Results 1 to 19 of 19
Thread: Univox U-102 Tube Amp
  1. #1
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    I picked up another Univox guitar amp. Its an early 60's Univox U-102. There's very little information on this amp. I was lucky to find a schematic. It has a 12" Jensen speaker that dates to 1965. Runs on a 6AU6, 2 - 12AX7s, a 6CA4 and 2 - 6AQ5s. Its all original with two prong power cord. The Suzuki caps and the remains of a Sansui label on the top of the cabinet give it away as made in Japan.
    3 Not allowed! Not allowed!
  2. #2
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,190
    Blog Entries
    1
    Thumbs Up/Down
    Received: 383/5
    Given: 275/0
    Rep Power
    11
    That is a beautiful amp! Looks to be very well made and it's in great condition. Thanks for sharing some pics. Would love to a picture of the speaker when you get to it. Score!!
    1 Not allowed! Not allowed!
  3. #3
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    Quote Originally Posted by DrGonz78 View Post
    Thanks! With little to go on I figured I'd take a chance. I plan on replacing the electrolytics and oil filled caps. Here are pics of the speaker. Someone wrote 16ohms on the basket, but it measures 5.7.
ID:	55774 Click image for larger version.
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    12,174
    Thumbs Up/Down
    Received: 1,924/24
    Given: 4,851/11
    Rep Power
    24
    Maybe at some point someone reconed it with an 8 ohm kit?
    0 Not allowed! Not allowed!
  5. #5
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    Quote Originally Posted by g1 View Post
    I just wrote it off as someone mistakenly labeling as 16ohms. But now you have me thinking. So I pulled the speaker. Here are pics of the cone.
ID:	55776 Click image for larger version.
ID:	55777 Click image for larger version.
  6. #6
    Supporting Member TomCarlos's Avatar
    Join Date
    Oct 2009
    Location
    Roseville, Ca.
    Posts
    818
    Thumbs Up/Down
    Received: 157/0
    Given: 265/0
    Rep Power
    11
    Just curious... back in the day when this amp was new, was Jensen selling the Gold Label speaker? (It looks like a Gold Label in the pics above). Take a look at this ad on Reverb.com. The speaker does say Special Design but it looks different - like the P12R square alnicos. https://reverb.com/item/1502030-vint...-great-tremolo
  7. #7
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    Quote Originally Posted by TomCarlos View Post
    I love the mysteries that come with these old amps. The markings on the speaker indicate 1965 production date. Unless its 1975. Here's a link to another U-102 with a blue label Jensen. This is the listing where I scored the schematic. Otherwise the schematic was nowhere to be found.
    https://reverb.com/item/3379137-univ...inal-reduction
    This is another U-102 listing with what appears to be a gold label Jensen.
    https://www.worthpoint.com/worthoped...ombo-140690892
  8. #8
    Join Date
    Oct 2009
    Location
    Roseville, Ca.
    Posts
    818
    Thumbs Up/Down
    Received: 157/0
    Given: 265/0
    Rep Power
    11
    Did you have a third link in your post? I do not see a link to the schematic. Can you please post that for us. Yes, this is a hard one to find!!
  9. #9
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    It was in the first link. The amp posting has pictures of the amp and one of pic is of the original schematic.
    I downloaded the image. Here it is.
  10. #10
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    13,026
    Thumbs Up/Down
    Received: 588/3
    Given: 306/0
    Rep Power
    28
    Here it is in pdf format: UnivoxU102.pdf
  11. #11
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    I finished recapping the U-102. I also replaced the rectifier tube socket and put on a grounded power cord. The volume is good. It actually sounds pretty good but something is a little off. I don't get a full spectrum of tone adjustment when I turn the tone knob. A small turn of the knob from all bass goes to all treble. Then 3/4 of the rest of the turning is all treble. Also getting breakup on the low notes all the time. I was short a cap when I replaced the 6AQ5 cathode bypass cap. The schematic calls for a 20/25. It had a 25/25. All I had on hand was a 47/50. Is that where my problem lies?Click image for larger version.
  12. #12
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    These are the voltages I measured:
    First filter cap - 331.7V
    Second filter cap - 294.8
    Third filter cap - 247.5
    6AQ5 plate - 325.6
    6AU6 plate - 154.2
    1st 12AX7 plate- 206.6
    2nd 12AX7 plate - 286.9
  13. #13
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    I take back everything I said. The amp sounds incredible!
  14. #14
    Join Date
    Jul 2011
    Location
    Adelaide, South Oz
    Posts
    750
    Thumbs Up/Down
    Received: 85/0
    Given: 4/0
    Rep Power
    9
    That 12AX7 Gain Stage/Phase Splitter is interesting.
    The first 12AX7 triode is a gain stage with a bootstrapped anode load resistor.
    The second 12AX7 triode is a Paraphase (Seesaw) Phase splitter.
    Cathode signal is fedback (as positive feedback) to input stage to bootstrap the anode load.
    Note the 50K anode load of Paraphase Splitter anode and the 100K cathode load resistor which is effectively in parallel with the 100K bootstrap resistor (the one from the top of the anode load to B+ node), so 50K load at cathode too.
    I have not seen this before.
    Cheers,
    Ian
  15. #15
    Senior Member trobbins's Avatar
    Join Date
    Jun 2010
    Location
    Australia
    Posts
    724
    Thumbs Up/Down
    Received: 101/0
    Given: 0/0
    Rep Power
    10
  16. #16
    Join Date
    Jul 2011
    Location
    Adelaide, South Oz
    Posts
    750
    Thumbs Up/Down
    Received: 85/0
    Given: 4/0
    Rep Power
    9
    That it exactly.
    CC Gain stage anode load and bootstrap resistor both 100K in lieu of 250K and 40K in the Wireless World Article.
    In the last SS Amp I did with bootstrapped VAS load I found the ratio of anode (Collector) load to bootstrap resistor was important for harmonic mix. In that case 33K VA load and 22K bootstrap resistor.
    Wonder if same is true for this Jeffrey circuit?
    Cheers
    Ian
  17. #17
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,708
    Thumbs Up/Down
    Received: 2,049/1
    Given: 1,172/2
    Rep Power
    5
    I think that (apart from bootstrapping part of the first triode's plate load) the PI essentially works as a Concertina/split-load type (the Jeffery article calles it "cathode follower PI"), and this:
    ... so 50K load at cathode too.
    ..is necessary for equal signal amplitudes at cathode and plate of the split-load PI (second triode of 12AX7).
    2 Not allowed! Not allowed!
  18. #18
    Join Date
    Jul 2011
    Location
    Adelaide, South Oz
    Posts
    750
    Thumbs Up/Down
    Received: 85/0
    Given: 4/0
    Rep Power
    9
    My Bad - I meant Cathodyne but brain short circuited and typed Paraphase.
    Cheers,
    Ian
  19. #19
    Join Date
    Jan 2019
    Location
    Rhinebeck NY
    Posts
    115
    Thumbs Up/Down
    Received: 69/0
    Given: 43/0
    Rep Power
    0
    I really like the sound of the Univox U102. I had a guitar play over yesterday and we made some recordings of all my amps. He wants this one. I told him not for sale. So now we have to look for another one.
    Unfortunately some pops got into the recordings but you still get the amp.
Thread Information
Users Browsing this Thread
  1. Need Help with Old MIJ Tube Amp (Univox?)
    By STLMatt in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-25-2017, 03:42 AM
  2. Univox U-45B
    By Shamus in forum Vintage Amps
    Last Post: 04-10-2016, 06:26 PM
  3. Help! Univox !
    By nuevoruido in forum Vintage Amps
    Last Post: 05-03-2009, 01:28 AM
  4. Univox 2x12 tall tube amp-japanese
    By Mars Amp Repair in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-13-2008, 04:43 PM
  5. Univox tube amp oscillates/feedbacks
    By mmcfarlane in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-08-2007, 10:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
