Results 1 to 2 of 2
Thread: Marshall JCM 900 SLX BR3 Issues
  1. #1
    New Member
    Join Date
    Oct 2019
    Location
    Canada
    Posts
    1
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Hi, new to the forum and semi-noob in electronics
    So like many, I had issues with my JCM 900 BR3 Bridge Rectifier, which was dead and burnt some traces
    I changed it (400V instead of 50V) and changed C8; I had to use the diode legs because the traces were burnt
    Powered up with 4 preamp tubes and they all lit up
    Put some power tubes on and now only 2 power tubes light up (V7 & V8 I guess, both further from the preamp tubes)
    None of the 4 preamp tubes light up, nor do the 2 first power amp tubes
    When I turn the amp on, I'm not getting any voltage reading on C8 (I have normal ± 500V reading on the 2 large electrolytic caps)
    Any help is appreciated
    Thanks
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,321
    Thumbs Up/Down
    Received: 1,219/1
    Given: 945/1
    Rep Power
    16
    If two power tubes have filament voltage and the other two and no preamp tubes light, I suspect a connection issue. Probably another burnt or open trace. Follow the traces that carry filament voltage from tube to tube and see where it isn't.
    1 Not allowed! Not allowed!
    “Yeah, well, you know, that’s just, like, your opinion, man.”
Thread Information
Users Browsing this Thread
  1. Marshall mosfet 100 - power amp issues
    By Intripped in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-08-2017, 10:50 AM
  2. Marshall 8080 Issues
    By misterc57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-24-2015, 05:11 PM
  3. Marshall TSL122 Extreme Issues
    By fishman in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-26-2008, 06:52 AM
  4. Marshall 1987x issues....
    By Dr. Jimmy in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-28-2008, 02:00 PM
  5. Marshall JCM 900 issues
    By goldtop5 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-17-2008, 04:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
