OK, so not a music related question, but my Ryobi cordless NiCad charger gets hot just sitting there plugged in with no battery in it. I opened it up and the power transformer is too hot to keep a finger on. It is pulling 3.6mA, that doesn't seem like much does it? It charges OK, and I don't see anything obvious, I wonder what's up? Would not want to start a fire, but don't want to have to buy a new one. Would you trust it?
NiCad charger getting hot
Is the PTC device (thermistor?) laying down on top of another component? It looks like a simple jumper under it, and I'm wondering if the thermistor should be sensing a component, or standing up and measuring free air temp.If it still won't get loud enough, it's probably broken. - Steve Conner
I see thermal paste on the bridge rectifier, so it must mount to a heat sink. I'm guessing the thermistor butts up against that heat sink when the thing is put together."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The BR and the X0405 thyristor are the components mounted to the heat one sink. They are not real close together. I don't see a thermistor.
"Those bats are OBSOLETE!"
Tell that to the 40 -50 year old satellites that are still running on NiCads. They can be rejuvenated, I just did it to a "dead" Ryobi 18v battery. Totally dead, wouldn't even turn my drill after 1 hour on charger. Put the battery in the charger with red light on, unplug/replug the charger several times, surging the cells until the grren light comes on. Now a dead battery charges up to 20v, and holds a charge for days. How's that for obsolete?
Now if I can just get this charger to cool down, I'm good for another few years.It's weird, because it WAS working fine.....
I wouldn't think so, but anything is possible. You could test it with a hair dryer if you like- PTC, so resistance should increase with temperature. Does it locate near the heat sink as I conjectured?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Doubt that the ptc is the issue, more likely the caps as were mentioned.
But where are you measuring the 3.6mA ? I don't see how that kind of draw would make the transformer get hot. That's like one of the LED's turned on.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Good luck on keeping them going! Yours is a noble pursuit!
Actually "nurse maiding" their charging with a CC/CV power supply is sometimes required; the chargers can have too many protection sub routines to allow you the flexibility to do this. Many call it quits at too low a voltage, or if the charging is off schedule.
Part of this is to avoid fires; I might do the alchemy in an unattached out building!
Originally posted by tedmich View PostNiCd??
Those bats are OBSOLETE!Last edited by shortcircuit; 08-14-2019, 01:08 AM.If you don't know where your going any road'll take you there : George Harrison
