Page 1 of 4 1234 LastLast
Results 1 to 35 of 124
Thread: Help please! 1973 Marshall Super Lead - EL34 to 6550s bias question
  1. #1
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Hello friends, I have a 73 Marshall Super Lead. This is a USA model originally outfitted with 6550s.
    Somewhere along the line, someone converted it to EL34s. It worked fine, sounded good, etc. I've been thinking of converting it back to it's original 6550 spec, and I've done that...to the best of my knowledge. I have a set of Sovtek 6550WE power tubes.
    My problem....I can't get the bias hot enough. Not even close. With the bias pot maxed, I'm getting about 24ma current through a bias probe at each tube. At the middle setting, about 17ma. The tubes seem fairly well matched - same readings at each tube. My negative bias voltage at the grids is about -40vdc at max pot adjustment. Plate voltage is approx 395vdc.
    I'm using the figures off of an old Unicord schematic with figures for USA 6550s.
    15K before the diode
    15K with the 10uf bias caps
    47k in series with the bias pot
    150k grid leaks
    All checked and verified with an ohmmeter.
    So what gives? Why can't I get these tubes to bias? Help please!
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member
    Join Date
    May 2010
    Location
    WV
    Posts
    962
    Thumbs Up/Down
    Received: 14/0
    Given: 105/0
    Rep Power
    10
    What's the pot value?
  3. #3
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Quote Originally Posted by gtrplayr1976 View Post
    22k
  4. #4
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,728/1
    Given: 979/2
    Rep Power
    5
    Real 6550s should run VERY hot at -40V bias. Marshall spec was -44V with 395V plate voltage.
    What are your screen voltages (pins 4)? Should be around 390V.
    How did the EL34s measure at -38V?
    4 Not allowed! Not allowed!
  5. #5
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Screen voltage is hovering around 388vdc.
    Grid voltage with the bias pot midway is about -48vdc.
    I didn't take any EL34 measurements because one had blown. But in the past I could bias EL34s no problem.
  6. #6
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Should I try to measure the bias a different way?
    I have some precision 1ohm resistors I can bridge from pins 1/8 to ground.
    I can also try the OT measurement method I guess.
  7. #7
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,728/1
    Given: 979/2
    Rep Power
    5
    So if your bias probes and meter (battery) are fine, your 6550s are out of spec.
    2 Not allowed! Not allowed!
  8. #8
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,728/1
    Given: 979/2
    Rep Power
    5
    Quote Originally Posted by Greg_L View Post
    If there's any doubt about the bias probes, I recommend to try alternative methods as mentioned. Always useful to have 1 Ohm cathode resistors installed.
  9. #9
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    That's what I'm thinking. The meter and probe has worked fine for literally everything else. My voltages seem to be where they should be. Nothing weird is happening, except the tubes won't bias hot enough.
  10. #10
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    With 6550s would I still tie pins 1 and 8 together?
  11. #11
    Supporting Member
    Join Date
    May 2010
    Location
    WV
    Posts
    962
    Thumbs Up/Down
    Received: 14/0
    Given: 105/0
    Rep Power
    10
    22k
    Try 50K. That's what I have in my JTM45.
    1 Not allowed! Not allowed!
  12. #12
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Thanks, but is there another way to increase range? This is a later 73 amp with a PCB. I'm fine with soldering on PCBs, but I'd rather not if I don't have to!
  13. #13
    Supporting Member
    Join Date
    May 2010
    Location
    WV
    Posts
    962
    Thumbs Up/Down
    Received: 14/0
    Given: 105/0
    Rep Power
    10
    I honestly don't know any other way. Maybe hotter tubes? Helmholtz would know.
  14. #14
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,038
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    You alter the amp to accommodate your tubes, or you alter your tubes to accommodate your amp. Those are your choices. Altering the amp requires soldering parts.
  15. #15
    Supporting Member
    Join Date
    May 2010
    Location
    WV
    Posts
    962
    Thumbs Up/Down
    Received: 14/0
    Given: 105/0
    Rep Power
    10
    I've had to increase pots ,or resistors more than once to get the bias where I need it.
  16. #16
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Quote Originally Posted by Enzo View Post
    I've soldered parts. I've soldered the proper resistors all over this thing. I'd just rather not change that pot. That requires ordering parts and waiting. And frankly, these tubes are so far off I don't even know what pot I'd need...and it might not even work!
    I'm gonna try a different measurement method. I'll be installing the 1 ohm cathode resistors this evening.
  17. #17
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Which resistor would I need to change? The 47k? Would I need to decrease it? Can I jumper in a parallel resistor just to see what happens?
  18. #18
    Join Date
    Feb 2010
    Location
    Posts
    11,757
    Thumbs Up/Down
    Received: 1,615/23
    Given: 4,129/11
    Rep Power
    22
    150k grid leaks
    Were these parts all there when it was running EL34's? If not, which did you change?
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  19. #19
    Senior Member vintagekiki's Avatar
    Join Date
    Jul 2006
    Posts
    1,598
    Thumbs Up/Down
    Received: 270/1
    Given: 223/0
    Rep Power
    16
    Who does not know and knows that he does not know - teach him Confucius)
    Who knows and does not know that he knows - wake him Confucius)
  20. #20
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Quote Originally Posted by g1 View Post
    The grid leaks were 220k for EL34s. The bias power resistor was 27k. I piggyback paralleled resistors to get them down to 6550 specs. All readings have been verified.
    When I got the amp the conversion was halfass complete. I put it to proper EL34 bias specs and it worked perfectly. Now I'm putting it back to it's original 6550 specs and it isn't.
  21. #21
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Update -
    I soldered in a 1 ohm precision resistor from pins 1&8 to ground on one power tube socket. Took a reading across the resistor. I get the same reading as with the bias probe, so the probe is telling the truth.
    Just for kicks, I jumpered a 150k across the 47k that lives in series with the bias pot. That dropped the 47k to around 35k. My bias reading went up at the tube. Not much, but it did go up more in the right direction. My light bulb limiter got brighter though. It went from a very dull dim glow to noticeably brighter, so something is drawing more amps. Maybe these tubes are just bad.
  22. #22
    Join Date
    May 2006
    Location
    Posts
    32,038
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    Yes, the hotter you bias the tube, the more current it draws. That current comes ultimately from the wall outlet mains supply, hence the bulb brightens.
  23. #23
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,331
    Thumbs Up/Down
    Received: 1,222/1
    Given: 950/1
    Rep Power
    16
    If you bias hotter, you are going to draw more mains current. The additional current comes from somewhere.
    Edit: Enzo beat me!
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  24. #24
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Quote Originally Posted by The Dude View Post
    Edit: Enzo beat me!
    Ha, yeah, it just seemed to get brighter than I thought it should. Maybe? I don't know. It's a 300w bulb.
    I had a rectifier wired backwards one time. That thing got really bright!
    I'm gonna put it back to EL34 configuration and get readings with the EL34s.
  25. #25
    Join Date
    May 2006
    Location
    Posts
    32,038
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    I may be old, but I can still be quick.
  26. #26
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,331
    Thumbs Up/Down
    Received: 1,222/1
    Given: 950/1
    Rep Power
    16
    I'm not sure the Mrs. would appreciate that statement.
  27. #27
    Supporting Member mozz's Avatar
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    822
    Thumbs Up/Down
    Received: 191/1
    Given: 133/0
    Rep Power
    5
    Taking bias readings with the light bulb or not?
  28. #28
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Quote Originally Posted by mozz View Post
    Both
  29. #29
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,331
    Thumbs Up/Down
    Received: 1,222/1
    Given: 950/1
    Rep Power
    16
    Good point! Bias should be set without the limiter at full/normal line voltage.
    3 Not allowed! Not allowed!
  30. #30
    Supporting Member
    Join Date
    May 2010
    Location
    WV
    Posts
    962
    Thumbs Up/Down
    Received: 14/0
    Given: 105/0
    Rep Power
    10
    Both
    Don't use the limiter to bias. You need full power.
  31. #31
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    I have checked it without the limiter. Still the same.
  32. #32
    Join Date
    May 2006
    Location
    Posts
    32,038
    Thumbs Up/Down
    Received: 1,822/7
    Given: 0/0
    Rep Power
    55
    The bulb limiter is a very useful tool, but you cannot rely on voltage readings taken while on it.
  33. #33
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    Noted, thanks. But I did take my readings without the limiter. I started with a variac and the limiter so nothing would blow up. Once I was confident nothing would go up in smoke, the power came straight from the wall.
  34. #34
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,728/1
    Given: 979/2
    Rep Power
    5
    The resistor values for the EL34 bias circuit (except the 220k grid resistors) seem to be more appropriate for your extra "cold" 6550s as well.
  35. #35
    Join Date
    Jun 2018
    Posts
    153
    Thumbs Up/Down
    Received: 82/0
    Given: 143/2
    Rep Power
    2
    I was thinking that myself....not that I know for sure, but thinking it was worth a try. I'm going to put it back to EL34 spec and try the 6550s.
Thread Information
Users Browsing this Thread
  1. Marshall Super Lead RI Oscillation trouble
    By sunshine_bassman in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-28-2019, 01:51 AM
  2. Marshall jcm 2000 triple super lead
    By baev_al in forum Guitar Amps
    Last Post: 10-09-2013, 02:48 PM
  3. Marshall Super lead 1959 Problem
    By COLMMCSHERRY in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-26-2009, 07:24 PM
  4. RI Marshall Super Lead 100 with bias issue
    By WholeToneMusic in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-16-2009, 01:04 AM
  5. Unknow mod in a Marshall 1959 Super Lead
    By chocopower in forum Mods & Tweaks
    Last Post: 09-01-2007, 09:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
