Results 1 to 16 of 16
Thread: '62 Kay 503A Volume Squeal
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    I'm getting a crazy annoying and loud squeal when I turn the volume knob up. I've gone thru the amp and have new caps. Would this problem most likely be a tube or the volume pot? If the pot, how do I test it?
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,437
    Received: 2,519/7
    57
    I doubt it is the pot. COuld be a tube, or could be wire dress, or a host of other things.
    Supporting Member TomCarlos's Avatar
    Oct 2009
    Roseville, Ca.
    915
    Received: 192/0
    Given: 321/0
    11
    Is this one of those (tube) amps where you need to make sure the speaker is grounded to the chassis? I remember having a similar problem with an old Gibson Ranger amp. There were two leads coming off the output transformer going to the speaker. But because there was no speaker jack connected to the chassis, I had to run an extra wire from the speaker (-) to the chassis ground.
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    I doubt its a ground issue since it is intermittent, which I should have mentioned. I'll test all the tubes tomorrow and go from there.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,437
    Received: 3,071/5
    Given: 3,710/0
    32
    Quote Originally Posted by Perkinsman View Post
    Could still be a tube. Sometimes they can behave and then just leap into microphony. More likely a bad solder joint, internally faulted lead or loose/dirty tube socket slot that is losing contact intermittently. But tubes are easy to test by replacement so there's no reason not to try that first.
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,783
    Received: 326/2
    Given: 292/0
    16
    The fastest way is to temporarily replace the pot with a pot that you know is correct.
    Check condition R7/ 3M9 and C3/ .05
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    Quote Originally Posted by TomCarlos View Post
    As you can see in the pic, there are 2 (blue & red) leads from the OT to the tubes. There is an odd grey lead that runs from the speaker frame to the amp chassis.
    Jul 2006
    1,783
    Received: 326/2
    Given: 292/0
    16
    Gray wire is the grounding of the speaker basket.
    It is slightly wrapped around blue & red wire to form a kind of shielded cable.
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    Quote Originally Posted by vintagekiki View Post
    Can I use any size pot or does it have to be same as volume, 1/2 meg?
    I replaced R7 & C3, still squeals when volume is over 6-7. What is 3M9?
    I attached the schematic, btw, this is a 504 model, not a 503a as I originally posted. My bad.
    Jul 2006
    1,783
    Received: 326/2
    Given: 292/0
    16
    Kay 503
    https://el34world.com/charts/Schematics/files/Kay/Kay503a_1962.jpg
    The values for R7 & C3 refer to the Kay 503A schematics; 3M9 = 3.9Meg
    Kay 504
    Volume pot between 1/2 Meg to 1 Meg
    I assume there are new tubes in the Kay 504 during repair.
    Check condition C1 (20 + 20 + 40)
    Between R8 and R13 parallel to C1 (20) R8 and R13 parallel to C1 (20) temporarily connect 22uF/ 400V
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    Kay 503
    Kay 504
    Interesting Update: There's 3 inputs on this amp. Inputs 2 & 3 didn't squeal, input 1 does. Bad jack?
  12. #12
    Jul 2006
    1,783
    Received: 326/2
    Given: 292/0
    16
    Most likely to oxidize the ground from input 1.
    Clean the chassis below input 1 and replace jack.
    4 Not allowed! Not allowed!
  13. #13
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    Now that you mention it, I did notice that the thin nut was looking oxidized but didn't stop to think that might cause a problem. I cleaned everything else in the amp! Tomorrow I'll clean that ring nut & the chassis underneath & report back.
  14. #14
    Supporting Member
    Jul 2019
    Northern California
    290
    Received: 30/0
    Given: 22/0
    0
    Success!! I took the jack off, clean the chassis, used a little emory cloth on the part that makes contact with the tip of the jack and emory cloth'd the inside of the jack. Then used contact cleaner on the parts and Voila!
    Now all 3 of the jacks work, pots are all cleaned, filter caps replaced with fresh stock and a few smaller caps. Amp sounds great at 10, tremolo is very sweet too.
    Big thanks to Vintagekiki!
    2 Not allowed! Not allowed!
  15. #15
    Jul 2006
    1,783
    Received: 326/2
    Given: 292/0
    16
    Glad you found a solution and repaired your amp.
  16. #16
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Kapaa Kauai
    3,312
    Received: 478/6
    Given: 56/1
    16
    If itís a standard Switchcraft jack.. replace it. Using emery cloth on contacts isnít a permanent solution.
  1. 5f1 hum and squeal
    By 5thumbs in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-04-2016, 11:54 PM
  2. 5F1 build developed squeal when on high volume
    By northern picker in forum Debugging Your Build
    Last Post: 04-09-2012, 05:23 PM
  3. Kay 503A questions...
    By gmoon in forum Repair and Restoration
    Last Post: 04-20-2011, 06:32 AM
  4. PeaveyTMax squeal
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-05-2010, 01:07 AM
  5. 5e3 squeal tone and volume pots
    By acjohnson in forum 5 E 3
    Last Post: 03-31-2008, 07:51 PM
