Results 1 to 6 of 6
Thread: DC Inject onto lifted heater center tap
    Senior Member Guitarist's Avatar
    Jul 2006
    566
    Received: 8/0
    Given: 10/0
    14
    Just verifying that I can do this with this type of Hammond PT and rectifier?
    thanks.
Name:	Screen Shot 2019-10-07 at 5.46.24 PM.png
ID:	55462   Click image for larger version.
Name:	Screen Shot 2019-10-07 at 5.42.40 PM.png
    Senior Member trobbins's Avatar
    Jun 2010
    Australia
    720
    Received: 99/0
    10
    I'd suggest posting a link to the entire amp circuit - that will help identify where you what to go and what it will affect. This snips don't show what HV you are using, or where in the heater circuit you are connecting, or what valves are in the amp and what their heater-cathode voltage will be.
    Supporting Member
    Mar 2018
    Germany
    2,260
    Received: 1,717/1
    Given: 974/2
    5
    Not sure what "0V Heaters" means in your drawing.
    For heater elevation you need a floating heater winding. So you would have to disconnect the winding's center tap from ground and inject the DC to the center tap (as your headline says). Otherwise the low DC resistance of the winding would short your DC to ground.
    - Own Opinions Only -
    Supporting Member
    Staffordshire UK
    3,766
    Received: 513/1
    Given: 468/2
    18
    Your drawing isn't consistent with the use of dots to indicate circuit connections, so it's unclear whether crossing lines are connected or not.
    Jul 2006
    566
    Received: 8/0
    Given: 10/0
    14
    Aha, ok well here's the whole amp then
    The DC source to inject is the common circuit type, two resistors and smoothing cap.
    thank you...
    Attached Files Attached Files
    Jun 2010
    Australia
    720
    Received: 99/0
    10
    I could suggest the simplest means to do heater elevation in that bassmaster circuit is to disconnect the heater CT from the 0V ground, and connect the CT lead to say a 63V electrolytic positive lead, with cap negative to 0V ground, and connect a resistor from the +39V common cathode point on the phase inverter stage over to the CT lead and new cap positive terminal. The +39V node has a pretty stable dc voltage that is not too high. The input stage triodes and V2B triode may achieve a lower hum, and V2A triode will have a reduced heater-cathode voltage stress on it.
    The new resistor can be something like 100k, and the capacitor something like 1 to 10uF (and doesn't really need to be electrolytic if you have a suitable film cap). The RC filter is then at most 2Hz, so will filter any mains frequency.
    If there were a short/arc on output stage socket pins 2 to 3 then the new cap may become collateral damage, and hopefully there will be no other stressed parts.
    If there was a short from a heater side to chassis, then no collateral damage due to the 100k resistor.
  1. When to use heater center tap
    By dcoyle in forum Theory & Design
    Last Post: 10-12-2015, 02:52 AM
  2. Heater center tap
    By lowell in forum Theory & Design
    Last Post: 01-15-2010, 11:41 PM
  3. Heater center tap
    By Rocketrob in forum Theory & Design
    Last Post: 03-16-2009, 09:44 PM
  4. Using a pot instead of 2 resistors for a heater center tap
    By CitizenCain in forum Theory & Design
    Last Post: 05-27-2008, 04:59 PM
  5. Heater center tap ground or thru .1 cap
    By Normybaby in forum Vintage Amps
    Last Post: 08-10-2007, 02:21 PM
