Results 1 to 14 of 14
Thread: Fender 65 Princeton Reverb RI-reverb tank feedback
  1. #1
    Supporting Member nevetslab's Avatar
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,795
    Thumbs Up/Down
    Received: 647/1
    Given: 1,478/1
    Rep Power
    11
    I have one of our Fender Princeton Reverb amps (65 reissue), with reverb tank feedback. It's NOT the stock Accutronics 4AB3C1B tank, but instead a Ruby RRVL2AB1C1BV4 8 ohm input (0.9 ohm DCR), 150 ohm output (46 ohm DCR) 2-spring long tank, short decay, input insulated, output gnd’d. While I like the sound of this tank, it takes very little to send this into gross howling feedback.
    I ordered a replacement stock tank, but while waiting, I've tried a number of things to see if I could defeat it. Loaded the output of the tank, first with 100k, then with 20k (220k input grid bias resistor on the return circuit), with no change. Reversed the polarity of the Tank Input wires, then the Tank Output wires, neither producing any change. Lacking any fiberglass insulation sheets, I tried some 2" grey packing foam, cut to inside cabinet dimensions, pushed in atop the tank/below the speaker. No change. Tried some 1.5" white packing foam, same approach, no change.
    I've no idea who installed this Ruby tank. I don't think that's stock from Fender. Hopefully the 4AB3C1B tank, when it shows up, will restore order.
    Any other ideas? Even with the tank out of the cabinet, held away as far as the cables will allow, turning up the Reverb will still make the system feed back.
    0 Not allowed! Not allowed!
  2. #2
    Old Timer Leo_Gnardo's Avatar
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,393
    Thumbs Up/Down
    Received: 1,413/21
    Given: 1,196/0
    Rep Power
    14
    FWIW Fender has been sourcing octal sockets from Ruby for quite a while now. Maybe 10 years, even longer? So it may not be unusual for other Ruby parts to show up in Fender factory builds.
    I'd wait until you have another tank arrive. Maybe the one in that amp is a particularly badly behaved unit.
    What I do with "bad actors" like this, aside from dumpsterizing them, is "mummifying" the tank with foam weatherstrip tape. Home Despot sells foam tape that's about 1.5" wide (4.5cm for the rest of the world) intended to keep chilly breezes from blowing into camper backs set atop pickup truck beds. About $10 a roll, enough to cover 3 regular size reverb tanks, top bottom sides front & back. Then a tank "sock" over the whole mess. It's always worked for me, and the tape is good for lots of other applications. If that don't fix it your tank is haunted.
    1 Not allowed! Not allowed!
    Enjoy. Every. Sandwich.
  3. #3
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,332
    Thumbs Up/Down
    Received: 1,224/1
    Given: 952/1
    Rep Power
    16
    Does touching the transducers in the tank stop the oscillation? I've had to insert a little rubber cement in the middle of transducers to stop oscillation. If loose they will vibrate.
    2 Not allowed! Not allowed!
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  4. #4
    Supporting Member
    Join Date
    Apr 2009
    Location
    NY, NY
    Posts
    1,239
    Thumbs Up/Down
    Received: 15/0
    Given: 88/0
    Rep Power
    12
    I had a princeton(or was it a deluxe?) reissue of the drip edge silverface series in for service and found that its reverb tank had a 3 or 4" piece of sheet metal riveted to the open side of the tank covering one end. I don't remember if it was covering the input transducer or the output. Has anyone seen one of these?
    Nevertheless when I get amps in with the new production tanks that howl I first try lining the open side with aluminum foil.
    And it sometimes works.
  5. #5
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,795
    Thumbs Up/Down
    Received: 647/1
    Given: 1,478/1
    Rep Power
    11
    Quote Originally Posted by pontiacpete View Post
    The Ruby tank that's presently installed has that riveted shield in place. I removed it so I could get at the two coil wires for flipping the polarity. As stated, changing the input/output polarity made no difference. Underneath the tank inside the vinyl pouch is the fiber board cut to the same size as the tank's flange perimeter.
  6. #6
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,795
    Thumbs Up/Down
    Received: 647/1
    Given: 1,478/1
    Rep Power
    11
    Quote Originally Posted by The Dude View Post
    That's something I haven't tried yet. If I get a chance later today, I'll see if it does. Never thought of this technique.
  7. #7
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,795
    Thumbs Up/Down
    Received: 647/1
    Given: 1,478/1
    Rep Power
    11
    The Accutronics 4AB3C1B Reverb tank arrived, so I moved an Eden WT-800 off the bench to see if this would be a quick slam-dunk. Would that it were so.
    The new tank howls just as badly as the Ruby tank, so, I think it's NOT the tank itself. So, I pulled up the schematic for the 65 RI Princeton Reverb, to see the tubes in use. V2 is the Reverb drive tube, 12AT7, and, that's what is installed. Just in case, I pulled it and installed a 12AU7. Got the same results...howling. So, put the 12AT7 back in. What's in the driver stage on this amp? 12AT7? No, 12AX7 was what I found plugged in, and, that's what is called out on the schematic, so the tubes are the right ones. Power tubes 6V6GT, with both running at 20mA plate current, according to my bias probes, so that's in the ballpark.
    I disconnected the RCA cables connected to the now-mounted/bagged reverb tank, and grabbed the Ruby tank I had removed, and plugged it in with a longer dual RCA cable. Stretched it away from the amp as far as it would reach (3 ft). Yup. still howling, regardless of orientation.
    I can put my finger on the long springs where the two shorter springs meet in the middle, and that will stop the howling. Though I don't think this was what The Dude was referring to: Does touching the transducers in the tank stop the oscillation? I've had to insert a little rubber cement in the middle of transducers to stop oscillation. If loose they will vibrate.
    Dude, are you referring to placing a little rubber cement at the middle connections of the two long springs? I don't have any rubber cement, but, do have some RTV that I'll try. First try, just the tiniest bit applied to both spring joints in the middle of the long springs. Still howling. Added a bit more. Now, while that seemed to stop it, the tank now sounds dark, lacking highs. Removed most of the two small blobs, still leaving a bit at each spring. Got more highs out of it, and still not howling. I'm trying this on the Ruby tank, outside the cabinet with a different cable attached so I could mess with it.
    Now pulling the Accutronics tank out and putting this modified Ruby tank back into the pouch and mounting it again. THAT seems to be working. Still a bit too dark to my liking, but, it's no longer feeding back, and I can drive the amp hard, dial in enough reverb to my liking without the loud screaching it had when it came in. Thanks for the suggestion, if that WAS what you meant.
  8. #8
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,393
    Thumbs Up/Down
    Received: 1,413/21
    Given: 1,196/0
    Rep Power
    14
    Maybe I missed if you checked this, is some sort of unexpected signal being sent out the reverb drive line? FWIW I've had reverb drive transformers apparently with internal insulation breaking down, maybe arcing, sending random pops or crackly noises into the tank. I'm thinking maybe you have something like that going on, but with a much more obnoxious noise coming out instead.
  9. #9
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,795
    Thumbs Up/Down
    Received: 647/1
    Given: 1,478/1
    Rep Power
    11
    Quote Originally Posted by Leo_Gnardo View Post
    I wasn't hearing anything that suggested random pops or crackling noises, plus got the same results with the new tank. I've removed the new tank, and, if you read my edited post from a few minutes ago, I think The Dude's suggestion, or my interpretation of it has restored order.
  10. #10
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,393
    Thumbs Up/Down
    Received: 1,413/21
    Given: 1,196/0
    Rep Power
    14
    Quote Originally Posted by nevetslab View Post
    I thought there might be some howling noise coming out of the tank drive jack, but upon reading your edited post #7 seems not. I'll have to keep The Dude's suggestion on file too.
  11. #11
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,332
    Thumbs Up/Down
    Received: 1,224/1
    Given: 952/1
    Rep Power
    16
    I was talking about between the transducer coil and core. I've drawn an arrow on this picture for clarity. Often times, it's really loose and will vibrate causing oscillation. I think you did something else, but hey, if it works......
Name:	Reverb Transducer.jpg
  12. #12
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,795
    Thumbs Up/Down
    Received: 647/1
    Given: 1,478/1
    Rep Power
    11
    Glue applied to middle of long springs where they join together
    I kind of thought that was the area you were referring to. It was tight on both ends on the Ruby tank, while a tiny bit of play on the Accutronics tank.
    What I had done here, after touching the springs that were vibrating with the howling, was to apply a tiny bit of RTV at the junction of the middle of the two shorter springs joined to make up each long spring, as shown below:
Name:	Howling tank fix-1.jpg
ID:	55655 Click image for larger version.
Name:	Howling tank fix-2.jpg
ID:	55656 Click image for larger version.
Name:	Howling tank fix-3.jpg
    I would have tried rubber cement here, but didn't have any on hand. I think the RTV wasn't the best choice, though it did succeed in halting the howling feedback, though it changed the character of the tank. I will have to look at a couple other Princeton Reverbs in our inventory, as I rarely find this symptom.
    I'll definitely keep your method in mind to try in the future. Thanks!
  13. #13
    Join Date
    Feb 2010
    Location
    Posts
    11,759
    Thumbs Up/Down
    Received: 1,615/23
    Given: 4,135/11
    Rep Power
    22
    I think they used to secure those joints with something harder, like epoxy or nail polish. Same as at the ends where the springs hook into the transducer cores.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  14. #14
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,729/1
    Given: 981/2
    Rep Power
    5
    Yes, I'd use a drop of high viscosity Super Glue (cyanoacrylate) which gets even harder than epoxy. Softer stuff tends to damp high frequency reflections.
Thread Information
Users Browsing this Thread
  1. Fender 68 Custom Twin Reverb LF feedback howl, HF feedback shriek
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-12-2018, 01:41 AM
  2. 67 Fender Blackface Super Reverb - Hammond Reverb Tank Replacement Suggestions?
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-05-2014, 06:32 PM
  3. Fender 6G15 REverb Unit - Reverb Tank questions
    By corliss1 in forum Vintage Amps
    Last Post: 11-16-2010, 01:43 AM
  4. How to silence reverb tank feedback?
    By Chuck H in forum Theory & Design
    Last Post: 04-18-2010, 05:15 PM
  5. Reverb tank feedback: could this pig stop squealing???
    By Victor Denance in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-18-2008, 08:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
