Results 1 to 19 of 19
Thread: Marshall JCM 800 50W Split channel rev. Combo sounds like crap!!
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    Hello! Itís been a while since Iíve posted but here I am. I have a JCM 800 50W on the bench that Iíve serviced before. Last time I replaced the filter caps with 2 50uf FT can caps and new voltage drop resistors, the previous work done in not related and has held up well. The customer brought it back with the complaint of not enough high end, it sounds kind of muffled. I found a shorted cap (C9) on the board related to the channel switching circuit I believe but itís unrelated, no difference after clipping in a new one. One problem which might be related is grounding. Seems like even with nothing plugged into the input jack 60hz hum can be heard when turning up the tone controls and volumes. Grounding the chassis through my meter kills it. Now, this is one of the issues but not sure if I can say itís related. On some level itís all related, but all stages are conducting to ground the way they should. I can post a generic voltage chart if it will help you help me track down whatís going on! Thank you. Schematic attached..
    https://drtube.com/schematics/marshall/4210.gif
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    I’ve localized the issue to boost channel only.. the reverb is not functional and some arcing from the reverb transformer secondary. Anyone have a datasheet for these? I’ve never seen anything like this
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,042
    Received: 1,825/7
    55
    C9? I don't see part numbers on your schematic.
    Your schematic shows a transformer part number. If those are not available, it seems to me you could mount a Fender transformer, and change the reverb pan to a 4AB part instead of the specified 4FB part. ANyone see problems with that?
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    To clarify, the complaint about the amp is that it sounds muffled, and lacking high end. Itís possible arcing happened because there was no load on the txfmr while it was on the bench. I put another reverb tank on the bench and it does work. Sorry about that. My initial thought of it being a shorted transformer was false, which overall Iím happy about. I localized the problem to the boost channel only. After sending a 1k sine through the circuit I realized that the treble control does nothing. There are signs of grounding issues. Nasty 60hz hum when the MV is turned up. Iím gonna look for problems in the preamp. There may be a grounding issue somewhere in the tonestack, although I havenít found it yet
    May 2010
    Sioux Falls, SD
    6,332
    Received: 1,224/1
    Given: 952/1
    16
    The treble control may not have much effect on a 1K test signal. Try a higher frequency. Yes, you could indeed have a problem there, but your test isn't proof of that.
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    Ok it took me all day, but I think I know whatís going on here: it is the switching circuit after all. For the reason of some failed diode or transistor, maybe this cap, thereís bleed between the boost and normal channel. When all the controls on the boost channel are dialed down to 0, normal channel sounds great. Anyway, each channel introduces 60hz hum when not selected. Does that make sense?
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    Agreed, the pot itself is good but havenít completely confirmed the tonestack is good. I think itís a product of this channel switching issue
    Jun 2006
    Norristown state hospital
    2,276
    Received: 161/4
    Given: 1/0
    16
    The pots and their pc board connections can go bad often on these.
    Re-work their connections, test and clean the pots.
    You're going to have to lift the board to troubleshoot the switching circuit anyway.
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    https://vimeo.com/366561781
    Heres a video of exactly whatís going on. Kind of an elusive problem and almost positive itís grounding. I went through and tested almost every ground point that I could think of and got an ok reading.. what do you think? What should I try next? Barely getting any signal through the boost channel
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    Doing a little bump on this
    All the ground connections are seemingly good.. but when I touch the boost channel volume knob specifically, its conducting signal like an instrument cable would. Not sure what could have failed here. Itís taking me forever to find it!
    Supporting Member
    Mar 2018
    Germany
    2,270
    Received: 1,729/1
    Given: 981/2
    5
    From the video it seems your amp chassis is not properly safety grounded. Please measure resistance between amp chassis and mains safety ground/earth.
    - Own Opinions Only -
  12. #12
    Feb 2010
    11,759
    Received: 1,615/23
    Given: 4,135/11
    22
    You have the plastic knob on or off the control shaft? Not sure how it could make noise if it is on as it is plastic. Is the nut that secures the pot to the chassis tight?
  13. #13
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    Seems your amp chassis is not properly safety grounded. Please measure resistance between amp chassis and mains safety ground/earth.
    0 ohms
  14. #14
    Supporting Member
    Mar 2018
    Germany
    2,270
    Received: 1,729/1
    Given: 981/2
    5
    The interesting thing is that the noise disappears if he connects the scope probe's ground to the chassis.
  15. #15
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    The knob in question is a replaced pot. Itís an alpha pot so no plastic shaft or insulation.. right now I have the board unmounted from the faceplate, but the result is the same even with the pot mounted
  16. #16
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    In general itís been hard to diagnose, there seems to be things done to the amp from some previous repairs, including one of these 330uf caps mounted under the board. There are some lifted solder pads that I reflowed the connection for after scraping away to get the bare trace to solder to
  17. #17
    Supporting Member
    Mar 2018
    Germany
    2,270
    Received: 1,729/1
    Given: 981/2
    5
    Quote Originally Posted by Steelwitch View Post
    0 ohms
    O.K. I assume you measured resistance between chassis and your wall outlet safety ground (the mains cable's ground wire could have a bad contact which would be a safety issue). Your video seems to indicate a difference in potential between the amp chassis and the scope's ground.
    I suggest the following: Cover a cardboard large enough to cover the complete chassis with aluminum foil and use it as as shielding bottom for the chassis. Make sure that the foil has good electrical contact to the chassis. Noise gone?
  18. #18
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    Ah sorry for bumping the thread yíall... it was a bad ground on the reverb transformer of all things. Just needed some flowó everythingís cool with this amp now... for now.
  19. #19
    Nov 2018
    217
    Received: 28/0
    Given: 5/0
    2
    It seems like the grounding for the reverb runs directly to the preamp ground on the board, so no wonder I was getting all this wonky grounding nonsense
  1. Crate Flexwave 120/212 combo strange sounds popping sounds
    By blindboybenton in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2019, 06:20 AM
  2. Marshall Split channel again (some interesting information)
    By Pedro Vecino in forum Mods & Tweaks
    Last Post: 10-02-2018, 10:19 AM
  3. Marshall 5275 ss combo: no sounds when golng thru input jack, ok thru effects loop :(
    By Led Hendriani in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-10-2016, 11:29 PM
  4. Replies: 27
    Last Post: 05-12-2014, 07:40 PM
  5. marshall split channel 50 1986 amp
    By rockinrendell in forum Mods & Tweaks
    Last Post: 08-22-2008, 02:38 PM
