Fender Blues Deluxe Reissue Drive Channel not Working
  • Fender Blues Deluxe Reissue Drive Channel not Working
    When I engage the "channel select" button, the red led comes on, both the master & drive volume work, the normal volume is diabled but it doesn't get 'dirty", it just stays clean.
    I've ran the 12ax7s thru a tube tester and they all test fine. The area around the 2 watt resistors are not showing any browning. What components (list by number on schematic) are most likely the problem?
    Why the second thread. Aren't we already doing this somewhere else?
      Sorry, I thought starting a new post would eliminate the confusion I caused by initially providing the incorrect model. I'm responding back to the original post. Thanks for your con'td assist. I'm not sure how to delete this post.
