Results 1 to 14 of 14
Thread: Crate gx-15r - A buzz together with clean sound
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Hello everyone
    Needing help with my Crate gx-15r. It is s making a small buzz together with the clean sound, like a small fuzz. I love the clean sound of this amp, but now it is making me crazy, I have clean all the pots and the circuit board with alcohol isopropyl and also with a cleaner spray for contacts. Could anyone help me with this. Thanks in advance, and there's maybe some mistakes on my english write, sorry about that
    Luis Medeiros
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,461
    Received: 2,015/7
    55
    Is this a noise that ONLY occurs when you play notes? Or does it sit there making this hum all the time it is turned on?
    If it only occurs while playing, then it suggests a speaker with a rubbing voice coil. Also possible are a cabinet buzz - something is loose and rattles.
    If the buzz is more a hum - sounds like when you touch your guitar cord - then it is electrical. Could be as simple as a loose ground, or could be a problem with the power supply, like a failed filter cap.
    Nov 2013
    318
    Received: 124/11
    Given: 40/0
    7
    If the amp has also a distorted channel always running and just switched out,it can be radiated on top of the clean,in general it should be grounded at some point.
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Hi thanks for your interest and support, the buzz happens only when playing, I ve try allready connected to another speaker wlth the same bad result. The sound seems like I had together the distrocion sound connected in a very low volume. When I don't play even with the guitar connected it doesn't make any open audible noise. Guitar is an used cheap ibanez gio
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Quote Originally Posted by alexradium View Post
    Hi thanks, it could be, do you know how I can found that source of distortion, that "shunt" and grounded properly or mute it, even I have to neutralize the distorced channel since I don't use it anyway. Hope you can help
    Luis Medeiros
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    If somebody posts the schematic I might find a way to add some extra muting to dirty channel when "Off".
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    2,172
    Blog Entries
    1
    Received: 364/5
    Given: 262/0
    11
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Sir I found the schematic going below thanks for your help
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Schematic Crate GX-15R
    Quote Originally Posted by Medeiros View Post
    http://music-electronics-forum.com/a...64-24701c4.pdf
    posted by The Dude
    http://music-electronics-forum.com/attachments/5546d1245133564-24701c4.pdf
    Last edited by Medeiros; 09-23-2019 at 10:12 PM. Reason: Complete the link of schematic
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Thanks Dr.Gonz78
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Quote Originally Posted by DrGonz78 View Post
    [QUOTE=Medeiros;539758]http://music-electronics-forum.com/a...64-24701c4.pdf
    posted by The Dude
  12. #12
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Thank you sir
  13. #13
    Oct 2007
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Just checked the schematic.
    Sadly,in this quite simplified amplifier, switching is not electronic (Fets or transistors) but the simplest mechanical, a plain push switch, thatīs why this amp does not have a footswitch.
    I suggest you set P1: "Gain" to 0, do you still have the background buzz?
    Because in that position IC1 pins 7 to 6 gets shorted and that Op Amp section gets fully muted.
    Try it and post results.
    If not enough, I can suggest a more drastic lobotomy which mutes it even more, requires desoldering a couple components and you should add a small switch at front or back panel to enable/disable it.
    But letīs try the above suggestion first.
  14. #14
    Twobie
    Sep 2019
    11
    Received: 2/0
    0
    Step one without mutilating
    Results, I turn gain and level to zero.
    No it sounds good, I thought I've try it before, but of course not,... So sir I really appreciate your help, and all the others advises and detailed lessons from you and the others in this forum thread . Late night I'll be practicing my very very hard Hey bi Jimi, clean loud with reverb. Wish you all the best
    2 Not allowed! Not allowed!
  1. horrible buzz/noise/hum on a crate gx15
    By Andres in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-23-2019, 01:50 AM
  2. Crate FXt65 cuts out on clean channel only
    By groovyfingers in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-06-2016, 04:17 AM
  3. TSL Clean Channel Buzz
    By PaoloJM in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-02-2010, 08:21 AM
  4. 5e3 Clean Sound
    By BluesDude in forum Tweed Builders
    Last Post: 01-27-2010, 05:32 PM
  5. Crate Glx212 Buzz
    By MickeyB in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-19-2007, 02:02 PM
