Results 1 to 16 of 16
Thread: Vintage cap voltage rating question
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    2,227
    Blog Entries
    1
    Received: 402/5
    Given: 307/0
    11
    So I ordered a 25uf 50v cap as that's what I read on it before pulling it out. Pulled it out and it actually reads 25uf 50/60v. So my guess is that it's a 50v rated working voltage cap with a 60v peak rating. Does that seem correct? Not too worried about really, just curious for educational reasons. The cap was found in an old Fender Taurus solid state amp.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,435
    Received: 3,070/5
    Given: 3,709/0
    32
    That seems like an odd way to indicate voltage rating.?. AC/DC maybe?
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    That is correct.
    - Own Opinions Only -
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Yes.
    The higher value is called "surge" voltage, whatever it can stand for a few minutes.
    Significative in Tube amps, since until filaments heat up supply voltages peak/surge significantly higher, irrelevant in SS amps, so it was dropped.
    Old Timer
    Chill-Ville, VA
    3,455
    Received: 856/6
    Given: 1,762/10
    19
    Also helpful for those times you are testing an amp without tubes installed, no?
    Justin
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Yes, same thing.
    But in general mopern caps do not even show it, although I guess it´s still in the datasheets.
    Now WHO reads a capacitor datasheet is another problem
    May 2007
    pacific north west
    16,435
    Received: 3,070/5
    Given: 3,709/0
    32
    Well "I" do because I don't just build, I design. So things like surge voltage matter to me. Guys that build often use caps that some reputable source has already determined the suitability of for tube amps in general. The number of amps getting built with over 550V of unloaded voltage is pretty small I think. It comes up here with certain models that are sort of known by this community to have special needs. Otherwise, not so much. But I think you might be heartened by the number of members here that actually DO check out spec sheets when it seems appropriate.
    2 Not allowed! Not allowed!
    Sep 2011
    Pace, FL
    3,630
    Received: 1,317/102
    Given: 183/36
    12
    I bet chuck reads datasheets while eating his Rice Crispies
    nosaj
    Oct 2011
    Scottsdale, AZ
    2,227
    Blog Entries
    1
    Received: 402/5
    Given: 307/0
    11
    Thanks for the responses!! All of the small eletros had spewed their guts out all over the place.
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Quote Originally Posted by DrGonz78 View Post
    Can you spell m-e-s-s-y ?
    I know, I know
    Here? sure!!!!
    But this is an above average Forum ... and that is an understatement
    May 2007
    pacific north west
    16,435
    Received: 3,070/5
    Given: 3,709/0
    32
    I do have horse blinders on, I suppose, because I'm not an active member of any other forums. In my head this place represents "the rest" of the demographic in this amp genre that isn't me. I'm familiar enough with the gear forums that I have perused. Specialized forums for Marshall owners or Les Paul owners. I always take those forums to be more "gear head" rather than gear build places. So I don't expect much going in. And I've read enough good tech at places like the Amp Garage and the old AX87 site that I just figured it was all like it is here, though I knew this was the best of them. Still... It's hard to imagine the number of shade tree techs that are still operating low tech on mojo based lore while this forum exists. But I do know it's still happening.
    1 Not allowed! Not allowed!
  12. #12
    May 2007
    pacific north west
    16,435
    Received: 3,070/5
    Given: 3,709/0
    32
    Eewww! I've only had to clean up after that sort of thing twice. Such a smelly mess. And you will never think you got it clean enough Still beats having them go off like little fire crackers or dead shorting and taking out more expensive components I suppose.
  13. #13
    May 2010
    Sioux Falls, SD
    6,905
    Received: 1,682/2
    Given: 1,210/1
    18
    Smell is actually a good troubleshooting tool. If you've done this for long enough, you can distinguish between leaky caps, burnt transformers, carbon resistors, solid state devices, etc.
    It's still never a good sign when a bad smell is emanating from an electronic device.
    Edit: I forgot selenium rectifier on my list of smells.
  14. #14
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,433
    Received: 2,519/7
    57
    Oh, AMEN.
    NOTHING smells like burnt selenium rectifier. And even after 50 years, I would recognize it instantly.
    Burnt resistors smell different from burnt plastic transistors. Caps smell different. Transformers have their own smell. Burnt circuit board smells different too. Yes, by experience, you usually know what burnt up by the aroma.
  15. #15
    Oct 2011
    Scottsdale, AZ
    2,227
    Blog Entries
    1
    Received: 402/5
    Given: 307/0
    11
    You know what the amp didn't actually smell bad. The amp had that 60's Fender tube amp smell to it, even though it is a solid state amp. I think they could package that scent and a bunch of vintage amp loving techs would buy it off the shelves.
  16. #16
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    I know that smell very well, and here it means "US made amp" whenever you go to a rehearsal room.
    After some time, I found it´s some kind of evil chemical added to animal/hide glue used by Fender (and many others) in their Potdevin gluing machines to Tolex amps.
    Otherwise such organic stuff rots or grows mold easily.
    The product is actually a milder version of Morgue approved Formaline or embalming fluid.
    There´s a similar smell coming from old Russian Cameras, which had thin leather covered parts using a similar glue.
  1. help with resistor voltage rating
    By mikepukmel in forum Build Your Amp
    Last Post: 04-02-2017, 02:11 AM
  2. Wire Voltage Rating
    By big_teee in forum Build Your Amp
    Last Post: 06-28-2016, 08:24 AM
  3. Carvin BX250 micro bass capacitor voltage rating question
    By DrGonz78 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-05-2016, 10:20 PM
  4. Cap Voltage rating for 1/2-wave voltage doubler - question
    By tubeswell in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-16-2011, 07:42 PM
  5. Capacitor Voltage rating Question
    By crunchman in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-13-2010, 04:16 PM
