Results 1 to 13 of 13
Thread: Kustom K6320 PA head
    Aug 2018
    Portland, Maine
    52
    Received: 15/0
    2
    Hi,
    I own a Kustom model K6320 PA head with a noisy reverb. I suspect a noisy transistor in that circuit. I have searched the internet for a schematic, and come up with nothing! Can any of you supply me with a schematic? Thanks.
    John
Name:	My Kustom PA head 02.JPG
ID:	55178   Click image for larger version.
Name:	My Kustom PA head 01.JPG
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,496
    Received: 2,543/7
    57
    I would start by calling the company and asking if they can provide it.
    https://www.kustom.com/contact-us
    Feb 2010
    12,654
    Received: 2,189/24
    Given: 5,521/11
    24
    Get the board number and check here: https://music-electronics-forum.com/...ad.php?t=34637
    33,496
    Received: 2,543/7
    57
    I could be wrong, but I think this is latter day Kustom, the reborn company, not from the old tuck-n-roll days.
    1 Not allowed! Not allowed!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    I guess only link between new and old Kustom is the logo ... and not much of that either.
    And modern one is not much American designed, they are "very korean", including car stereo and minicomponent style "graphic EQ in a single chip", Sanken/Sanyo power modules, KA**** ICs, etc.
    33,496
    Received: 2,543/7
    57
    They resurrected the Kustom name, product has nothing to do with the original stuff.
    WHen they came along, I signed on as a warranty station, but in the five years before renewal of status, I never got so much as a single customer from it. I guess they did not have strong sales in my area of the country. They hired James Brown away from Peavey to design some guitar amps, don't recall the results of that. He has moved on since then.
    Aug 2018
    Portland, Maine
    52
    Received: 15/0
    2
    Thanks for your thoughts. I have owned and gigged with this amp for many years, and has served me very well. For my purposes, six channels has always been more than sufficient, and I like to simplicity if this PA head. Anyone in the band can walk up to it, and use it within a minute, so easy to use. I may just end up trying to fix the reverb without a schematic, using a can of freeze spray to pinpoint the faulty transistor......however, a schematic is something I have always had a desire to obtain for any future repairs.
    Aug 2018
    Portland, Maine
    52
    Received: 15/0
    2
    Another thought....as you can see in the photo, I have cables plugged into the pre out / main in jacks. They go to an external digital reverb unit. So, for now I do have reverb, but I have never found a digital reverb unit that sounds right. The internal spring unit is far superior, in my opinion, so there is a strong desire to get that working again. A schematic, anyone???
    33,496
    Received: 2,543/7
    57
    Seriously, did you call Kustom and ask?
    Aug 2018
    Portland, Maine
    52
    Received: 15/0
    2
    Enzo, Yes, I did contact Kustom. They have little if any documentation dating back as far as this unit, so no help there.
    Oct 2007
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Ok, now we only have Plan B left.
    Go to reverb return jack (is it connected through RCA jacks or straight plugged into PCB?) and follow the track leaving it, it should lead you to a coupling capacitor which will then lead to a transistor base or an IC leg.
    Please identify such active element and take a closeup picture showing its surroundings.
    If an IC, which I suspect, which pin is used as input?
    Almost forgot: define "noisy reverb" , even better upload some MP3 or video.
    is pulled out of the blue and does not mean much.
  12. #12
    33,496
    Received: 2,543/7
    57
    I dug my new-era Kustom files out of storage tonight. I have docs on the KPM6160, which is like yours but mono. That is from about 1999. But nothing on your model. I suspect yours is somewhat newer than 1999.
    meanwhile, if you want to FIX it, isolate the problem. Is the noise on the return side or the drive side? Does the noise turn up and down with the reverb control? UNplug the drive cable from the reverb unit. Still noisy?
  13. #13
    Aug 2018
    Portland, Maine
    52
    Received: 15/0
    2
    Enzo, JM, Thanks for your continued thoughts. I have decided to simply recap the main board which includes all the reverb circuitry. As old as this unit is, I figured why not, and it may solve my problem. There aren't that many caps, and new caps are cheap enough. It shouldn't take but an hour or so. I'll let you all know the result. By the way, at this point, the situation has gotten worse...the reverb is now completely dead...all other functions work. Caps are on order, and I should have them any day now.
  1. Kustom IV Bass Head Schematics?
    By Corona Blue in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-07-2017, 01:50 AM
  2. Kustom K200B-4 amp head
    By Montey in forum Theory & Design
    Last Post: 09-26-2016, 10:13 PM
  3. Kustom Kasino Fever guitar amp head and cab.
    By Ballzach in forum Guitar Amps
    Last Post: 08-27-2016, 01:55 AM
  4. Kustom Profile one 100w PA head help!
    By Bruce / Mission Amps in forum Music Electronics
    Last Post: 01-07-2011, 10:40 PM
  5. New Kustom KPM4200TNR PA Head
    By jessadr in forum Schematic Requests
    Last Post: 11-25-2009, 01:01 AM
