Results 1 to 16 of 16
Thread: Weird OT issue ?
  1. #1
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    Weird OT issue ?
    Hello,
    I just noticed using one Hammond OT and trying to apply some nfb. Keeping common secondary lead to whatever ground point or keeping isolate didn't do any diference. I checked DC continuity in isolation condition and shows secondaries are isolated from ground, the output jack's are suspended from chassis, even the iron is physical dc isolate from its support. I injected 9db feedback in my amp and from an accident I disconnected the common ground lead from the ground. I didn't noticed any diference . I repeated more carefully, swapping signal from 100 to 10000 hz, no diferences,the feedback loop is pretty stable with, or without common lead grounded, it looks like OT was grounded by default, despite the fact it is completely isolated. In fact it not exist a physical nfb return.Now I wonder if my transformer could be as well AC coupled with my steel chassis to not see any diference in terms of grounding. It is normal , please? Thanks
    1 Not allowed! Not allowed!
  2. #2
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    And the circuit:
    How nfb loop can be functional without nfb return to common OT tap, please? Thanks
  3. #3
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,099
    Thumbs Up/Down
    Received: 2,886/4
    Given: 3,403/0
    Rep Power
    31
    It looks to me like the global FB may be getting cancelled by the anti phase of the triodes at the shared cathode because both are elevated by a 47R resistor. What happens if lift the global FB loop? Any change? My thinking is that you may not be seeing that you still have a FB loop without common ground, but rather that you DON'T have a FB loop even with a common ground.
    0 Not allowed! Not allowed!
    "In fact when I run into problems working on electronic circuirts, there are so many times that when I finally track it down, the source of the problem is located between my soldering iron and my seat." SoulFetish
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
  4. #4
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    Hey, thanks for you input.
    The feedback is applied only over 47ohm resistor in cathode of first stage, the 100u over shared 820ohm resistor drain ac voltage to the ground, the 47 ohm over non inverted stage is there just to keep the bias as same and is not compulsory, so nothing is cancelled. The amount of feedback works exactly as should be. Lifting the nfb wire put the voltage gain of the stage with 9 db more.
    I still not see it the issue in circuit, the global feedback works very well, except the fact lifting nfb return didn't do any diference. The OT is completely isolated by any grounding point. I don't get it....
  5. #5
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    This is a pic at onset clipping with 9...or 10 db nfb applied ( not sure ...did a lot of changes) with nfb return lifted. It looks pretty decent, nothing to worry, ..but how the heck it works just with one wire...?
    and with nfb lifted
    Both pictured without any nfb return, without any common secondary tap physical tied to any ground. DC is infinite
  6. #6
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,099
    Thumbs Up/Down
    Received: 2,886/4
    Given: 3,403/0
    Rep Power
    31
    Are you sure the load is floating also? Because that could provide a return path to 0V if it's weren't.
  7. #7
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    Yes, I removed the output jack's from chassis to be sure and the power resistors are away on my table. It's woo-doo I tell Ya.
    What it remains to do is to remove the OT bolts and to move it away to see if the loop is not closed by induced current in chassis - if it have any sense...
  8. #8
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    Oh, wait a sec.... Can be the loop closed through the probes via wall outlet and far away through earth protection of the amp ? Should be a long return, but still...?
  9. #9
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,099
    Thumbs Up/Down
    Received: 2,886/4
    Given: 3,403/0
    Rep Power
    31
    I'm interested. I'd be surprised if the OT EMF is coupling/damping at the chassis so completely that the NFB level doesn't change significantly from an actual common connection to 0V. Not much to work with. I'm out of ideas.
  10. #10
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,099
    Thumbs Up/Down
    Received: 2,886/4
    Given: 3,403/0
    Rep Power
    31
    Quote Originally Posted by catalin gramada View Post
    I thought about this, but it seemed unlikely. The probes should have considerable impedance.
  11. #11
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    ....no, no...Bingo! ...I just checked ...between probes and amp chassis get 0.25 ohm resistance. It is a healthy path....Thank You.
    The alligator clip which was connected to the common tap get contact direct with the chassis through 0.25 ohm resistance of earthing wiring.
  12. #12
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    16,099
    Thumbs Up/Down
    Received: 2,886/4
    Given: 3,403/0
    Rep Power
    31
    Oh.!. You have the scope plugged in and obviously grounded. So because you're measuring AC at the load you have the scope - connected to one end of the load and the + connected to the other. Makes sense now. Glad you found it before unbolting the transformer
  13. #13
    Join Date
    Feb 2010
    Location
    Posts
    12,389
    Thumbs Up/Down
    Received: 2,034/24
    Given: 5,197/11
    Rep Power
    24
    Quote Originally Posted by Chuck H View Post
    'Floating' load means NO other earthed equipment (like scope) be connected. This is also very problematic when testing solid-state amps that use current feedback.
    Best practice is to leave scope ground connected to amp chassis, or measure at load with a hand held multi-meter that has no earth connection.
    4 Not allowed! Not allowed!
  14. #14
    Member uneumann's Avatar
    Join Date
    Jun 2010
    Location
    Los Angeles
    Posts
    277
    Thumbs Up/Down
    Received: 78/0
    Given: 56/0
    Rep Power
    10
    Quote Originally Posted by g1 View Post
    True - problematic, but many dual-channel scopes allow A-B display so they provide a solution. The A and B channel probes can be connected to the two floating outputs, with their ground clips both clipped to chassis. This safely avoids the ground problem described above, and it shows exactly what the output (spkr) signal looks like.
    Old Tele man: Equations provide theoretical values, SPICE provides approximate values; but, the ears provide exact values.
    Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
    https://sites.google.com/site/stringsandfrets/
  15. #15
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,885/23
    Given: 1,463/35
    Rep Power
    27
    Why do you say so?
    The "common" end of the OT is connected DIRECTLY to ground, per your schematic .
    And the 8 ohm tap is connected to first PI cathode through a 2k2 resistor and a series 100uF capacitor.
    NFB loop, at audio frequencies, is 2k2/47 ohm
  16. #16
    Join Date
    Mar 2008
    Posts
    852
    Thumbs Up/Down
    Received: 107/0
    Given: 230/0
    Rep Power
    13
    Hi. Yes this was the circuit. My issue was related by accidental disconnection of nfb return which You remarked in the drawing. I didn't saw it the earth grounding path because is pretty unfamiliar for me on my bench. I did my hobby for years in a building without earthing connection at wall sockets and anyhow I used to use grounding paths soldered even for experiments. Now it was happen to use a strap wire which accidental was disconnected, is not happen to often to me, especially when work over hundred volts...but was happen and didn't know where to look. I have limited experience, I didn't learn from books, just test some circuits when have time and save what I consider relevant for futures builds. I found the source of problem by determination not by analysis. I checked DC resistance in circuit removing the load, the scope was conected over my load resistor, I did not saw it.
    Got a lot of good advices over here, Thanks guys!
Thread Information
Users Browsing this Thread
  1. JCM900 noise issue this is a weird one...
    By SoulFetish in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-12-2019, 06:01 AM
  2. JCM 2000 DSL 50 weird cut in & out & dead issue
    By j.walker in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-17-2017, 05:31 PM
  3. ENGL Savage 120 with weird grounding issue
    By kka in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-31-2015, 02:05 AM
  4. Cathode bias *cap* issue - weird whistle
    By EFK in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-14-2011, 12:44 AM
  5. 5E3 volumn control weird non-issue
    By Danelectron in forum Music Electronics
    Last Post: 01-17-2010, 08:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
