped around horizontal axis, so inductor still towards the left.
  23. #23
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
  24. #24
    Supporting Member
    Aug 2017
    Portland, OR
    860
    Received: 312/1
    Given: 133/2
    3
    BTW, the one cap you can see is labeled as .47u the other two are .33u.
  1. Thumbs up for ZT Amplifiers tech support
    By glebert in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-13-2019, 07:31 PM
  2. Bang and Olufsen Icepower 500asp module sch
    By Misley in forum Schematic Requests
    Last Post: 11-13-2016, 08:03 PM
  3. schematic ICEpower 1000asp
    By sugengsound in forum Schematic Requests
    Last Post: 02-13-2013, 04:22 AM
  4. Does anybody have the schematics for ICEPower 250 & 500
    By paleeman in forum Schematic Requests
    Last Post: 02-02-2013, 07:27 PM
