Rectifier substiture?
  • Rectifier substiture?
    I'm trying to find a substitute for an obsoleted rectifier, SF304 (see attached datasheet). Does this look like a good substitute?
    FFA60UP20DNTU
    https://www.mouser.com/ProductDetail...2Bnw0GaA%3D%3D
    Is there any reason the replace the other, opposite polarity rectifier in the circuit if it tests good?
    Thanks!
    I think you will need to provide info regarding the intended application (eg schematic with voltages) before anyone can have a chance of helping.
      I agree^^^
      But it looks like the specs are the same: ultra-fast, 30A, 200v.
        It's close but the forward voltage drop is quite a bit higher. Therefore the power dissipation will be significantly higher too. That might not matter if the thermal margins are good.
          If you don’t have a schematic tell us what it’s in?
            Thanks everyone.
            It's for the Mackie FR M1400i I am working on in this thread:
            https://music-electronics-forum.com/...573#post537573
            The schematic is in that thread. I'm somewhat confident that I found at least part of the problem with this thing, but of course the rectifier is obsoleted. I figured the generic question regarding a substitute would see a bigger audience in this forum than the specific thread on the amp. The substitute I am asking about was what Mouser listed as similar, once I chose the same form factor, and other specs of the SF304.
              The problem is it takes a long time to research and compare parts. Per my comment above I suggest you find one with a lower forward voltage drop. I don't think the switching speed is crucial, although it may affect the noise level. Power dissipation is important. You might consider a schottky diode for speed and low drop.
                FWIW: The NTE6251 is a cross and is available.
                  Excellent, thank you!
