Originally posted by tepsamps
View Post
Rickenbacker 4001 build : need advise
Originally posted by glebert View PostIf you use a brass nut or zero fret the strings will have a metal connection to each other, so only one ground wire (to one of the saddles) needed. Could also put a metal plate underneath the saddles.
Originally posted by David King View PostThere is no tailpiece so saddles must be individually grounded or you can use a brass nut or a zero fret.Logic is an organized way of going wrong with confidence
So i started over, i follow a plan that i bought, and now i'm facing different problems.
The main one, is that the action is too high, more than 3 mm, almost 4 at the 12th, though i used a rickenbacker bridge and the bridge nut is at the lowest.
I used a 7 mm thick fretboard while on the schematic they use a 6mm one. The neck through does that the fretboard is at the same level than the body and the rick bridge is a little deep inside the body, so the bridge nut is lower than in other guitars, but it's too high. Should i make a notch into the saddles ?
Second, it's the first time i use a 4 knobs configuration with 2 pickups. It's not clear, but it seems that with the selector in the middle, when i turn off the volume of the bridge PU, the sound is off, while it should remain the neck PU. And the bridge tonality at the min cuts the sound too. Weird...
I followed this schematic : https://guitarelectronics.com/2-humb...ries-parallel/
though i have a single coil for the neck and a humbucker for the bridge.
Originally posted by tepsamps View PostSecond, it's the first time i use a 4 knobs configuration with 2 pickups. It's not clear, but it seems that with the selector in the middle, when i turn off the volume of the bridge PU, the sound is off, while it should remain the neck PU.
Originally posted by tepsamps View PostYes the neck is straight, i think that i have to berry the entire bridge 3 mm deep, but it's not easy to do it clean, very risky!!!
If you don't know where your going any road'll take you there : George Harrison
Originally posted by Helmholtz View PostProbably not: Neck through body construction.If you don't know where your going any road'll take you there : George Harrison
I played with my router and the result is very clean, i'm surprised.
The bass is almost ok, i had forgotten how bassy it is, only one octave lower but it's low!
The pickups are powerfull, i had to lower the gain on the clean channel (i use a guitar amp) to have a clean tone.
I post a pic as soon as i get my phone back.
Very instructive built, but neck through is too tricky for me, and the pickguard seems mandatory, with my tools at least.
Did you lower the bridge? I was having a bit of trouble following some of the description and understanding if the action was high everywhere (like up at the 1st fret) or if it was OK there and got higher as you went towards the bridge.
Originally posted by glebert View PostDid you lower the bridge? I was having a bit of trouble following some of the description and understanding if the action was high everywhere (like up at the 1st fret) or if it was OK there and got higher as you went towards the bridge.
Nut height is always cut down to make the action at the 1st fret acceptable, so that sounds like a normal thing.Last edited by glebert; 11-04-2019, 12:56 PM.
