Page 1 of 2 12 LastLast
Results 1 to 35 of 52
Thread: Echolette pinch roller
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I got a Klemt Echolette a couple months ago and found some Dynacord pinch rollers being sold on Ebay and was wondering if this would work on an Echolette. The dimensions of the pinch roller on my Echolette are
    20mm OD x 7mm ID x 12mm long
    Some more details:
    I used a dental mirror to look at the bridge rectifier and since its selenium (B 300 C 70) I decided to put in a silicon type bridge rectifier (KBPC50-10) to substitute for it. I checked the motor capacitor and two filter capacitors with an analog ohm meter and capacitor tester. The motor works (both speeds, bridge rectifier disconnected during the test). After that I connected the silicon bridge rectifier in place of the selenium (left in place but disconnected) with a 250 ohm power resistor in series with the new bridge rectifier. With a variac and ammeter connected, I slowly brought up the voltage and figured it looked OK. I tested the tubes with a tube tester and they look OK. I put the tubes in and turned it on with a microphone connected via a home made adapter with a 3 pin DIN connector and phone jack and connected the output to an amplifier. It worked with the mic connected, but there was no reverb. I connected a jumper between two pins of a 3 pin DIN connector plugged into the remote control and the reverb worked with some problems with the tape I can discuss later. It seems that it was a bad connection at one of the pots which I fixed. More recently I replaced the roller on the spring biased arm with a new polyurethane roller. It works good in the slow speed when I put my finger on the pinch roller arm and push it toward the capstan. If I had a new pinch roller it might work better.
    Also, I used a 9 pin tube adapter/tester (ie. Pomona) between the tube and socket and checked the grid and plate voltages on some of the tubes which seem OK. There doesn't seem to be any bad interstage capacitors (no shorts).
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I found this on a foreign Ebay website
    As stated this is a rubber tape pinch roller for a Dynacord Vintage Echo Chamber Type S62 although I suspect it will fit other Dynacord Machines from the same era It is 22 mms diameter x 9.5 mms thick with a 5 mm bearing
    Looks like they aren't equivalent.
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    You can have the original roller rebuilt with new rubber. I had two of them done last year by Terry in Michigan. Very nice work and fairly quick service as well.
    Where are you located?
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    Some pictures of my Echolette. The roller on the spring biased arm was replaced with a polyurethane roller with a bearing.
    I'm in Maryland. If I had a new tire for the roller, I might be able to rebuild it myself. How much would it cost if Terry fixed it? There's some on Ebay (German seller) for about $60 a piece.
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    Quote Originally Posted by Toynbee View Post
    Here's the link www.terrysrubberrollers.com.
    The cost was $35 plus shipping ($6), but check with him.
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    OK, thanks. Some pictures of the roller in my Echolette. It doesn't look that bad. It seems to be harder than a new pinch roller.
ID:	55483   Click image for larger version.
ID:	55484   Click image for larger version.
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    The center bearing looks to be serviceable, but there is a tape path indentation line along the outer surface. At least you don't seem to have a big dent in the roller from having the roller left in contact with the drive capstan.
    I'd try and clean up the surface of the roller first and see how the tape runs with just that much being done. Usually there are bigger issues to deal with that make the roller a last thing on my list. It's great to have the tape running smoothly, but if there is a problem with the electronics or the heads and there is no echo, that pretty much makes the roller a moot point.
    1 Not allowed! Not allowed!
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I tried googling "pinch roller refurb" and found some interesting links. I have some Rubber Renue and I'm going to try some more of that.
    one video I found:
    https://www.youtube.com/watch?v=nATgx4uJcZI
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I tried putting some of that Rubber Renue on the pinch roller, but it doesn't seem to do much. I noticed there were some lines or deformations in the roller which caused some slight bulges on either end. I read a thread on another forum, I think it was at tapeheads.net about someone putting a pinch roller in a lathe and worked on the pinch roller somehow. I decided to try putting my pinch roller on a bolt (with a short piece of brass tubing as a shim) and putting it in the chuck of a drill press and filing the bulges on either end. It seemed to improve the performance when put back in the Echolette, but I still had to push the pinch roller arm toward the capstan to get it up to speed. I tried putting a second spring on the pinch roller arm before and that seems to work.
ID:	55560   Click image for larger version.
ID:	55561   Click image for larger version.
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    If the last photo is the wheel after you have abraded it, you still have a few problems.
    The shiny section is still going to slip because there is still a depression where the tape touches the roller. When the depression is gone, the entire surface of the roller will have a clean new even color.
    I don't know what you are using to abrade the surface with, but it is tearing up the rubber. It should be clean and smooth or you will have tape speed problems caused by a too rough surface.
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    That glazing is more obvious after filing the bulges. I used a jeweler's file. I was thinking of filing the glazing off where the tape contacts it, but I probabbly need to be careful with it.
  12. #12
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I bought 5 Neutrik Rean 3 pin DIN male connectors for $1.370 a piece recently from Allied Electronics. The price was lower than most Ebay sellers and they shipped it fast. They fit in the 3 pin jacks on the Echolette.
  13. #13
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,681/2
    Given: 1,210/1
    18
    This won't always work. Sometimes the rollers are just passed it and nothing but replacement will work. That said, I've used a fine emery cloth in the past. Apply slight pressure to the roller as it spins. Low and slow. Be patient. You need to take enough off the outside that the entire surface looks the same- no high or low spots and no shiny spots or grooves. Also, you'll need to continue to apply the Rubber Renue and let it soak in until it no longer does. Don't wipe it off right away. Let it do its job and soak overnight if necessary. If there's a chance of the pinch roller surviving, this will work. If it doesn't, time for a new one. My $.02.
  14. #14
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    You need to use the DIN connectors for the two mic inputs and the footswitch connector, as the 3rd input that is recommended for instrument use and the output have already been changed to 1/4" phone jacks.
    I don't know what sort of file you are using, but I suggest that the file be wide enough to cover the entire face of the rubber roller. In order to not distort the dimensions of the wheel, you need to try and remove the old rubber on the surface as evenly as possible.
    I would also suggest that you file the surface flat before you use the Renue product.
  15. #15
    New Member
    Oct 2019
    Indonesia
    4
    0
    Be sure to send a photo of the final result. I think it should turn out an amazing thing!
  16. #16
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I'm waiting on some 6X20X6mm (20 mm OD) polyurethane rollers slowly making their way through China. I put a 6X17.8X7mm polyurethane roller on the spring biased arm (idler pulley?) and it turns easier than the original one. The 6X17.8X7mm polyurethane roller touches the metal washer of one roller which could be modified.
    Original roller shown top left (20 mm OD), 6X17.8X7mm polyurethane roller top right, 2 6X26X10mm polyurethane rollers and a teflon washer bottom in the picture. The polyurethane rollers have some kind of bearing in them which allows them to turn easier (they don't have ball bearings).
  17. #17
    Feb 2010
    12,606
    Received: 2,168/24
    Given: 5,470/11
    24
    626RS is a standard type sealed deep groove ball-bearing.
  18. #18
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    So you're saying they have ball bearings in them? They don't rattle like bicycle hubs and I thought they didn't have ball bearings. I tried holding one up to my ear and spun it real quick and I could hear some kind of sound like a bunch of little ball bearings.
    At about 5:34 in this video you see the guitarist reaching toward what looks like an Echolette.
    MY INDOLE RING..............................................1:25
    https://www.youtube.com/watch?v=WHBhH0dYOow
    21st post here (by Mecaso) John Lennon with an Echolette:
    https://music-electronics-forum.com/...t=39009&page=2
  19. #19
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    How about something like this?
    https://www.ebay.com/itm/LR50-6NPPU-...ty!20770!US!-1
    They have metal surfaces and they could be used for rollers/pulleys in the tape path (not the pinch roller)
  20. #20
    Feb 2010
    12,606
    Received: 2,168/24
    Given: 5,470/11
    24
    Those are expensive. If you look closely at the picture you posted of the polyurethane roller, you can see the number 626RS. They just put a polyurethane tire around it.
    Here is a plain 626RS without the tire, cheaper than the LR50 you posted.
    https://www.ebay.com/itm/626-2RS-Pre...UAAOSwawpXsH7l
  21. #21
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    How about 6 mm ID 19 mm OD and 9 mm width?
  22. #22
    Feb 2010
    12,606
    Received: 2,168/24
    Given: 5,470/11
    24
    If you need 9mm instead of 6mm width, then LR50/6 is a good number. I only mentioned the 626 because that is what they are using in the roller you are waiting for from China.
  23. #23
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    Does anyone know if this would work for replacing the 47 uf bipolar motor capacitor? The cap in the Echolette reads higher than 47 uf on the cap tester I have.
    https://www.ebay.com/itm/USA-43-56-M....c100010.m2109
  24. #24
    Old Timer
    Jun 2007
    5,129
    Received: 108/0
    Given: 66/0
    19
    That cap will probably work, but mounting may be a problem. What is wrong with the cap you have? Being higher in value doesn't mean that it is bad.
  25. #25
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,419
    Received: 2,515/7
    57
    Um, does the motor work? If it does, stop fixing it.
  26. #26
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    I said the motor works in the first post. When working on the Reverbatape I found that I had to replace the electrolytic capacitors (129 and 132 in the schematic) in the power supply to get the voltage up to -30V. I tried testing the original caps with a Uygao UA6013L capacitor tester and used an analog voltmeter to check the resistance of each cap (one side unsoldered and disconnected from the circuit). The capacitance was higher than 500uf and the resistance after charging was at least 500k for both caps, but they still didn't work right in the ciruit (voltages to low). When I tried testing the motor cap in the Echolette it was higher than 48uf.
    I have some new 47uf 100V bipolar caps and was thinking of trying one in place of the old one in the Echolette to see if it affects the speed of the motor. The cap in the Ebay link could be used to replace the old one if a bolt was glued to the bottom of it offset from the center and held in place with a nut like the original one. The orginal motor cap is 3 1/4" long and 1 1/8" in diameter and the one in the Ebay link is 2 2/4" long and 1 7/16" diameter.
    A lot of people recommend recapping old equipment, too.
  27. #27
    Oct 2014
    142
    Received: 5/0
    6
    That's a sorry looking Echolette but before you get too carried away, have you measure the resistance of the heads, they should measure 1.2K ohms. If any of these heads are faulty which is most likely on the pre circuit board Echolettes you could be up for a few dollars. Although you believe the coupling capacitors to be OK they are most likely leaky and you should replace every one of them and while you're at it also replace those cathode bypass electrolytics.
    Those motor capacitors usually short and if not removed and replaced will quickly render the motor U/S. If your motor is turning I would leave that alone and make sure all the electronics are attended to and then turn to the drive system.
    FYI also remember that it is an analog device with a tape driven by an electric motor and even though the tape speed can be as good as designed it will not match the "speed" of a digital delay/echo device. Many users of these machines fail to understand this and it takes a while for them to realize that this tape "wow" is part of the magic of tape driven devices.
    Currently I've got two of the Klemt Echolletes on my bench and another in the post, having just repaired another two. .
    Good luck and have fun.
  28. #28
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    So how do you feel about analog vs. digital and tubes vs. transistors?
    The tape heads seem to work. I connected it to an amp and spoke through a mic connected to it and all tape heads work. It looks like the motor cap should be replaced to prevent damage if it goes bad.
  29. #29
    Oct 2014
    142
    Received: 5/0
    6
    There are 5 tape heads, to check the recording heads raise the recording level one head at a time and to check if both playback heads work, listen to the echo from any one recording head and then pull out playback head 2 switch to hear double the echos.
    You appear to be obsessed with replacing the motor cap, in reality they don't give to much trouble.
    Re analog versus ,,,,, etc, horses for courses, I like valve/tube equipment but could you imagine a 24 channel mixer with tubes?
    Good luck with your Echolette
  30. #30
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    Recording, '50s Style
    https://www.youtube.com/watch?v=_Q-scxybnp0
    http://www.rickresource.com/forum/vi...p?f=5&t=415855
    Replacing Selenium Rectifiers attached
    Attached Files Attached Files
  31. #31
    Oct 2014
    142
    Received: 5/0
    6
    The tape tensioning roller is not that critical as long as it spins freely. It should be approximately 7-8mm high and 19mm in diameter.
    The rubber pinch roller/wheel is very important! I usually remove the roller and rub it's surface on 120 emery paper finishing on 80. Hold the roller between your index finger and thumb and let it abrade on the emery paper, don't hold it to tight as you will introduce flat spots. After I am satisfied with this procedure I give it a coat of "renue" and let that sit for a day or so. Sometimes I have to do it all again two or three times. BE CAREFUL WITH THE RENUE IT IS HIGHLY CARCINOGENIC!
    My next step is to remove the steel pinch roller support and check this to ensure it is perfectly flat. All rubbing areas are smoothed with emery paper and I do this to keep the wheel perfectly flat against the motor shaft. Failure to do this can cause the tape to wrinkle, the tape to ride up or down on the shaft and increase wow.
    The 47uf capacitor does not give to many problems, in my 50 years of echolette repairs I have possibly only found one faulty one. The capacitor is a motor start capacitor and if it increases in value it would make the motor turn a little faster, no big deal!
    The bridge rectifier can be replaced with numerous options as long as it has at least 400PIV at 200mA rating. I have not used a voltage drop resistor but that is your choice.
    At the risk of being repetitive check the heads all should measure 1.2K ohms, replace all the coupling and bypass capacitors, check the valves/tubes and if all has been done then move on to the mechanical overhaul.
ID:	55971   Click image for larger version.
ID:	55972   Click image for larger version.
ID:	55973   Click image for larger version.
ID:	55974   Click image for larger version.
ID:	55975   Click image for larger version.
    2 Not allowed! Not allowed!
  32. #32
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    With the emery paper why would you want to use 80 after 120 when 80 is courser than 120? The capacitors are hard to get to, too.
    https://homeguides.sfgate.com/emery-...per-96632.html
  33. #33
    Oct 2014
    142
    Received: 5/0
    6
    Yes, got that back to front, 80 first!
    Echolettes are not for the novice repairer. If you have a printed circuit board model you need to take extra care when soldering in the new capacitors as you can easily short one track to the other, also manipulating the board can be a task. The earlier non board models require some patience when replacing the caps around valve No.2. If you're planning this project as a detailed restoration I would also replace those filter capacitors as shown in one of my photos.
    One more tricky job will be the adjustments of the record head bias oscillator levels and if you are experiencing echo volume issues with head 1 check the level pot (dual ganged) as I have found these to go open circuit occassionally.
    Have just received an E51 which requires new heads and a pinch roller, but is otherwise in a very clean condition
  34. #34
    Banned
    Oct 2019
    40
    Received: 3/0
    Given: 1/0
    0
    Various rollers
    The Echolette comes with three solid rollers like the one shown in the pictures. One of the black rollers is shown with some metal and polyurethane rollers. The metal and polyurethane rollers all have bearings. The polyurethane rollers turn easier than the metal rollers (less friction). I tried using a smaller polyurethane roller on the tension arm and it turns easier than the solid black roller. At times the black roller wouldn't turn and the tape would just run over it when the tape was running.
ID:	56037   Click image for larger version.
ID:	56038   Click image for larger version.
  35. #35
    Oct 2014
    142
    Received: 5/0
    6
    Attached is a photo of a later model NG51S which shows three all plastic rollers, on the earlier model the two plastic rollers are held in place with a large washer while the roller on the tape tension arm is held by a smaller washer and screw. Thw large washer on the earlier moel also serves to align the tape.
    The solid black roller is I believe the rubber pinch wheel and this MUST be in tip-top condition so that the tape is moved past the heads at a constant speed.
    If the tape is riding high or low this could be caused by a warped pinch wheel support plate, but get that pinch wheel in good order before you go any further.
    Have you sorted out the electronics?Click image for larger version.
ID:	56041Click image for larger version.
ID:	56042Click image for larger version.
  1. Under rated cap in a pinch
    By Sowhat in forum Fun with computers
    Last Post: 07-27-2017, 12:41 PM
  2. EL84 tube clamp, in a pinch......
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-02-2014, 10:58 PM
  3. Replies: 9
    Last Post: 12-04-2012, 02:57 PM
  4. Echolette B200
    By QJerry in forum Schematic Requests
    Last Post: 09-16-2010, 05:27 PM
  5. Cleaning Pinch Roller on a roland Space Echo?
    By boutiquedungeonla in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-28-2008, 03:42 AM
