I sold one a few months back in perfect working order (even the reverb worked with mostly original tubes) for $400. It had some water damage to the cab. They used to be worthless. I can remember throwing 5 or 6 in a dumpster in the 1980s because the they weren’t worth re-tubing and saved the speakers for wedge monitors. A cult kind of started after Jack White hit and was using one. That demand has peaked I believe. They aren’t a good amp to gig with. The tube sockets don’t age well and you get lots of intermittences if you move them around much. Replacing tube sockets is a bear. If you get “weird” problems the first thing you do is retention the tube sockets.
Silvertone 1484 Twin Twelve
Originally posted by olddawg View PostI sold one a few months back in perfect working order (even the reverb worked with mostly original tubes) for $400. It had some water damage to the cab. They used to be worthless. I can remember throwing 5 or 6 in a dumpster in the 1980s because the they weren’t worth re-tubing...
I found a piece of plywood for a new speaker baffle. That and some epoxy should strengthen things up.
Originally posted by Helmholtz View PostNot sure which chinese brands you mean. But for decades the best, most advanced ecap technology has been coming from Japan (no matter where the production sites actually are), think Rubicon, Chemicon, Nichicon, Matsushita/Panasonic etc. as well as Europe (Evox/Rifa, Philips/BC now Vishay, Siemens/Epcos).
The ecap technology of Sprague (Atoms) and ILC must be considered inferior and outdated by today's standards.
I will defer to your experienced opinion Helmholtz, and continue to use my Chengx branded caps.
The ones I have installed still look good, and no failures or dimensional changes that I've seen so far in the past two years, so I will carry on !" Things change, not always for the better. " - Leo_Gnardo
Well I would hope even the most generic modern caps would be an improvement when replacing 50-60 year old caps. What I avoid when buying components is the snake oil expensive stuff that only cork sniffers would buy.When the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View PostWell I would hope even the most generic modern caps would be an improvement when replacing 50-60 year old caps. What I avoid when buying components is the snake oil expensive stuff that only cork sniffers would buy.
I've only been told the Chinese caps are inferior, never seen it so far in my short tenure as a tube amp guy.
I will defer to your experienced opinion Helmholtz, and continue to use my Chengx branded caps.Last edited by Helmholtz; 11-03-2019, 12:55 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostTo be clear, I can't comment on Chinese brands. I doubt they are comparable to japanese quality, might look similar, though.
If I was building or refurbishing an amp for a customer, I would indeed want to make sure all the caps were reliable, again for at least several years without any issues. Also, I would shotgun replace all caps in anything over 20 years old. I haven't automatically done that in my own amps, but I feel you would owe it to your customer to give them something reliable. I have changed my opinion on this, as I have bought vintage amps with all the caps bad in the last year, and they looked fairly good visually, and one can cap created a nasty short that took out a fat node resistor prior to the fuse blowing. So I wouldn't play a Russian Roulette game with a customer's amp. Only my own !Last edited by HaroldBrooks; 11-03-2019, 09:08 PM." Things change, not always for the better. " - Leo_Gnardo
Originally posted by tigerzilly View PostBaffle making time. The old one is good for a pattern. Thats about it.If you don't know where your going any road'll take you there : George Harrison
Originally posted by shortcircuit View PostThere goes the Silver tone.. Quite sure the masonite was all about $$$cheap$$$cheap$$$ production.
Originally posted by tigerzilly View PostThey used the same masonite board inside the chassis for mounting terminal strips. I thought it interesting that the old baffle is stamped "Made in Finland".If it still won't get loud enough, it's probably broken. - Steve Conner
Speaker cabinet is back together and speakers remounted. I replaced the all electrolytic caps except for the can capacitor, because I forgot to order a new base plate for the can cap. That's on order now.
I did another test and the amp and speaker sound good. I have to check the standby switch though. At first I thought I had very little volume then I realized it was on standby. I switched to operate and the volume is loud and sound is good. Not sure why I would hear any sound with the switch on standby.
The reverb works but I get feedback from it when I turn the reverb up much. I'll have to check into that.
I did some cosmetic work on the cab. I usually leave a vintage amp cab alone and accept the wear as part of the vintage thing. This had a few too many rips and missing pieces of covering so I touched the exposed wood with some paint. It still looks vintage, just not shabby.
Originally posted by tigerzilly View PostSpeaker cabinet is back together and speakers remounted. I replaced the all electrolytic caps except for the can capacitor, because I forgot to order a new base plate for the can cap. That's on order now.
[ATTACH=CONFIG]55913[/ATTACH] [ATTACH=CONFIG]55914[/ATTACH] [ATTACH=CONFIG]55915[/ATTACH] [ATTACH=CONFIG]55916[/ATTACH]
Greg
Sprague Atoms are purposely oversized, they make them to sell to nostalgic older technicians, and audiophiles wanting some sort of originality in their stuff. If you cut open an Atom, you will find inside a smaller sized cap plus empty space around it.Education is what you're left with after you have forgotten what you have learned.
