Mysteries of the Bench: Phantom coupling in Belair (Carvin Belair)
  • Mysteries of the Bench: Phantom coupling in Belair (Carvin Belair)
    Here's an interesting one:
    Amp: Carvin 2x12 Belair Combo
    Carvin_Belair_Schematic.pdf
    Issue: Customer complains of distortion and low output in the clean channel.
    After looking over the service order, I set the amp up on the bench for a play test and establish a base line. I confirm the clean channel has an overall unpleasant distortion on all level settings, and proceed to check the output on the scope.
    I can get a clean sine wave at the lowest volume settings, but the signal begins to clip hard very "early". The overdrive channel will starts out with clipping at the lowest gain settings. I normally would inject signal into the output stage to eliminate or confirm where the problem was, but I didn't this time (but I probably should have, it's good practice).
    Interestingly, the signal output did not show the problem as drastically as the audio test playing the guitar. One thing I noticed, was that the volume control on the guitar was loud and scratchy like there was DC on the pot. Using a dummy plug in the input, I measured around -700mV to ground at the input jack, and 0V when V1 was pulled. So, first things first, labeled his preamp tubes and installed known good bench tubes in the pre and output stages to eliminate bad tubes. The scratchy pot and bad distortion was still there, so I moved on to the next phase of checking voltages and signal tracing.
    Following the schematic, all the voltages at the relevant nodes in the clean channel checked out. But one thing I did notice was the voltage at pin 1 on V1 was +38V (indicating that the 220k resistor had gone open *measured around 9.1MΩ). Even though this stage is in the overdrive channel, and the plate is AC grounded in the clean channel, I had a suspicion that the low adjacent plate voltage was coupling into the clean channel input and causing our problems.
    My suspicion was confirmed after replacing the 1/4W 220k resistor with a 1W, and playing the clean channel again to find the high frequency response and clean headroom returned for it's normal function. We double checked that this was the cause and fix by opening up the plate again, just to be sure.
    All said and done, we were fortunate that we were able to find this one pretty quick. But I could have easily seen this one having us chase this ghost around for a while.
    Nice work! Yes, those type of issues can be dreaded quicksand for sure. Can you explain the mechanism of the coupling and problem it created?
      The fault caused the following audible symptom/problems (in no particular order of severity):
      • a noticeable drop in output volume.
      • loss of high frequency response. (similar to if the tone control was rolled off on a standard telecaster, or the treble and presence were turned all the way down on a typical FMV tone control)
      • ugly, "blatty" type distortion during pick attack. Seemed to be more pronounced on low notes. The audible distortion was present at all volume settings on the clean channel during a play-test.
      As far as a good technical explanation of the mechanism, I'm afraid I only have a suspicious as to what physically was going on to cause this. Perhaps one of our engineer colleagues, or someone who may have experienced something like this before can offer up a better explanation.
