Results 1 to 6 of 6
Thread: Roland cube 60d send return mod
    Twobie
    Aug 2019
    4
    Given: 2/0
    0
    Hi guys,
    Any suggest?
    I need only power amp section.. To use with another preamp.
    Someone Can give me some idea?
    Thank you..
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Schematic?
    I think it uses a chipamp, an LM3886, but might be wrong.
    EDIT:
    if it matches the schematic posted elsewhere, you must find the track joining R187 and C49 , cut it, and add an insert jack there, so no plug and everything is as before; you insert an external preamp and it replaces the old one.
    2 Not allowed! Not allowed!
    Twobie
    Aug 2019
    4
    Given: 2/0
    0
    Schematic?
    EDIT:
    I ll give a look
    In the while.. Thank you!
    Twobie
    Aug 2019
    4
    Given: 2/0
    0
    I suppose,
    If i dont cut r187 c49 track, but i just insert an input in +c49, is the same? I just use lm3886 and bypass pre and effects. Is correct? Or Can i have some problem? (of corse without any other input signal connwcted
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Quote Originally Posted by Slash_83 View Post
    I suppose,
    You need to cut the track (which is easy peasy) and add a switching jack (same circuit as in FX return jacks) or any signal you inject there will be shorted to ground through the Preamp output impedance.
    If you want to use just the LM3886 Power Amp by itself you need to REMOVE the preamp out of the picture, and that is accomplished by the added Power In switched Jack.
    1 Not allowed! Not allowed!
    Twobie
    Aug 2019
    4
    Given: 2/0
    0
    Very Clear
    Thank you fahey
  1. Twin reverb Send/Return controls
    By ThisLifeILead in forum Theory & Design
    Last Post: 09-14-2016, 04:24 AM
  2. PRRI: Rewiring reverb send/return & verb/trem footswitch to original layout???
    By Clear Guy in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-23-2016, 08:54 PM
  3. Fender '63 RI reverb unit as a send/return effect?
    By telstar in forum Guitar Effects
    Last Post: 05-16-2015, 09:37 AM
  4. New to FX loops - Send and return controls needed?
    By Gaz in forum Theory & Design
    Last Post: 01-20-2012, 12:51 PM
  5. Fender reverb send/return as effects loop?
    By mike_mccue in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-03-2010, 04:09 AM
