Results 1 to 7 of 7
Thread: Test Gear Maintenance: LCD Display Issues on Analogic 2030 Multifunction Waveform Synthesizer
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    2,108
    Received: 786/1
    Given: 1,913/1
    13
    I have this unique Analogic 2030 Waveform Synthesizer which has a large LCD screen on it's front panel which has horizontal lines across it that don't belong. This is the last of the three units I had owned, having repaired and sold the other two back in 2011 & 2012, keeping this one, having finally succeeded in repairing the power supply. The instrument IS functional......just has these unwanted horizontal lines appearing on the screen and thus far, I don't know if this is a permanent defect in the display, or if it's from the controlling circuitry or even connections. When I was first investigating this, I still had one of the one other instruments, and swapping screens, the problem moved with the front panel / screen PCB assembly. That may rule out interconnects, as far as two instruments were concerned. Still could be connector issues on the defective screen assembly.
    Anyone out there with experience on troubleshooting LCD screens like this? I do have the service manual, though the reproduction quality is pretty poor. Analogic hasn't been in the Instrumentation business now for a good 10 yrs or more, so no replacement parts available nor factory support.
Name:	2030A with Display defects (horizontal lines)-1.jpg
ID:	55290 Click image for larger version.
Name:	2030A with Display defects (horizontal lines)-2.jpg
ID:	55291 Click image for larger version.
Name:	2030A 50Hz 45 Deg Phase Mod 4Hz rate Output-1.jpg
ID:	55292 Click image for larger version.
    I had dialed up a Phase Modulation waveform, using 50Hz @ 1V RMS (1.414V Pk), with 45 deg Phase modulation at a 4Hz rate. Scope photo shows the modulation character. The last image shows what the LCD Display should look like....this one being from one of the other instruments I had sold.
Name:	FTLV-Open for Svc.jpg
ID:	55294 Click image for larger version.
Name:	FV-Open for Svc.jpg
ID:	55295 Click image for larger version.
Name:	FTRV-Open for Svc.jpg
    Analogic _2030_Data Sheet.pdf
    Supporting Member
    Aug 2017
    Portland, OR
    869
    Received: 318/1
    Given: 134/2
    3
    Does it have an actual connector on the LCD, or is it more of a permanent connection? I remember on a Saab my wife had the display for the radio had lines like this, and it was a known issue that would happen to those cars. They had used a kind of thermal formed foam to push the ribbon cable against the board, and it would shrink over time and some lines would be lost. IIRC the fix was to use a heat gun to soften the foam and push it down until is rehardened, but there was a chance of loosing the whole display so I never did it.
    Apr 2010
    Burbank, CA
    2,108
    Received: 786/1
    Given: 1,913/1
    13
    Quote Originally Posted by glebert View Post
    There are two ribbon cables. I haven't been inside it since late 2012, so kind of starting over. On one of the other displays, I had replaced the eight 4.7uF/35V radial electrolytic caps laid over on their sides, and have that task yet to do. I'll have a closer look once I pull this apart again. I do see twist-tabs used to hold the top PCB assembly into place, so there may well be some friction-held connections in this assembly. I've had this powered up for a couple hours, and during that period, the display has cleaned up a little bit, though the upper blue line is still solidly in place where there shouldn't be anything.
Name:	FP-Display Assy-1.jpg
ID:	55298 Click image for larger version.
Name:	FP-Display Assy-2.jpg
ID:	55299 Click image for larger version.
Name:	FP-Display Assy-3.jpg
ID:	55300 Click image for larger version.
Name:	FP-Display Assy-4.jpg
    Feb 2010
    12,633
    Received: 2,184/24
    Given: 5,497/11
    24
    No elastomers or 'zebra strips' between the display and board, like is often used for DMM displays?
    Apr 2010
    Burbank, CA
    2,108
    Received: 786/1
    Given: 1,913/1
    13
    I don't know yet......I left off at replacing the eight tiny 4.7uF/35V electrolytic caps on that top display PCB assy. All of those original parts had corrosion on their leads, with one having puked white stuff onto the solder pad. I debated at that time to untwist the metal tabs around the perimeter of the PCB and carefully lift off the board. I do see a foam liner around what looks like cushioning for the glass housing. The schematic lists this display as florescent, and it has 225VAC applied to it. I ended up NOT opening the tabs and digging deeper at that time, and checked to see if anything changed after replacing those caps. Didn't change the display defects...the lines are still present. I set it aside for the moment, as more paying work came in. Always something to interrupt fun time. So, I'm not yet thru digging for a solution. Just hope opening it up doesn't screw the pooch.
    Thanks for the suggestion.....I've seen that zebra strip on both the Fluke 8060A displays as well as on my HP 41CV calculator.
    Digging further thru the service manual, all of their 'troubleshooting' guides suggested was replacing complete PCB assemblies. Typical. Turns out there isn't any documents/drawings for the Display PCB assy at all. I was able to slightly change the lines by messing with the 20-cond ribbon cable, but not enough to tell me I have bad cable/IDC connections, or (heaven forbid) PCB pin solder joint issues with multilayer board. Don't know for sure if these boards are multilayer, but, it wouldn't surprise me. When I do pull it further apart, I'll replace that display ribbon cable with a freshly made one, just in case.
    Supporting Member
    Mar 2018
    Germany
    3,211
    Received: 2,346/1
    Given: 1,336/2
    8
    This indicates a VFD ( https://en.wikipedia.org/wiki/Vacuum...escent_display ) rather than an LCD. It's actually an electron tube.
    1 Not allowed! Not allowed!
    - Own Opinions Only -
    Supporting Member
    Aug 2017
    Portland, OR
    869
    Received: 318/1
    Given: 134/2
    3
    Great, now we have to get into the tube vs. solid state thing...
  1. Display issues
    By Enzo in forum Fun with computers
    Last Post: 11-25-2017, 06:25 AM
  2. Favourite DIY test gear
    By Mick Bailey in forum Music Electronics
    Last Post: 07-24-2017, 11:44 PM
  3. Marshall JCM 2000 Preventative Maintenance issues
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-12-2014, 02:48 AM
  4. connecting test gear to amplifiers etc
    By diydidi in forum Music Electronics
    Last Post: 09-26-2012, 04:52 AM
  5. Stretched waveform
    By lowell in forum Theory & Design
    Last Post: 09-28-2009, 09:52 PM
