I switched out the R28 47k bias resistor for a 33k to get the amp biased in range. I was able to get proper readings on one side of the OT while checking bias, where I read 15.3ohms between center tap and brown primary, as well as -1.2vdc. My problem is that when checking these readings on the red primary, I got +25vdc between center tap and primary. When I pulled the phase inverter it read properly at -1.2vdc. What went wrong here?
Marshall Super Lead RI Oscillation trouble
Connecting the meter lead to the red primary wire causes the amp to oscillate and gives wrong idle reading. Happens often. Pulling the PI tube disrupts the FB loop, stops the oscillation and allows correct idle current reading.Last edited by Helmholtz; 08-28-2019, 11:09 AM.- Own Opinions Only -
