G'day all,
I try and stay away from the 'modern' stuff like this but said I'd do this for a mate......
This post I guess is to more understand the circuit as much as fix it. Initial diagnosis , nil power up.
I found the Pwr supply chip U1 melted and the zenner D9 (ZD101) on the VCC input open cct. Replaced both and have checked all components in the primary side of the circuit.
Now have 13vdc at the U1 VCC (although it seems to modulate around a volt+/-.)
Still no good. There is 48V phantom power, which comes off TXFR tap 10 but nothing else.
I'll admit i'm at a loss.
How do you experienced fellas troubleshoot these things? im not 100% what I am actually looking for to see whats going on.
There is 110vdc at the o/p of all the Secondary Diodes D6 to D8 (D202 - 205 off datasheet) which is obviously not right. Them all being the same to me points to a common issue upstream???
Hope someone can shine a light at my incompetence!!!!
Trying in vain to upload the schematic but it is not co operating.
Here is the Data sheet link which is essentially the same although a bit simplified on the secondary side.
TIA
Gav
TIA
Gav
