Peavey transistor ID
I just went through this working on a Special 150! Enzo straightened me out and pointed to this:
http://matthieu.benoit.free.fr/cross...stor_Cross.pdf
However, I don't see 5951 in the chart.
Originally posted by Bill Moore View PostI just went through this working on a Special 150! Enzo straightened me out and pointed to this:
Here is a 2N5951 for sell...
https://www.jameco.com/z/2N5951-Majo...ulk_38527.html
Mind you though that I believe the pin out on these are different than the original ones that are listed in Peavey guide. Peavey has pin out as G-D-S and the fairchild data sheet on this web page above has it as G-S-D. Perhaps all modern replacements will have pin out variations from the original and you will have to bend the legs around to make it fit the design of the amp.
edit: I think the J-111 would work but all the legs of the pin out would need to be bent around into configuration.When the going gets weird... The weird turn pro!
