resistor wattage ID?
There's no way to know 100% without any other info. There are even mini resistors now that look much smaller than typical counterparts, but have the same wattage rating. That said, if you know that the one on the left is 1/2 watt, I'd be relatively certain that the one on the right is also. If in doubt, install it and monitor it for heat."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by mikepukmel View PostYeah, check out Vishay PR01 series. 2 watt resistors, tiny.If it still won't get loud enough, it's probably broken. - Steve Conner
With metal film and metal oxide resistors there can be confusion but those of carbon film (I refer to modern ones) usually maintain the proportions of physical volume and dissipation capacity.
So, if one of them is half a watt, the other should be too. The different thickness of the pins does not indicate much by itself. There is a tendency in those of Asian origin to have them thinner.
The 1-watt carbon film resistors from Tayda for example (very thin pins) should be used with caution regarding mechanical assembly. In certain applications I do not use them.
What bothers me about the little ones is that voltage rating usually is better with more surface area (edit: I mean length).
So where a small part with a high wattage rating may be fine for SS equipment, it is often not as good in high voltage applications.Last edited by g1; 09-01-2019, 11:44 PM.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
voltage rating usually is better with more surface area.- Own Opinions Only -
I should have said length instead of surface area. More distance is always better for voltage withstand ratings, even in air.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I bought some of the Vishay PR01 series 82K and 100 K for driver plate resistors but was surprised at the small size so I've never used them.
Good thing, because they're only rated at 350V whereas the regular old carbon film types are 500V.
https://music-electronics-forum.com/...1&d=1567386302
