Results 1 to 10 of 10
Thread: Positive voltage on grid of self-biased triode at idle
    Member mhuss's Avatar
    Nov 2006
    West of Philly
    318
    Received: 25/0
    Given: 1/0
    14
    We're having an odd problem with V2 in a couple of recent builds. After a few minutes, a small positive voltage (~.5 - .8vDC) gradually builds up on the grid, which of course causes the stage to be biased very hot and incapable of passing an undistorted signal. The plate voltage is normally ~175v but gets dragged down to 140 or so at idle. Grounding the grid with a jumper brings things (at idle) back to normal. There is about 240k DCR from grid to ground (by inspection, and verified with a meter). Replaced the tube, measured all the neighborhood resistors, everything is within spec. Resistance between pin 1 and 2 measures 'open circuit.' Turning both input volumes to zero has little to no effect.
    I'm out of ideas - any suggestions?
    Schematic similar to this (but no cathode bypass cap): https://hiwatt.org/Schematics/DR_Pre4Input_v2.pdf
    Supporting Member
    Staffordshire UK
    3,822
    Received: 562/1
    Given: 485/2
    18
    Maybe a bad batch of tubes?
    Try one from a completely different manufacturer.
    1 Not allowed! Not allowed!
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,914
    Received: 2,753/4
    Given: 3,223/0
    30
    Are there any other symptoms? Otherwise I agree that it could be a bad batch of tubes.
    Mar 2008
    838
    Received: 106/0
    Given: 229/0
    12
    I.ll look for severe high freq osscilation at that tube at a point.
    2 Not allowed! Not allowed!
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    Jun 2011
    South West Arkansas
    166
    Received: 21/0
    9
    What do you get if you pull the tube and measure voltage on the pin at the tube socket?
    Mar 2008
    838
    Received: 106/0
    Given: 229/0
    12
    Put a grid stopper first, close to the socket.Change the ground reference point of shielded cable (if you used one). See if something changed.
    Nov 2006
    West of Philly
    318
    Received: 25/0
    Given: 1/0
    14
    Tried a known good tube from another amp - same thing.
    The preamp grounding is pretty 'good', grounded at the chassis next to the input jacks, with subsequent stages chained to that point. It's a low gain design, so we rarely have oscillation problems.
    We finally changed the (brand new) coupling cap connected to the plate(!) and somehow that made it come around.
    Thanks for the suggestions!
    Feb 2010
    12,186
    Received: 1,928/24
    Given: 4,871/11
    24
    The coupling cap from V1 plate?
    You said the problem was in more than one build, so more bad caps?
    Nov 2006
    West of Philly
    318
    Received: 25/0
    Given: 1/0
    14
    Perhaps - or maybe the cap was a false flag(!) He hasn't gone back and checked the second one yet. (I'm troubleshooting remotely, sigh.)
    Given the tube is OK (based on working fine in an older amp) what else could cause significant positive voltage on the relatively-low-impedance-to-ground grid?
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Different possibilities to test:
    Leaky/contaminated board material.
    Same with socket.
    What do you use? Turrets/eyelets (mounted on what?)
    Fiberboard - pertinax - glass-epoxy - Formica?
    Please post close up pictures, both sides.
    Turn amp ON but with V2 unplugged, read voltage at all socket pins in this sequence: :OFF > just ON > 5/10/15/20/30 minutes later
    Now plug V2. all controls to 0, repeat voltage testing on all pins (except filaments that is).
    You are looking for the unexpected/abnormal/ "shouldn´t be this way".
    n
  1. What is positive and negative grid current.
    By Alan0354 in forum Theory & Design
    Last Post: 03-12-2014, 09:31 PM
  2. Negative voltage on grid of cathode biased output tube...
    By alchemy in forum Debugging Your Build
    Last Post: 04-10-2011, 08:17 PM
  3. Replies: 3
    Last Post: 02-16-2010, 06:03 PM
  4. Replies: 4
    Last Post: 06-29-2009, 10:29 PM
  5. Mark IV EQ on positive voltage?
    By GainFreak in forum Theory & Design
    Last Post: 05-31-2009, 10:35 PM
