Results 1 to 13 of 13
Thread: Blackstar Stage HT60
  1. #1
    Join Date
    Nov 2013
    Posts
    285
    Thumbs Up/Down
    Received: 113/11
    Given: 36/0
    Rep Power
    6
    Quote Originally Posted by Gonzo72 View Post
    Iím having an issue with my HT60 it keeps blowing the T3.15AL250V fuse. Having a tech look at it but we are not having any luck. Need help
    disconnect all the main PT secondaries and start powering through a bulb limiter in series
    2 Not allowed! Not allowed!
  2. #2
    Twobie
    Join Date
    Sep 2019
    Location
    Oklahoma
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Rep Power
    0
    0 Not allowed! Not allowed!
  3. #3
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,113
    Blog Entries
    1
    Thumbs Up/Down
    Received: 316/5
    Given: 208/0
    Rep Power
    10
    Okay, what have you done in the way of troubleshooting so far?
    https://music-electronics-forum.com/...8&d=1519629152
    Edit: That was weird. A minute after I posted this the whole thread was edited.
    Last edited by DrGonz78; 09-04-2019 at 09:54 PM. Reason: To express my confusion...
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    11,629
    Thumbs Up/Down
    Received: 1,544/23
    Given: 3,908/11
    Rep Power
    22
    Quote Originally Posted by DrGonz78 View Post
    Yes, very strange. How can a response be the first post?
    I may be mistaken but I think there may have been multiple threads started for the same topic, and maybe a moderator combined them but accidentally put the first response ahead of the question?
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  5. #5
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,113
    Blog Entries
    1
    Thumbs Up/Down
    Received: 316/5
    Given: 208/0
    Rep Power
    10
    The Yoda I think alexradium might be. The crew here is getting so good that they can even predict a question in advance of the op.
  6. #6
    Join Date
    Nov 2013
    Posts
    285
    Thumbs Up/Down
    Received: 113/11
    Given: 36/0
    Rep Power
    6
    Yes the original post has been moved to another section
  7. #7
    Twobie
    Join Date
    Sep 2019
    Location
    Oklahoma
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Rep Power
    0
    Thank you
  8. #8
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,250
    Thumbs Up/Down
    Received: 1,172/1
    Given: 911/1
    Rep Power
    16
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
  9. #9
    Twobie
    Join Date
    Sep 2019
    Location
    Oklahoma
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Rep Power
    0
    Changed bad resistor and cap on the circuit board where plug attaches. Also changed all tubes.
  10. #10
    Twobie
    Join Date
    Sep 2019
    Location
    Oklahoma
    Posts
    6
    Thumbs Up/Down
    Received: 0/0
    Given: 2/0
    Rep Power
    0
    What section was it moved to?
  11. #11
    Join Date
    Feb 2010
    Location
    Posts
    11,629
    Thumbs Up/Down
    Received: 1,544/23
    Given: 3,908/11
    Rep Power
    22
    I think the post at the top of this page was moved in here from your other post in another section. That other thread was removed as far as I can tell.
  12. #12
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,885
    Thumbs Up/Down
    Received: 491/3
    Given: 260/0
    Rep Power
    26
  13. #13
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,113
    Blog Entries
    1
    Thumbs Up/Down
    Received: 316/5
    Given: 208/0
    Rep Power
    10
    Did you try the recommendation giving by Alexradium??
    "disconnect all the main PT secondaries and start powering through a bulb limiter in series"
    Edit: Not that we should suspect the power transformer first but it might be easy enough to rule it out. Also running the amp through bulb limiter or monitoring current with a variac will be crucial to not blow fuses while testing. If not the transformer then try turning on with the power tubes removed, light bulb limiter connected too. At that point if it pulling too much current focus on bridge rectifier and even a faulty mains filter cap.
Thread Information
Users Browsing this Thread
  1. Blackstar HT60 bias circuit
    By Roberto Lasco in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-26-2019, 01:37 AM
  2. Blackstar HT60 soloist oops!
    By LarBal in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-03-2018, 08:05 PM
  3. Blackstar HT60 PCB leaking voltage
    By Mick Bailey in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-01-2018, 09:18 AM
  4. Blackstar Stage 60-100
    By Enzo in forum Schematic Requests
    Last Post: 06-19-2015, 12:19 AM
  5. Blackstar HT Stage 60
    By Rhodesplyr in forum Schematic Requests
    Last Post: 05-29-2012, 05:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
