LINE 6 POD PRO schematics/ service manual
  • LINE 6 POD PRO schematics/ service manual
    Howdy.
    I cannot seem to locate any reference online to the LINE6 POD PRO service manual on ANY of the many links available searching for hours. It looks like everything else or a majority are available but not this particular one. There is POD and POD 2 but not POD PRO! This is the red rackmount unit. It has a shorted (Neg supply) opamp,probably in the front end that also took out a series resistor for that supply section. With a schematic it should be easier to isolate the offending part and the R value, but is a pain in the ass without.
    Much thanks in advance. Line 6 is useless in this regard and even treat old gear as proprietary for some reason.
    Cheers,
    Gregg
    I can't find a schematic, but there should be a corresponding resistor on the positive supply that might be the same value.
