Results 1 to 15 of 15
Thread: Opinions: 1968 or so Sunn Sceptre with cabinet for sale
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,491
    Received: 168/0
    Given: 2,598/0
    5
    Hi All!
    Back in the day, I had a Sunn Sceptre head, loved the tone, sat in Dads attic until they moved and sadly it got tossed. I look on craigslist and reverb from time to time, they don't come up often.
    Found one on local craigslist, asking 750 with a cabinet. This is not a museum piece, but its not war torn either.
    Seller isn't a tech, so isn't posting gut shots and such. The one photo that scares me is that a bunch of paint looks to be burned off the PT, at least that's what it looks like.
    Can guess a few possible scenarios: bias goes flooey, tube goes bad, bad resistor etc, transformer overheats and is damaged but still barely works. Somebody buys the amp, and PT goes pouf.
    Price is reasonable as is, if its all there and works, I think. But anyone know where in the heck to get transformers for this amp, if its really toast?
    Also, might be way off on a tangent, its happened before <smile> might be that paint peeled off and a little rust set in from a long basement storage.
    Thanks,
    Mike
    The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,983
    Received: 2,274/7
    55
    Or moisture got under voids in the paint and the resulting rust peeled the paint. I sure wouldn't suspect that transformer from the visual. Note the rust on the power tube bases. Note the rust on the lams of the transformer.
    2 Not allowed! Not allowed!
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,491
    Received: 168/0
    Given: 2,598/0
    5
    Thanks Enzo, maybe just damp storage damage? If it plays well, and runs for half hour or so without emitting smoke, tending to want to buy it. Its couple of hours drive, so I have to arrange the trip.
    Without being able to take the chassis out, anything else I should look for, besides obvious, red plating, something overheating, .. ? Judging by the condition, betting it hasn't had the standard once over by a good tech, replace filter and cathode caps, check out resistors, etc.
    (oops, spelling correction)
    Near Dallas Texas
    3,566
    Received: 258/0
    Given: 130/1
    18
    Sunn transformers are not very corrosion resistant. Fender transformers from the same era (mid to late 60's) are better. Going back to the Tweed Fenders, you see more corrosion. The Sunn chassis and the chrome corners will also show corrosion. This degrades the value in my opinion. It means the amp was stored in an unheated garage or attic. Not worth the crazy money people ask for them. If you pay that crazy money, you'll kick yourself when the amp needs a three or four hundred dollar repair.
    1 Not allowed! Not allowed!
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,491
    Received: 168/0
    Given: 2,598/0
    5
    Quote Originally Posted by loudthud View Post
    Thanks, Loud. That was the reason for looking at this one, price. Its 750 with 2 x 10 cabinet. Most of the Reverb listings Ive seen were a lot higher. Ad says "not into negotiation", but .. meh, 750. Yeah, I bet this one needs all electro caps, few resistors, few signal caps. The stored in a damp environment thing does scare me a bit more. Wish this one was a little cleaner since its within driving distance.
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,491
    Received: 168/0
    Given: 2,598/0
    5
    Found a 30-20-20-20 525v can cap on antique electronic supply a little below 40 bucks. Someone on one of the MEF threads said something about the chokes going bad. Triode has one for 35 bucks. If the giant PT and OT are okay ... ?? worth 750 (with cabinet) assuming speakers are not toast?
    Feb 2010
    12,380
    Received: 2,032/24
    Given: 5,182/11
    24
    If it's working, I think you are ok if you are set on this model anyway.
    Near Dallas Texas
    3,566
    Received: 258/0
    Given: 130/1
    18
    Worth about half that with non-original 2x10 cabinet. It should have a 4x12 cabinet. Chances are it won't sell. Keep your eyes open for it to be re-listed in a month or two.
    Feb 2010
    12,380
    Received: 2,032/24
    Given: 5,182/11
    24
    Sorry, I'm not that familiar with the US market. I would trust loudthud's valuation, and I know he is on top of Sunn stuff.
    Supporting Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    1,364
    Received: 506/1
    Given: 426/0
    7
    Years ago, I used to have a Sceptre with the original speakers in a 4x12 cab. It's one of those ol' style 4x12 cabs that are about the size (and weight) of a small fridge.
    I remember when I listed the cab on craigslist, I priced it at like $200/$225 (something like that) to get some quick cash. Within about an hour or two, my inbox was filled with responses.
    I knew I probably priced it too low when many of them were written like they were applying for a grant, saying things like "Please consider me to sell this cab to", "I know you probably sold this, but if you haven't, I can meet you anytime and would really appreciate..."
    I would have probably pulled the ad and re-posted it, but I already agreed on a sale with the first guy I heard from.
    But, if I remember correctly, it has a pretty good sounding true phase shift vibrato. Right?
    Cornelius, Oregon
    1,424
    Received: 116/0
    Given: 209/2
    15
    Quote Originally Posted by SoulFetish View Post
    https://el34world.com/charts/Schemat...nn_sceptre.pdf
    They're using transistors for the trem and reverb.
    Personally I can't stand Sunn amps for guitar...hard and not very touch responsive and bright when clean, and when distorted much of the same with a harsh distortion. For bass I think they sound great though.
    Greg
  12. #12
    Near Dallas Texas
    3,566
    Received: 258/0
    Given: 130/1
    18
    The tremolo is just the opto type. If the opto goes bad, you'll have to experiment to replace it. Some low value electrolytics in the LFO that go bad. Reverb is tube drive, solid state recovery.
    Sunn guitar amps (exception Model T) are not very popular. A 200S bass amp in good condition (some wear but functional) with the original 2x15 JBL cabinet could go $750 to $1K. A 2000S (Noel Redding) with original JBL cab could go for twice that. They are more rare. The cabs are so big, they are hard to ship. A friend has a 2000S head for sale, PM me if interested.
  13. #13
    Supporting Member
    Mar 2017
    Massachusetts, USA
    1,491
    Received: 168/0
    Given: 2,598/0
    5
    Thanks everyone. Yeah, remember that the amps distortion was not good tube distortion. Thought the clean tones were ok. But, 40+ year memories aren't very accurate. Don't see them very often, but ... don't seem to sell either. Thinking.
  14. #14
    Cornelius, Oregon
    1,424
    Received: 116/0
    Given: 209/2
    15
    I used to have a 200S head and cabinet and sold it to get an SVT head. It was a particularly awesome sounding and original 200S too...early Dynaco transformer in a one chassis head rather than the earlier Smiley Face 2 chassis Sunns or the later Schumacher or Western transformer Company transformer heads. The SVT with the 8x10 was great too but I didn't need the power, and I have a complete 2000S head and cabinet that sound better so I kept that one. I've fixed many Sunn guitar amps, but have never owned one myself. Probably never will too haha. Of course all the classic tube Sunn guitar amps can be used for bass too, with the exception of the Model T likely.
    Greg
  15. #15
    Near Dallas Texas
    3,566
    Received: 258/0
    Given: 130/1
    18
    Model T's are awesome for Bass, but require a strong set of 6550's. Current prices in the 2K-3K USD range because they are hard to find. OT has a 2 Ohm tap and an impedance switch that won't melt. Can be used for guitar but they are really loud. Sometimes you can get them cheap because some wire wound resistors that protect the OT are smoked. A couple of 5W resistors and a fresh set of tubes and they are up and running.
  1. Sunn Sceptre
    By phillip.lynn in forum SUNN
    Last Post: 04-27-2012, 10:36 AM
  2. Sunn sceptre Gut shots????
    By baddog in forum SUNN
    Last Post: 07-30-2011, 07:15 PM
  3. Sunn Sceptre Head 1969
    Last Post: 04-29-2011, 05:48 PM
  4. Post PI master in Sunn Sceptre?
    By Boy Howdy in forum SUNN
    Last Post: 12-12-2009, 05:48 PM
  5. Sunn Sceptre
    By AdamN in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-10-2009, 05:55 PM
