Crate TV60 Bad Output Transformer?
  • Crate TV60 Bad Output Transformer?
    Received this Crate TV60 with no tubes and told that it may have a bad OT.
    With all OT wires disconnected, on primary I have continuity from center tap to outer legs, reading 70 ohms and 90 ohms. Across both outer legs I cannot get a reading. The meter readout keeps jumping. I thought I would see the sum of the 70 and 90 ohms.
    Secondary looks okay on resistance readings.
    I also noticed that F5 is blown. F6 is okay.
    I have attached schematic. I do not think this amp is worth putting money into but I wanted to see if I can bring it back to operation as I have nothing else to work on right now.
    Thoughts on issues? Thank you
ID:	876072 Click image for larger version
    I have a DMM that jumps when taking readings as you describe. In my case its noise being picked up by the windings. I also get it with some pickups with the same meter. Even if you get readings that add up you could still have a shorted turn and this is not detectable with a DMM. You either have to use the 'neon trick' or get hold of a ring tester that essentially does the same thing in a more fancy way. Transformer failures aren't at the top of my list when I'm looking for a fault, but when they are defective a shorted turn is quite common.
    The OT has flyback protection diodes so that's reassuring. It could have just had a shorted output tube on the side where the fuse had blown.
      Thanks so far. It looks like I am missing some of the schematic. I do not see any output tubes on the one I have.
        The reason for the measuring artefacts is the high primary inductance (full primary has 4 times the inductance of a primary half) and the counter EMF generated when connecting the meter. (I could explain in more detail if someone cares.) It is actually a good sign showing that there are most likely are no shorted turns and that the winding is not open.
        Just short the secondary while measuring primary DCR to facilitate a stable reading.
          Here is the TV-120 schematic.
          TV-120 Schematic.pdf.zip
          It may help.
            Interesting. Not sure I have seen a circuit where each output tube has its own fused protection. Help me understand what is the general concept here. Thank you
              The power tube cathodes are fused. It helps prevent a bad tube from damaging other components, like screen resistors, or in worst case, transformers.
              The Marshall JCM900 series had them mounted on the rear panel, with indicator lights showing that a power tube fuse had blown.
                That worked!
                  That is what I always did, facing this.
                    Sure, the method is obvious to anybody who understands transformer (and meters).
