Results 1 to 6 of 6
Thread: Source for 53mm 1018 'Bucker Keeper Bars?
  1. #1
    Member PoorMan's Avatar
    Join Date
    Mar 2007
    Posts
    296
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    14
    Can't find 1018 keeper bars in 53mm. Can anyone point me in the right direction?
    Thanks!
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member TomCarlos's Avatar
    Join Date
    Oct 2009
    Location
    Roseville, Ca.
    Posts
    915
    Thumbs Up/Down
    Received: 192/0
    Given: 321/0
    Rep Power
    11
    Sorry.... I am a novice in this area. I assume you are talking about something like this? PU-6947 53mm Keeper Bar
  3. #3
    Join Date
    Mar 2007
    Posts
    296
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    14
    Quote Originally Posted by TomCarlos View Post
    Yes, but in 1018 steel. All I can find is 1010 or undisclosed "mystery" metal.
  4. #4
    Supporting Member
    Join Date
    May 2006
    Location
    PDX
    Posts
    3,333
    Thumbs Up/Down
    Received: 64/0
    Given: 35/0
    Rep Power
    19
    Worth a call to allparts, someone there probably knows what these are made from or can find out for you. I think maybe Mike is the fellow who knows stuff like this but it's been a while.
    Philadelphialuthier can't get them for you?
  5. #5
    Join Date
    Mar 2007
    Posts
    296
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    14
    Quote Originally Posted by David King View Post
    I haven't had time to call around. Just browsing my usual suppliers. I did email Mojotone...they only have 1010.
    I'm curious about 12L14, but I'm not familiar with its tonal qualities. This is for an order so I'm not in a position to experiment.
  6. #6
    Join Date
    May 2006
    Posts
    834
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Rep Power
    15
    You can just make your own. All you need is some 1018 steel bars from Online Metals or elsewhere*, a miter saw or bandsaw to cut to length, and a drill press. Use an existing 53mm keeper as a template (you will need to "widen" it to the 1/4" with a piece of wood, plastic strip, or tape, whatever works -- see below for why) to make your first one, then use this first as your permanent template.
    *I just use 1/4" wide 1/8" deep bars. Yes, the holes are little off to one side because it's wider but it will fit, though you may need to shave one corner down a bit to allow the lead to fit through the lead hole, especially with 4-conductor. Naturally if you can get some 1018 bars the same width as a traditional keeper, that would be easier, but I wasn't able to find any so I just got used to the 1/4".
Thread Information
Users Browsing this Thread
  1. Source for Quality Bucker Keeper Bars? 49.2mm
    By PoorMan in forum Pickup Makers
    Last Post: 09-13-2019, 08:32 PM
  2. Looking for a source to get some custom Keeper bars made ?
    By copperheadroads in forum Pickup Makers
    Last Post: 03-27-2019, 04:43 PM
  3. Humbucker Keeper Bars
    By belwar in forum Pickup Makers
    Last Post: 06-13-2010, 09:51 PM
  4. P90 keeper bars - yay or nay?
    By Meowy in forum Pickup Makers
    Last Post: 02-06-2008, 04:02 AM
  5. Are keeper bars 1018 or 1022?
    By kevinT in forum Pickup Makers
    Last Post: 03-31-2007, 03:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
