Results 1 to 20 of 20
Thread: Laney Ah210 PA mixer power supply
  1. #1
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    G'day all,
    I try and stay away from the 'modern' stuff like this but said I'd do this for a mate......
    This post I guess is to more understand the circuit as much as fix it. Initial diagnosis , nil power up.
    I found the Pwr supply chip U1 melted and the zenner D9 (ZD101) on the VCC input open cct. Replaced both and have checked all components in the primary side of the circuit.
    Now have 13vdc at the U1 VCC (although it seems to modulate around a volt+/-.)
    Still no good. There is 48V phantom power, which comes off TXFR tap 10 but nothing else.
    I'll admit i'm at a loss.
    How do you experienced fellas troubleshoot these things? im not 100% what I am actually looking for to see whats going on.
    There is 110vdc at the o/p of all the Secondary Diodes D6 to D8 (D202 - 205 off datasheet) which is obviously not right. Them all being the same to me points to a common issue upstream???
    Hope someone can shine a light at my incompetence!!!!
    Trying in vain to upload the schematic but it is not co operating.
    Here is the Data sheet link which is essentiallyClick image for larger version.
ID:	54489 the same although a bit simplified on the secondary side.
    TIA
    Gav
    0 Not allowed! Not allowed!
    Cheers,
    Gavin
    Tone, its in your fingers mate!!
  2. #2
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,435
    Thumbs Up/Down
    Received: 1,999/7
    Given: 0/0
    Rep Power
    55
    Not sure what you have there, but first thing I check is the secondary side rectifiers for shorts.
    Remember this is an SMPS - switchmode power supply - and it does not run at 50/60Hz. SO any "AC" over there will not register on your meter well.
    Note pin 4 of the IC is the feedback from the secondary, and it can shut things down. Make sure we are not in shutdown.
    Note the primary and secondary sides have different grounds. SO you can't use the same ground as a reference to take readings on both sides. I suspect the you were using the primary side ground - where you got the 13v DC - to read the secondary voltages. That would explain the extra 100v everywhere.
  3. #3
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    Thanks Enzo.
    5vdc on the 30v rail and 3vdc on the 15v rail using the right ground reference this time. (Cheers)
    There is less than 100mv on the pin 4 feedback.
    The data sheet says there needs to be 15v Vcc for the chip start up to function so my guess is this is the issue.
    There is a waveform on the primary using my old cro. Ballpark 200v (300Dc) so something is trying to happen.
    Cheers,
    Gavin
  4. #4
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    First and foremost, the primary side INCLUDING GROUND is LIVE MAINS.
    Everything to the left of the transformer core (including primary winding) is deadly.
    Keep both grounds separate, do not join them with a piece of wire or your own body.
    So do NOT touch it or at least get a 220V-220V 1:1 isolating transformer of at least 100VA just for initial testing.
    You may try to disconnect all secondary loads, check (unplugged) that everything at left is fine, including new chio and other semiconductiors, plug it in (you might use a lamp bulb limiter but with a largish bulb, say 100W) and turn it on.
    Then measure secondary voltages referred to the secondary ground.
    Post results.
    PS: in any case, supply includes a Stby/Normal switch, try it both ways and see if supply starts.
    PS2: check you dont have fried secondary diodes or shorted capacitors, *something* killed that supply.
    Some SMPS do not like a bulb limiter, but we start using it anyway; worst case we find some other way later.
    1 Not allowed! Not allowed!
  5. #5
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    Thanks Juan.
    Appreciate the reply mate.
    The Txfr is PCB mounted so not sure how I can isolate it? Definitely aware of those primary voltages! The resovoir cap holds 300v well!
    The primary side powers up ok now. Nothing is burning however theres is only 13 volts Dc on the chips Vcc input.
    5v and 3v on the 2 secondary rails. Ill try and isolate components on the secondary side tomorrow.
    48 v phantom power is coming through ok which again I dont get.
    Not sure by what you mean about the stby/normal switch? Its just a standard power on 240v in switch.
    I still feel like its definitely primary side related. Im doing a lot of reading tomorrow on SMPS theory. I want to know why this is doing what its doing.
    I think my old analog Cro struggles to see the primary pulses. Not sure. Very inexperienced at troubleshooting this SMPS thing.
    Ill try and get the PDF schematic to upload as it wouldnt today. (Maybe too big at 3meg)
    Again, appreciate the replies.
    Cheers
    Cheers,
    Gavin
  6. #6
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Not sure by what you mean about the stby/normal switch? It’s just a standard power on 240v in switch.
    Im referring to the schematic you posted, look at the bottom right showing such a switch.
    If the full manual is too large for MEF, host it somewhere else and post download link here.
  7. #7
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    Cheers,
    Gavin
  8. #8
    Join Date
    May 2006
    Location
    Cheshire, UK
    Posts
    2,269
    Thumbs Up/Down
    Received: 571/4
    Given: 304/0
    Rep Power
    16
    Try it without the http://
    AH210 Service Manual
    What Juan said is worth repeating.
    "First and foremost, the primary side INCLUDING GROUND is LIVE MAINS.
    Everything to the left of the transformer core (including primary winding) is deadly."
  9. #9
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Can somebody else try to download it?
    The post link sends me to a home improvement site ????????????????????
    Mistakes I found so far:
    1) your link starts with which isnt possible, its either one or the other.
    2) what firefox shows on top of the home improvement page is:
    http://www.https.com//www.dropbox.co...anual.pdf?dl=0
    which again looks funny, since we have been sent to https.com ... ?????????
    Please check and repost
  10. #10
    Join Date
    May 2006
    Location
    Cheshire, UK
    Posts
    2,269
    Thumbs Up/Down
    Received: 571/4
    Given: 304/0
    Rep Power
    16
    Quote Originally Posted by ziggy007 View Post
    The isolation transformer is used to isolate the incoming mains supply to the unit then the "ground" of the switchmode transformer primary side can be connected to true ground to make it safe(r) to work on.
  11. #11
    Join Date
    May 2006
    Location
    Cheshire, UK
    Posts
    2,269
    Thumbs Up/Down
    Received: 571/4
    Given: 304/0
    Rep Power
    16
    Quote Originally Posted by J M Fahey View Post
    Could have been worse
    Check the link in #8 above. I think I've fixed it now.
  12. #12
    Join Date
    Dec 2009
    Location
    Canada
    Posts
    276
    Thumbs Up/Down
    Received: 145/0
    Given: 4/0
    Rep Power
    11
    Here it is as an attachment
    https://music-electronics-forum.com/...1&d=1564520933
    Attached Files Attached Files
  13. #13
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Thanks, dave hs modded link works.
  14. #14
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    Quote Originally Posted by Dave H View Post
    Firstly thx for fixing the link Dave.
    My query was more that I was not sure how to isolate the secondary loads in the way that Juan mentioned as the Txfr is PCB mounted.
    Cheers,
    Gavin
  15. #15
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    The idea is to have (just for testing purposes) the various supplies on the secondary side separated from their respective loads.
    So if connectors or wiring are in the path, just unplug or unsolder whatevers needed to disconnect them.
    Remember to label them properly to avoid reconnection errors.
    IF only copper tracks are involved, standard procedure is to cut them open with an X Acto knife, simply slitting them away, so theres no continuity between both sides.
    You measure your now unloaded supply and hopefully you have full expected voltage.
    Often a little high because its unloaded.
    IF you have a problem, you know its a supply problem (diode or cap, not much else there) and solve it, knowing its not being causedn byb the load.
    Once you are happy with that, you scratch a little of the epoxy solder mask on both sides of your testing cut and you apply a drop of solder on the now shiny copper exposed, period.
    If now some voltage is funky (or straight shorted to 0) you know its some load fault and not a supply one.
    The old "divide and conquer" method.
    EDIT:
    IF this were your supply, the points to cut and measure would be:
Name:	Laney Supply.jpg
  16. #16
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Check added graphic above
  17. #17
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    Isolated 15v easily but 30v to audio chip near impossible on this board layout. (For me anyway)
    The 15v rails oscillate between 5.1 and 5.3, the 30v are 6 to 7V.
    The phantom pwr is at 45v which taps off the 15v rail prior to diode.
    The Vcc oscillates between 10-13v which is not enough. Its 20v unloaded. Replaced the quasi regulator chip again to see. Same. All components in that cct checked ok.
    At a loss unfortunately.
    Maybe just buy a new power board from Laney if viable.
    Thanks for your help.
    Cheers,
    Gavin
  18. #18
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Mmmm, what a pity.
    Lets try just one more time, can we?
    IF we have disconnected all loads, then any trouble may be attributed (and eventually solved) EITHER to one of the rectifier diodes being shorted or filter capacitor shorted, since for the power supply "all are in parallel" meaning all suck power from the same core OR to Live side of supply, including the funky controller+switcher IC
    Now if one important and highly suspect load, the power amp, is not disconnected, then we cant be certain of anything.
    My mistake, I always referred to the generic datasheet schematic posted, which may or may not help you.
    Now I downloaded and opened the ACTUAL schematic, sameinstructions asbefore but now more focused.
    I *think* you are lucky.
    I guess the tracks feeding the (suspect) power amp are already interrupted because I see inductors at each of them which must be external components solered topads, doubt they can put a ferrite bead around aprinted track, so by (carefully) removing them, we can disconnect power amp from supply.
    Please check that, and if possible, remove them.
    Since they certainly use terrible lead free solder, first apply a little regular (leaded) solder to make it more liquid at lower temperature and then suck solder and remove inductors; then you can measure unloaded supply.
    Check these points:
Name:	Laney AH210 Supply Test.png
    Try my suggestion.
    If possible post some inductor area pictures, one above, one below, may clear things a bit.
    Either supply is heavily loaded and self turning OFF or primary side is not yet fully repaired ... but we can test that now.
    The Vcc oscillates between 10-13v which is not enough. It’s 20v unloaded. Replaced the quasi regulator chip again to see. Same. All components in that cct checked ok.
    Thats why I seem to be obsessed with "functional testing" rather than a "part by part" search ... unless we find a smoking gun that is.
    Do this last test and post results.
    Im kinda stubborn
  19. #19
    Join Date
    Mar 2009
    Location
    Sydney, Australia
    Posts
    78
    Thumbs Up/Down
    Received: 4/0
    Given: 14/0
    Rep Power
    11
    Thanks Juan.
    Yeah, its killing me too as I hate being beaten.
    Ive just found out I can get a whole new Laney SMPS board for $45 Aussie. Thats ridiculous. Shouldve done that research first. Haha.
    Im definitely going to keep trying when I get the chance as I love the learning of new areas. Ill pull those inductors. Plainly obvious now youve pointed it out.
    The fact that the Vcc oscillates to me points that its still primary.
    Cheers,
    Gavin
  20. #20
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Oh, for $45 just replace it; and leave the old board aside for further use.
    When/if you repair it, it can make a nice plate amp driving *two* monitors or a powerful PC or TV speaker or ....
    A 100+100W amp able to drive 4 or 8 ohm loads is always useful in lots of places.
Thread Information
Users Browsing this Thread
  1. Power supply for Phonic MM502 mixer
    By Risto in forum Music Electronics
    Last Post: 03-15-2016, 10:56 PM
  2. Roland PA-250 Mixer Amp Power Supply.
    By Boik in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-27-2016, 09:19 PM
  3. Behringer Europower PMP1280S Mixer power supply failing?
    By Boffosteve in forum Music Electronics
    Last Post: 06-05-2013, 06:14 AM
  4. Laney CD1090s Powered Mixer
    By bluesman123 in forum Schematic Requests
    Last Post: 08-19-2011, 01:50 PM
  5. alesis studio 32 mixer power supply
    By roughcut studios in forum Schematic Requests
    Last Post: 12-05-2010, 09:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
