Page 1 of 5 12345 LastLast
Results 1 to 35 of 142
Thread: Paraphase inverter question
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    Hello,
    What's happen if I couple R4 and R5 resistors to plates with capacitors and remove C2 and tie second grid directly to the junction instead, in the circuit below, please ? The coupling caps to power tubes remains into position. Thanks
    Just like this;
    1 Not allowed! Not allowed!
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    Quote Originally Posted by catalin gramada View Post
    I guess it'll work the same. But why spoil the elegant simplicity of the original circuit by adding an extra capacitor?
    2 Not allowed! Not allowed!
    Professional Lurker eschertron's Avatar
    Aug 2012
    Great Black Swamp
    2,364
    Received: 522/0
    Given: 1,366/1
    11
    I don't expect that R4 and R5 have the same value. Do they?
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    656
    Received: 72/0
    Given: 13/0
    13
    Adding a C to an existing R will create an RC-filter, you wanting to roll-off / reshape the bandwidth or something?
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    Why not? I would expect the circuit to have excellent self-balancing properties.
    3 Not allowed! Not allowed!
    - Own Opinions Only -
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    It have, already tested.
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    The same value is close enough. For perfect balance using a 12AX7 R5 should be about 2% bigger than R4
    Aug 2012
    Great Black Swamp
    2,364
    Received: 522/0
    Given: 1,366/1
    11
    All right, I was thinking that like a conventional paraphase, there's a voltage division. But I see this is a little different.
    I see that a voltage will develop at the node of R4 and R5 only when the voltages at the plates are not exactly equal in magnitude and opposite in phase. An error signal. But with "perfect symmetry" the voltage is zero, and then the voltage reaching the plate is zero... I still find myself wanting the resistors to be unbalanced in order to generate a drive signal to the grid that nets an ideal opposite plate voltage.
    edit: I see Dave has put a number on my vague itch. Thanks!
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    The second triode will still be driven from its cathode input, even if grid signal is zero.
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    Interesting materials about circuit
    The See-Saw circuit - A self balancing phase splitter (5).pdf
    and different ways of thinking about nfb aplication
    150_UL_6V6s (5).pdf
    Aug 2012
    Great Black Swamp
    2,364
    Received: 522/0
    Given: 1,366/1
    11
    True. But even that depends on a signal that is not balanced; if the cathode currents are opposite and equal then there's no cathode voltage deviation to drive a signal. If the grid error signal is doing its job then the cathode deviation should be minimal.
    But I confess, there are more servo loops than what I initially thought.
  12. #12
    Aug 2012
    Great Black Swamp
    2,364
    Received: 522/0
    Given: 1,366/1
    11
    I like
    And in the example, the cathode is bypassed.
  13. #13
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    That paper lost me
    I simply calculated the open loop gain (A) of a 12AX7 driving a 1M resistor and put that in the NFB equation.
    A = uRL/(RL+ra) = 100*90/(90+62) = 59
    G = A/(1+AB) where B is the feedback factor (1 in this case)
    G = 59/(1+59) = 0.98
    Closed loop gain G should be 1 for perfect balance therefore the feedback resistor should be 2% bigger.
  14. #14
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    What does simulation say? Any difference with bypassed cathode resistor?
  15. #15
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    I suspect not but I'll check it out after I get another beer
  16. #16
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    not bypassed 100mV input
    First triode 5.7V. Second triode 5.45V. Gain 57. Imbalance 4%
    Bypassed 100mV input
    First triode 5.84V. Second triode 5.56V. Gain 58. Imbalance 4.7%
    I calculated 2% imbalance. I think that's because I didn't allow for the output impedance of the first stage being much greater than the output impedance of the second stage.
    6 Not allowed! Not allowed!
    Last edited by Dave H; 08-31-2019 at 06:03 PM. Reason: 'much less' changed to 'much greater'
  17. #17
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    Interesting, thanks.
    because I didn't allow for the output impedance of the first stage being much less than the output impedance of the second stage.
    Wouldn't you expect the second stage to have the lower output impedance because of its total voltage NFB?
  18. #18
    Supporting Member
    Staffordshire UK
    3,874
    Received: 599/1
    Given: 549/2
    19
    Yes, that thought struck me too.
  19. #19
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    Thanks, you're right. I had it backwards and still didn't notice after reading it again
    I've fixed it now.
    I think the second stage output impedance would be reduced by the loop gain to something like 30k/60=500R which is negligible compared to the 1M feedback resistor. If it was 30k the same as the first stage it cancels out. There would be 30k added to the feed on resistor and 30k added to the feedback resistor so the feedback factor is still unity.
    EDIT: I ran the sim. again with the feedback resistor 5% larger (1050k) and the outputs are balanced.
  20. #20
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    "If the two triodes are really operating in push pull,the current in R3 should not contain any alternating component,and C has no decoupling function."- N.Crowhurst
  21. #21
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    More material:
    Crowhurst_Cooper_1956_High_Fidelity_Circuit_Design_text.pdf
    from p.126 and the follow
  22. #22
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    More material:
    We think we are cleaver with our computers and simulations but it's true, we are standing on the shoulders of giants. I've only just worked out that the feedback resistor needs to be 5% bigger for perfect balance but Crowhurst had done it back in 1956 with just a slide rule.
  23. #23
    Supporting Member
    Staffordshire UK
    3,874
    Received: 599/1
    Given: 549/2
    19
    When I've tinkered with both simple and floating paraphase circuits with a type 1 master vol after it, I found that if the cathode resistor was shared and unbypassed, horrid blips of parasitic oscillation were generated when it was overdriven. Of course it could have been something else but bypassing or splitting the cathodes got rid of the issue.
    Note that the Vox AC50 variants that used a paraphase had its shared cathode bypassed, also the Ampeg B15, so perhaps they noticed it too?
    https://el34world.com/charts/Schemat...Vox_ac50_1.pdf
    https://el34world.com/charts/Schemat...eg_b_15_nc.gif
  24. #24
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    Quote Originally Posted by pdf64 View Post
    I don't think so but who knows.... I have not You mentioned issue in my experiments. And think the decoupling cap is useful just to can apply the global nfb to the first section. It is a bit tricky due to the double function as bias resistor and component of voltage divider of nfb but can be done. I much prefer the Grommes solution for the moment.
  25. #25
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    With equal values resistors, not precisely balanced but didn't looks so bad.
    Of course the values should be tailored a bit...
  26. #26
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    Does someone have a good explanation of the strange asymmetrical cathodes' wiring of the PI in the Grommes circuit?
  27. #27
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    I cannot provide a good explanation, there are not, but who cares ? (meant why should be so important as time as are decoupled?). The circuit should work with separate cathode resistors as same, but think economy reasons...
  28. #28
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    And just separate the cathode and tested: it works as same, with same degree of imbalance. Think the more important think in circuit are anode resistors, the second triode should be compensate in any circumstance for precise balanced results. Nfb can be applied in the bottom of first cathode resistor in more traditional way.
    But Grommes shows very elegant simply solution
  29. #29
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
    What I found is the circuit ( in my case) support a limited amount of nfb. Over 12 db sign of instability appears. Think is more related by shifting phase and for this reason I asked at beginning of topic about. Of course think is possible to shift the pole changing the cap value but just thinking at blocking distortion opportunities...
  30. #30
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    O.K., meanwhile I understand that the asymmetrical cathodes' wiring (additional unbypassed 100 Ohm resistor at the first tubes' cathode) is necessary to allow feeding NFB only to first tube's cathode.
  31. #31
    Mar 2008
    868
    Received: 110/0
    Given: 240/0
    13
  32. #32
    Cheshire, UK
    2,335
    Received: 635/4
    Given: 328/0
    17
    It was originally designed for hi-fi. You're not supposed to overdrive it
    My guess is that in a perfect world with perfectly matched outputs which are unloaded the bypass cap isn't needed but in the real word with equal feed on/feedback resistors and 150k loads (Vox) it's better to have the capacitor.
  33. #33
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,783
    Received: 326/2
    Given: 292/0
    16
    The best way to satisfy your curiosity is to do everything you described, perform DC measurements, and attach the circuit to the signal source and oscilloscope. Its implies that you share your experience with us.
    EDIT 190902
ID:	54981 Click image for larger version.
    It work do the same, only you have two unnecessary capacitors more, whose value can affect to (low) frequency.
    From ratio R4 vs R5 will depend on the symmetrical excitation of the outputs.
  34. #34
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    Also the balancing resistors contribute to the effective PI load.
  35. #35
    Jul 2011
    Adelaide, South Oz
    751
    Received: 85/0
    Given: 4/0
    9
    The Paraphase is great in simple /minimalist circuits - easy to add a 1 knob tone control
    See the GA40 for example of this
    https://music-electronics-forum.com/...ad.php?t=49627
    Cheers,
    Ian
  1. Paraphase inverter question
    By catalin gramada in forum Theory & Design
    Last Post: 08-30-2019, 09:52 AM
  2. Paraphase inverter values
    By EFK in forum Theory & Design
    Last Post: 11-11-2011, 09:13 AM
  3. Paraphase Phase Inverter...and other things 5C3
    By EETStudent in forum Theory & Design
    Last Post: 04-20-2011, 11:34 AM
  4. Question re: paraphase inverter
    Last Post: 02-19-2011, 10:17 PM
  5. Incorperating a NFB loop into a paraphase inverter
    By anson in forum Theory & Design
    Last Post: 01-05-2010, 06:30 PM
