Results 1 to 30 of 30
Thread: NiCad charger getting hot
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    OK, so not a music related question, but my Ryobi cordless NiCad charger gets hot just sitting there plugged in with no battery in it. I opened it up and the power transformer is too hot to keep a finger on. It is pulling 3.6mA, that doesn't seem like much does it? It charges OK, and I don't see anything obvious, I wonder what's up? Would not want to start a fire, but don't want to have to buy a new one. Would you trust it?
    May 2010
    Sioux Falls, SD
    6,926
    Received: 1,693/2
    Given: 1,219/1
    18
    I wouldn't think a charger would get that hot with no load/battery. Have you looked at the guts? There can't be that much to a simple charger.
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    Nothing looks unhappy. The PT passes the neon bulb test. Diodes all seem OK. Perhaps for giggles I will replace the electrolytics, the big one did measure as a short in circuit a couple of times, then it looked OK, not sure why.
    May 2010
    Sioux Falls, SD
    6,926
    Received: 1,693/2
    Given: 1,219/1
    18
    Those Samxon caps aren't the best quality (mildly put). It wouldn't surprise me if one was leaky.
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    That's what I am thinking Dude, can't hurt to order some replacements.
    Professional Lurker eschertron's Avatar
    Aug 2012
    Great Black Swamp
    2,366
    Received: 522/0
    Given: 1,366/1
    11
    Is the PTC device (thermistor?) laying down on top of another component? It looks like a simple jumper under it, and I'm wondering if the thermistor should be sensing a component, or standing up and measuring free air temp.
    May 2010
    Sioux Falls, SD
    6,926
    Received: 1,693/2
    Given: 1,219/1
    18
    I see thermal paste on the bridge rectifier, so it must mount to a heat sink. I'm guessing the thermistor butts up against that heat sink when the thing is put together.
    1 Not allowed! Not allowed!
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,470
    Received: 337/2
    Given: 124/3
    16
    NiCd??
    Those bats are OBSOLETE!
    Eventually they will take no charge and charger will die trying. Sadly Ryobi makes no adapters like these
    My dad just adapted all his old NiCd over to Li ion but his drill goes so fast he cams out everything when trying to drive, so I got him the 3 speed 20V driver
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    The BR and the X0405 thyristor are the components mounted to the heat one sink. They are not real close together. I don't see a thermistor.
    "Those bats are OBSOLETE!"
    Tell that to the 40 -50 year old satellites that are still running on NiCads. They can be rejuvenated, I just did it to a "dead" Ryobi 18v battery. Totally dead, wouldn't even turn my drill after 1 hour on charger. Put the battery in the charger with red light on, unplug/replug the charger several times, surging the cells until the grren light comes on. Now a dead battery charges up to 20v, and holds a charge for days. How's that for obsolete?
    Now if I can just get this charger to cool down, I'm good for another few years.
    2 Not allowed! Not allowed!
    May 2010
    Sioux Falls, SD
    6,926
    Received: 1,693/2
    Given: 1,219/1
    18
    Thermistor is the yellow device marked PTC on the circuit board.
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    Oh. I assumed it was just a cap. It is bent down, but not touching a small diode D9. I wouldn't think that would be the root of the problem here, could it?
  12. #12
    May 2010
    Sioux Falls, SD
    6,926
    Received: 1,693/2
    Given: 1,219/1
    18
    I wouldn't think so, but anything is possible. You could test it with a hair dryer if you like- PTC, so resistance should increase with temperature. Does it locate near the heat sink as I conjectured?
  13. #13
    Feb 2010
    12,643
    Received: 2,186/24
    Given: 5,512/11
    24
    Doubt that the ptc is the issue, more likely the caps as were mentioned.
    But where are you measuring the 3.6mA ? I don't see how that kind of draw would make the transformer get hot. That's like one of the LED's turned on.
  14. #14
    Apr 2008
    Sonoma CA
    3,470
    Received: 337/2
    Given: 124/3
    16
    Good luck on keeping them going! Yours is a noble pursuit!
    Actually "nurse maiding" their charging with a CC/CV power supply is sometimes required; the chargers can have too many protection sub routines to allow you the flexibility to do this. Many call it quits at too low a voltage, or if the charging is off schedule.
    Part of this is to avoid fires; I might do the alchemy in an unattached out building!
  15. #15
    Supporting Member
    Jan 2018
    Michigan
    305
    Received: 79/0
    Given: 151/0
    3
    Quote Originally Posted by tedmich View Post
    NiCd??
    From the manufacturer , last I knew you could still get NICD/NIMH packs rebuilt at Batt +/Interstate centers. A little pricey but cheaper than buying new interchangeable Li ion + charger.
  16. #16
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    "You could test it with a hair dryer if you like- PTC, so resistance should increase with temperature. Does it locate near the heat sink as I conjectured?"
    It is about 1/2" from the heat sink, but I still don't see how this would make the transformer heat up like this.
    "But where are you measuring the 3.6mA ? I don't see how that kind of draw would make the transformer get hot. That's like one of the LED's turned on."
    Measured across the open fuse at the secondary of the PT. No LEDs are on.
  17. #17
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    What matters regarding transformer heating is primary current.
    Please measure with and without secondary load.
    Do you have a "Kill a Watt" meter that reads real input power?
    - Own Opinions Only -
  18. #18
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    Current measured by placing ammeter in AC line is 0.093A loaded and unloaded, that is with secondary fuse in/out, but not charging a battery. 11.6 watts.
  19. #19
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    Quote Originally Posted by Randall View Post
    At 120V that means an apparent input power of 11.2W, which is quite a lot for a small transformer (what are the core dimensions?). Unfortunately without a "Kill a Watt" we don't know the percentage of real power (heating up the transformer) and reactive power.
  20. #20
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    2,108
    Received: 786/1
    Given: 1,918/1
    13
    I have a pair of NiCd batteries in a vintage General Radio 1564A Sound & Vibration Analyzer (1/3 Oct, 1/10 Oct, All Pass) that I bought used in Aug 1992 for $40 at a Radio Amateur's Technical Swap Meet TRW in Redondo Beach, CA, and those NiCd batteries are STILL going strong. I don't know who GenRad found as a battery supplier, but they picked a great one! (Gould 9.6V x 2)
  21. #21
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    I have 125v here, puts it at 11.6W. Laminate dims are 2.5" x 2.25" x 1.15".
    I just ordered a Kill A Watt meter.
  22. #22
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,889
    Received: 1,785/21
    Given: 1,461/0
    14
    You're bound to have some fun with that! Excellent piece of kit to have around the workshop & house.
    Enjoy. Every. Sandwich.
  23. #23
    Feb 2010
    12,643
    Received: 2,186/24
    Given: 5,512/11
    24
    My thinking was that during normal operation, when a LED was on, drawing that kind of current, the supply should not overheat. 3.6mA at the secondary should not pull approx. 100mA from the primary, in any case.
    I think we may be seeing a limitation of the neon bulb test for transformers, as you said it passed.
  24. #24
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    "I think we may be seeing a limitation of the neon bulb test for transformers, as you said it passed. "
    I was thinking the same thing.
  25. #25
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    Shorted turns should show in the neon bulb test and would most probably cause way higher input current.
    I think it's just a poor transformer design with relatively high magnetizing current. This is caused by low primary inductance. I also assume relatively high primary DCR.
    DCR times input/magnetizing current squared heats up the winding. (Any chance that the core laminations loosened allowing Es and Is to separate?)
    I just measured a smaller transformer having a core size of 2.15"x1.79"x0.8". Apparent input power at idle is 8.4W, real (heating) power 2.1W. Gets barely warm.
  26. #26
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    So what is the bottom line here? I don't remember it always getting hot like this. Is the transformer malfunctioning? I have included a couple of shots of it, but it doesn't look to me like there is anything amiss with the laminates or anything else. I looked it up, it is used in microwave ovens as well as Ryobi chargers, and they are available used for a price.
ID:	54727Click image for larger version.
    edit: after being plugged in for over an hour out of the case and with secondary fuse out, the laminates measure 128*F at the top of the transformer, somewhat less at the bottom.
  27. #27
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    Bottom line is that a PT that gets too hot even without a load should be replaced because it is a potential safety risk. Even more alarming if it ran cooler before, as that means that something inside the PT must have changed and might continue changing.
    The neon bulb test shows that there is no problem with the windings. I rather assume that for some reason (temperature, vibration, mechanical shock, corrosion) the effective airgap of the core has increased. This would explain increased input current and transformer dissipation/heating.
  28. #28
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    "I rather assume that for some reason (temperature, vibration, mechanical shock, corrosion) the effective airgap of the core has increased. This would explain increased input current and transformer dissipation/heating. "
    Well it does live in my garage always plugged in, in SW Florida where it is often hot and humid. Time for a new one I guess.
  29. #29
    Sep 2011
    Pace, FL
    3,638
    Received: 1,321/102
    Given: 183/36
    12
    Man if it's been heat indices of 105 to 113 down there like it's been here they need a new word for hot n humid maybe F'ing hot!
    nosaj
  30. #30
    Jan 2013
    Cape Coral, FL
    2,662
    Received: 640/0
    Given: 116/0
    10
    I scored a good used charger for $15 shipped. It doesn't get nearly as warm, even while charging. Buh-Bye potential fire hazard!
  1. 34 lbs. of force from Neo bar mag enough to charger alnico?
    By Kindly Killer in forum Pickup Makers
    Last Post: 09-15-2011, 09:51 PM
  2. Kustom Charger bass amp schematic
    By laroi888 in forum Schematic Requests
    Last Post: 06-18-2011, 06:43 AM
  3. Kustom Charger
    By Koos in forum Guitar Amps
    Last Post: 06-18-2011, 05:18 AM
  4. Magnet Charger
    By belwar in forum Pickup Makers
    Last Post: 07-07-2009, 08:33 AM
  5. Magnet Charger
    By Pep in forum Pickup Makers
    Last Post: 12-18-2006, 04:48 AM
