Results 1 to 8 of 8
Thread: How to "cheat" Reverb circuitry?
    Apr 2010
    Belgrade, Serbia
    45
    Received: 2/0
    Given: 7/0
    0
    I have build custom all-aluminium housing for my Laney VH100R head. It is 5 Kg (about 10 Lbs) lighter then the original wooden box. Since I never use the spring Reverb I wanted to leave out the reverb tank also. The thing is: even when reverb pot is on zero, seems that tank does have some influence on sound because when I disconnect the tank's RCA leads sound gets really dry and dead and ugly.
    SO is there a way to cheat the circuitry?
    To leave out the tank but to put some resistor across the RCA leads / driver out??? Again I will NEVER use the reverb pot, it will always be on ZERO. I just want the circuitry to "think" that tank is connected.
    Attached Files Attached Files
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,160
    Received: 1,890/7
    55
    Isolate the problem. The amp sounds OK WITH the reverb pan? It sounds bad WITHOUT the reverb pan? Unplug only ONE of teh pan cords at a time. Pull only the INPUT (drive side) cord. Does that affect the sound? Return that cord and now pull the OUTPUT (return side) cord only. Does that affect the sound?
    Just guessing here, but my first thought is that when you unplug the reverb pan, you are leaving the high gain return circuit unterminated and it is free to oscillate. The simple cure for that would be to connect a short across that return connection.
    1 Not allowed! Not allowed!
    Supporting Member
    Aug 2017
    Portland, OR
    720
    Received: 254/1
    Given: 106/2
    3
    Looks like the reverb is footswitchable. Does it help any if you disable the reverb via footswitch? It looks like there are separate op amps to drive the reverb so it seems like it should be isolated from the main circuit.
    Is your custom shell much smaller than the original that you can't fit the tank inside? Even if you don't use it and leave the knob at 0 it seems like the simplest thing is to just leave it in.
    Apr 2010
    Belgrade, Serbia
    45
    Received: 2/0
    Given: 7/0
    0
    Quote Originally Posted by glebert View Post
    Well no, it's not smaller but I kind of use both shells, I know it's silly, but one is a snake skin foil, and the wooden one is a Burgundy Red tolex :-) The amp is like a drawer I just slide it in and fasten the few screws. So I use them intermittently. Maybe I could just find any tank to put in the aluminium one, but I didn't have any luck finding a reverb tank over here in Serbia. And moving the same tank from box to box each time is not an option, particle board on the original box would strip down fast.
    Apr 2010
    Belgrade, Serbia
    45
    Received: 2/0
    Given: 7/0
    0
    Yes the reverb is footswitchable but it does not help if it's turned off on the footswitch, sound is still really dead and dry without the tank.
    Apr 2010
    Belgrade, Serbia
    45
    Received: 2/0
    Given: 7/0
    0
    Good thinking I will try your ideas next time I get to the practice pad, will report :-)
    Supporting Member
    Aug 2017
    Portland, OR
    720
    Received: 254/1
    Given: 106/2
    3
    Quote Originally Posted by Emetal View Post
    You could have the tank in a bag and secure that to the shell with velcro or snaps.
    Apr 2010
    Belgrade, Serbia
    45
    Received: 2/0
    Given: 7/0
    0
    Hmmm interesting thought, well let me try to find some electronic solution and it everything else fails I guess that will be it :-)
  1. Replies: 1
    Last Post: 04-20-2014, 01:59 PM
  2. Fender Twin Reverb/"custom" Vibrolux Reverb foot switch noise
    By mrkgtr49 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-19-2012, 12:16 AM
  3. Peavey Delta Blues - No Sound - All Tubes Glow - Powered "On", Made a "Hum", and died
    By Renegade44 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2009, 06:24 AM
