Results 1 to 9 of 9
Thread: The Lion Tamer
    Dec 2008
    Wernersville, PA
    13,098
    Received: 624/3
    Given: 328/0
    28
    The Lion Tamer
    Has anyone any experience with this little widget?
    Name:  Lion Tamer.jpg
    https://www.ebay.com/itm/Fender-Hot-...MAAOSwJtdaN9mr
    It appears to go in the Fx loop Send Return jacks.
    1 Not allowed! Not allowed!
    Professional Lurker eschertron's Avatar
    Aug 2012
    Great Black Swamp
    2,364
    Received: 522/0
    Given: 1,366/1
    11
    I've never seen one,but the fact that it sits on the front panel of the amp gives it some appeal
    Old Timer
    Chill-Ville, VA
    3,455
    Received: 856/6
    Given: 1,762/10
    19
    Never used one because my amps don't have FX loops, but a ton of guys in a FB group I mod have used them. They all seem to rave over them, as the BWST THING TO EVER HAPPEN FOR YOUR HOT ROD DEVILLE! Yes, they are that enthusiastic... Personally I'd make it myself...
    I haven't checked a schematic to see what parts of the circuit it affects, but it's cheap enough & doesn't hurt anything so, whatever. Reminds me more of the Ice Cube, probably more "effective" though. I don't know of anyone who uses a volume pedal in the FX loop; I would think thatsa more "useful" variation on this theme, as it is adjustable from the rest of my pedal board (if I had one).
    Justin
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Is it a pot in the effects loop?
    Not exactly rediscovering the wheel.
    2 Not allowed! Not allowed!
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,682/2
    Given: 1,210/1
    18
    I haven't used one, but it looks simple, effective, and you don't even have to take the amp apart.
    Feb 2010
    12,612
    Received: 2,172/24
    Given: 5,478/11
    24
    Should be good demand for this. Nobody likes the dirty channel in those hot rod amps, and the taper of the clean volume pot is too twitchy.
    Lots of guys looking for a simple solution, and you won't find anybody that will swap out the clean vol. pot for 25 bucks.
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,682/2
    Given: 1,210/1
    18
    I've often thought of doing this out to a footpedal- pot and footswitch to bypass the pot. You could then use the switch to boost solos or cut rhythms, depending on your perspective.
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,651
    Received: 639/0
    Given: 113/0
    10
    I think that is a cool as sh*t idea! I hope he sells a million of them. Why didn't I think of that?
    Jun 2006
    289
    Received: 16/0
    Given: 2/0
    14
    All this because of Fender’s epic design fail - using a linear taper master volume pot...
  1. Replies: 0
    Last Post: 11-20-2011, 07:42 AM
  2. 12AU7 as tamer reverb driver in BF amps
    By tubeswell in forum Theory & Design
    Last Post: 03-05-2011, 05:04 PM
  3. Red Lion Cub3/3r counters on ebay
    By David King in forum Tools and Coil Winding Gear
    Last Post: 03-03-2007, 03:41 PM
  4. FS: Red Lion Cub5 Counter + Proximity Sensor
    By Pep in forum Pickup Makers
    Last Post: 12-21-2006, 08:02 PM
  5. Kendrick Lion VII
    By TD_Madden in forum Kit Amps
    Last Post: 08-22-2006, 09:53 PM
