Results 1 to 8 of 8
Thread: Fender 68 prri
    Aug 2007
    Richmond, VA
    173
    Received: 12/0
    Given: 7/0
    13
    Fender 68 prri
    v4 pin 6 is this cathodyne phase inverter supposed to chop off the top of the wave form on the positive side? it doesnt do it to the negative side. seems odd to me and I dont see a lot of these. It also chops off the neg bottom of the waveform on pin 8
    Aug 2007
    Richmond, VA
    173
    Received: 12/0
    Given: 7/0
    13
    This guy has a this exact circuit described. Everything seems normal except my grid measures 21V not 55V (meter error??) https://www.tdpri.com/threads/fender...erters.755580/
    Aug 2007
    Richmond, VA
    173
    Received: 12/0
    Given: 7/0
    13
    I guess this IS normal for this design, so never mind. https://www.youtube.com/watch?v=IjAVqBRT92g
    1 Not allowed! Not allowed!
    Jul 2011
    Adelaide, South Oz
    750
    Received: 85/0
    Given: 4/0
    9
    The Wiz covers the Cathodyne Phase Splitter pretty well.
    http://www.valvewizard.co.uk/cathodyne.html
    It is Not a good choice for amps where the power amp is going to be overdriven although there are things which can be done to improve it.
    21V on the grid is NOT good - is the correct tube fitted? Has the circuit been modified?.
    The cathode should sit at 1/4 to 1/5 of B+ and the grid will then sit at a few volts (the bias volts level) below that.
    Cheers,
    Ian
    Aug 2007
    Richmond, VA
    173
    Received: 12/0
    Given: 7/0
    13
    Thanks for your input. I will read into this more and look forward to what the next PRRI will measure. The amp actually sounds really good after correcting some minor stuff and customer is happy with it so I guess thats what truly matters.
    Cheshire, UK
    2,229
    Received: 536/4
    Given: 285/0
    16
    Quote Originally Posted by clintronics View Post
    I've noticed that measuring the high impedance grid of an LTP or cathodyne often give a wrong reading. If you measure the cathode voltage it will probably be OK (55V)
    Supporting Member
    Staffordshire UK
    3,767
    Received: 514/1
    Given: 468/2
    18
    Yes, the resistance of the volt meter will form a potential divider with the 1M grid leak resistor and draw current through it, pulling the grid voltage down whilst it’s being measure thus. Evidence of that will be a thump from the speaker, and a second volt meter will reveal that the cathode and anode voltages change.
    To correctly measure the grid voltage of such an arrangement, measure the voltage to 0V at the other end of the grid leak, then measure the voltage across the grid leak, and then add those together.
    Generally there’s only a few mV across the grid leak, so only the 1st measurement (0V to the ‘non grid’ end of the grid leak) is necessary.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,017
    Received: 1,813/7
    55
    We have discussed this elsewhere. Your meter loads teh grid voltage so it appears low. The thing to do is measure the cathode voltage, then measure voltage from cathode to grid.
  1. PRRI: Rewiring reverb send/return & verb/trem footswitch to original layout???
    By Clear Guy in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-23-2016, 09:54 PM
  2. '65 PRRI
    By dtjacob in forum Mods & Tweaks
    Last Post: 10-13-2010, 11:32 PM
  3. Installing an TO20 OT in a PRRI.....
    By Jared Purdy in forum Guitar Amps
    Last Post: 08-08-2010, 12:33 AM
  4. PCB Board PRRI
    By FFM in forum Mods & Tweaks
    Last Post: 04-16-2009, 12:46 PM
  5. Fender deluxe 90 prob....any fender techs?
    By daz in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-13-2008, 09:04 PM
