Results 1 to 14 of 14
Thread: Carvin Nomad 112 Issues
  1. #1
    Supporting Member
    Join Date
    Jul 2019
    Location
    Sacramento, California
    Posts
    84
    Thumbs Up/Down
    Received: 9/0
    Given: 4/0
    Rep Power
    0
    I'm working on my first Nomad and have some questions. I put all new tubes in today and set the bias at 75mA. Vp on the 5 preamp tubes are all 15-20% lower than the schematic values. Voltages in the power supply are also lower, which probably explains the low Vp on the preamp tubes.There are 5 22uf caps in the power supply (C40-C44) but I can not locate C42, C43 or C44 on the board. There is a C83 & C84 but they're not on the schematic, lol. All are 22uf but C40 & C41 are 2200. What am I'm missing here?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	55270   Click image for larger version.
    Attached Files Attached Files
    0 Not allowed! Not allowed!
  2. #2
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,031
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    Nothing. They used the same board for more than one model, certain parts differences would be for that. Like C81,82 are in the same spots as C40,41, but the "missing" parts were axial leaded and would lie flat in place of the vertical (radial) C40,41. I would assume what is in there is correct as made, even if not matching the drawing.
    I don't worry if the whole thing has lower voltage. But I must ask, are you using a light bulb limiter? If so, that explains your low voltages.
  3. #3
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,325
    Thumbs Up/Down
    Received: 1,220/1
    Given: 950/1
    Rep Power
    16
    I believe there are different revisions of that amp. My guess is that your schematic is not the correct revision. Is there something you're trying to fix? "If it ain't broke, don't fix it."
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    11,754
    Thumbs Up/Down
    Received: 1,613/23
    Given: 4,128/11
    Rep Power
    22
    You set bias for total current through standby switch?
    That is what they specify.
    If you set for 75mA idle current at power tube, it would certainly pull down all the voltages.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  5. #5
    Join Date
    Nov 2013
    Posts
    303
    Thumbs Up/Down
    Received: 117/11
    Given: 38/0
    Rep Power
    6
    Quote Originally Posted by Perkinsman View Post
    the power section on that schematic is the exact same of the 100w models MTS and legacy,i bet its less voltage in reality,more like 350/400V on B+ which is more appropriate for el84s,,that explains why the caps have different numberings
  6. #6
    Supporting Member
    Join Date
    Jul 2019
    Location
    Posts
    84
    Thumbs Up/Down
    Received: 9/0
    Given: 4/0
    Rep Power
    0
    Quote Originally Posted by g1 View Post
    Yes, I did bias thru standby but that is a good point.
  7. #7
    Supporting Member
    Join Date
    Jul 2019
    Location
    Posts
    84
    Thumbs Up/Down
    Received: 9/0
    Given: 4/0
    Rep Power
    0
    Quote Originally Posted by The Dude View Post
    Possible but every revision I saw had the same higher voltages and the same power supply.
  8. #8
    Join Date
    Feb 2010
    Location
    Posts
    11,754
    Thumbs Up/Down
    Received: 1,613/23
    Given: 4,128/11
    Rep Power
    22
    Is heater voltage also low?
  9. #9
    Supporting Member
    Join Date
    Jul 2019
    Location
    Posts
    84
    Thumbs Up/Down
    Received: 9/0
    Given: 4/0
    Rep Power
    0
    Quote Originally Posted by Enzo View Post
    Thanks Enzo, I’m glad to learn this. I don’t use a bulb limiter but my isolation variable transformer has a current meter. Doesn’t that accomplish the same thing?
  10. #10
    Join Date
    May 2006
    Location
    Posts
    32,031
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    I myself use a variac and amp meter for testing, but that misses the point. Many people use the bulb, and when you do, all the voltages in the amp wind up low. SO that is why I asked.
  11. #11
    Join Date
    Feb 2010
    Location
    Posts
    11,754
    Thumbs Up/Down
    Received: 1,613/23
    Given: 4,128/11
    Rep Power
    22
    What is the AC voltage at the actual primary leads of the power transformer?
    What is the heater voltage?
  12. #12
    Supporting Member
    Join Date
    Jul 2019
    Location
    Posts
    84
    Thumbs Up/Down
    Received: 9/0
    Given: 4/0
    Rep Power
    0
    I understood what you were asking...I went off point a little because I was hoping you would explain why using a variac with separate voltage & current meters isn't as effective as using the variac and limiter.
  13. #13
    Join Date
    May 2006
    Location
    Posts
    32,031
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    The bulb limiter is something effective and protects the amp. It is easily made with stuff anyone has at little expense. One can make one in fifteen minutes or less. No extra meters to buy or wire up. The bulb limits the current through the amp under load, especially fault mode loads. That said, I don't have one myself. But when we see the need, we can ask a guy to make and use one so we can continue. We could tell him to buy a variac and meters, and wait for them to arrive, sure, but then we have to put the repair on hold. The bulb is automatic, can't accidentally turn it on full as one could with the variac.
    The variac requires discipline, I start to turn up my variac, and if current starts to ramp at even 20 volts, that means trouble and back off. yet time after time, guys write in here telling us they could get their variac up to 90 volts before something starts smoking. The variac is not a contest to see how high it can get, it is a tool to indicate trouble. But many people use it that way. It is easy to use a variac wrong, the bulb is hard to abuse. Well I suppose one could use a 500 watt bulb instead of something more useful.
    And a guy with neither bulb or variac is usually not that advanced a technician, and the bulb is easier to interpret, at least for a novice.
    I don't believe I said that. I only asked if you were using the bulb, as many many do, because you reported low voltages, and that would be a common reason for it.
  14. #14
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,133
    Blog Entries
    1
    Thumbs Up/Down
    Received: 336/5
    Given: 230/0
    Rep Power
    11
    For me when I work on solid state amps I reach for the light bulb limiter. The idea of checking voltages even when there is a short somewhere feels empowering. A light bulb limiter is like a condom, easy to use and it does one thing. Honestly I don't use the lightbulb limiter on tube amps and just use variac with ammeter. I think it's good to have both.
    G1 had a good question that has not been answered about voltage readings.
Thread Information
Users Browsing this Thread
  1. Carvin SX100 DSP, a mystery even Carvin couldn't solve...
    By Libertylover in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-26-2019, 04:01 PM
  2. Carvin Belair/Nomad/VT50 circuit design question?
    By sjturbo in forum Theory & Design
    Last Post: 03-09-2016, 05:02 PM
  3. Mesa Nomad 55
    By goldtop5 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-21-2015, 07:00 PM
  4. 1952 Carvin amp - power transformer issues
    By Resonator Guy in forum Repair and Restoration
    Last Post: 09-28-2013, 01:49 AM
  5. Carvin X-amp with footswitch issues
    By Mr Johnny Birchwood in forum Music Electronics
    Last Post: 05-16-2013, 03:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
