Page 2 of 4 FirstFirst 1234 LastLast
Results 36 to 70 of 108
Thread: Peavey XR 696F - I made a booboo
  1. #36
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    This is very strange. Resistors almost never short. Is it's body marked as a 100K resistor?
    It was an SMD marked 104, I double checked with a magnifying glass in case my eyes were lying to me!
    1 Not allowed! Not allowed!
  2. #37
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,546
    Received: 2,068/7
    55
    R110/116 are not there as a voltage divider per se, they are bleeder/balance resistors for the stacked filter caps, C110/115. The resistors make sure the voltage is equally shared between the two caps.
    At Q103 you show the 86v rail turning into 48v at the collector, and then at the base it is both 48 and 86v. Obviously this is in error. The collector should have the full 86v as they are wired together. 48v on the base seems right, as it is set by the two 24v zeners in series. 34v output is very low.
    In my 65 years of soldering, I do not recall a shorted resistor. I guess it makes more sense in an SM part.
    2 Not allowed! Not allowed!
  3. #38
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Once I've had a decent nights sleep I'll go over all the measurements again. I'll take Q103 out so I can get a good look at the tracks running under it to see where they go as its possible I've crossed paths trying to follow them, maybe I should take measurements with Q103 removed. Looking over my notes I don't seem to have "ticked" Q103 as replaced, seven others have a tick but not that one, so best I take it and be sure!
  4. #39
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    OK I popped out the Q103, it tests fine, so i think I did replace it, but I have two spare so I can always pop in a fresh one. Measurements on the pads, left to right are;
    0.2v / 86.4v / 48.4v
    EDIT:
    Is the silk screen for the transistor orientation wrong?! E should be on the first pin on the left, but the silk screen would have B on the first pin on the left, which is wrong.
    I swapped the transistor around and it's now passing 47v
    Now to carry on trouble shooting the rest of it!
  5. #40
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    I've never seen that silk screen symbol, but I also would have read that as 1,2,3 left to right, but since R111 is connected between base and collector (1 and 2) then it has to be 3,2,1 Maybe the dashed lines are supposed to represent a heatsink on that transistor?
  6. #41
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Quote Originally Posted by glebert View Post
    It's definitely happier now it's the other way around. Looking at the Peavey schematic, there is a subtle difference in the part number for Q103, it's 2SC4793V all the others on the board are 2SC4793D. 2SC4793V is only listed once on the bill of materials. Maybe it was a short production run of reversed pin out versions? Google doesn't help, I can't find a mention of it anywhere other than Peavey related things.
    The bright light bulb indication has now switched places. We have a bright bulb and Q107/Q110 heating up with HDR100 + J107 connected. HDR100 + J202 no longer cause a bright bulb.
    I think I'm making progress?
  7. #42
    32,546
    Received: 2,068/7
    55
    V means vertical. OEMs can specify lead configuration. Like TDA7293 or TDA2050 cone in H and V versions. V versions have the two rows of legs bent to the thing stands up on the board. The H version has them bent at right angles so the thing can lie flat. No difference in the part, just the way the legs are bent as supplied.
  8. #43
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Good to know
  9. #44
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    I've had a little time to poke around today, I found CR100 (1N4148) shorted, it's part of the "Off Mute" circuit (very bottom of the first page), i removed it to confirm and replaced with with a through hole with its legs cut short for now. I think Q1 (J111 N-channel) might have a problem, I read 30ohms between G to D and D to G, in either direction, I'll need to remove it to test fully. Q2 doesn't test the same and has very high resistance G to D.
  10. #45
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Q1 is dead, Q106 (page 1, middle right) is also dead, currently awaiting spares
  11. #46
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    OK I can't find Q106, an SDS-7204 this side of the pond!
  12. #47
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    Quote Originally Posted by jondoe View Post
    I see 7204 spec'd as a 300V 10mA NPN transistor, but I have no idea why you would need such a high voltage rating for Q106, since it is on a 25V rail. There should be many TO-92 NPNs will work there. If the pinout is oddball you can bend legs around to reorient them. I'm sure someone will correct me if I'm wrong.
  13. #48
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Seems like quite a meaty transistor!
    I found this Peavey transistor cross reference document;
    Peavey_Transistor_Cross.pdf
    It recommends a 2N6557 or MPS-U10, both of which I also can't source for anything less than the price of a kidney. Would it be advisable to also change Q117, so there are a pair of new transistors?
    Thanks!
  14. #49
    Dec 2009
    Devon, UK
    3,604
    Received: 804/1
    Given: 624/1
    14
    Thanks!
    Dang - wrong part - deleted
  15. #50
    Feb 2010
    12,060
    Received: 1,830/24
    Given: 4,684/11
    23
    Quote Originally Posted by nickb View Post
    RS have them in packs of 100 for 8.80 for 100 https://uk.rs-online.com/web/p/products/8051129/
    You won't have to worry abut running out of them!!!!! Ever!
    Nick, that's a 6517 rather than 6557, is that what you meant?
  16. #51
    Dec 2009
    Devon, UK
    3,604
    Received: 804/1
    Given: 624/1
    14
    No I didn't mean that but I see what happened. I searched for the required part and it brought up the wrong one (nearest lexical match- how dumb is that?) and didn't spot it. Well spotted - thanks. Updated post.
    Can't find a decent cross for the moment. If I get time I'll try later.
  17. #52
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Thanks Nick, I'm glad it was well past the 8pm order cut off when I saw this last night
    Would the following be a suitable replacement?
    https://uk.rs-online.com/web/p/bjt-b...stors/7613701/
  18. #53
    Dec 2009
    Devon, UK
    3,604
    Received: 804/1
    Given: 624/1
    14
    No, that will fry. The best I came up with was an MJE340 but the pinout is wrong and it's a bit slow. Might work at a push.
  19. #54
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    Just curious why you think this needs a 20W transistor?
  20. #55
    Dec 2009
    Devon, UK
    3,604
    Received: 804/1
    Given: 624/1
    14
    It doesn't, but it 's the best I could find for the moment that would not evaporate.
  21. #56
    32,546
    Received: 2,068/7
    55
    The originals are 10w parts, that is why the little MPSA would burn.
    We can deal with the legs in different order by turning the part sideways.
    I still have a few 6557 as well as a coupl MPSU10, but in similar parts, I usually just find a TO220 from my stock.
  22. #57
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    To educate me, I don't understand how a 300V 10mA rated transistor can be a 10W device, that sounds to me like 3W or less, but I can't find any info other that that on these parts. I have never looked at one in person to know how big, etc. In this specific case, the max voltage C-E would be less than 115V, and the current should be less than 10mA (per original part spec), right? The MPSA part at 625mW might then be at risk of burning up, but 10W seems overkill.
  23. #58
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    The Peavey suggested replacement 2N6557 is a 2W part, were the originals just very over spec'd for some reason?
    I just found this CEN-U10, it's a direct replacement for the MPSU10, which itself is a recommended alternative part on Peaveys list. It's a little expensive per unit and a 16 week lead time on Mouser It's look like the MJE340 and hoping it fits in around the heat sinks!
    On closer inspection the one I removed from the amp was actually an MPSW42, which looked factory!
    Last edited by jondoe; 11-21-2019 at 01:06 PM. Reason: realised the one that came out was a MPSW42
  24. #59
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    Amplifiedparts has the original in stock and looks like they ship internationally. https://www.amplifiedparts.com/produ...7204-300v-10ma
  25. #60
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Well I'll be damned, after looking through ebay I found some new old stock MPSW42 (10 of them), which come out at the same price as the SDS 7204 after you take shipping into account. I've ordered those
  26. #61
    32,546
    Received: 2,068/7
    55
    Ah. I have MPSW42 and MPSW92 in my hand as I write. Eight of each.
  27. #62
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    Only 3500 miles away!
  28. #63
    Sep 2011
    Pace, FL
    3,313
    Received: 1,164/102
    Given: 162/36
    12
    Do you have various parts in candy dishes around the house for when a tech swings by to say hi? 😁
    Nosaj
    3 Not allowed! Not allowed!
  29. #64
    Dec 2009
    Devon, UK
    3,604
    Received: 804/1
    Given: 624/1
    14
    I fear those uniwatt packages will overheat and die in short order. The original is 2W in free air, 10W on a large heatsink. The MPSW42 is 1 watt, 2.5 if you can keep the case at 25C or less.
    Is the SDS-7204 mounted on a heatsink or not?
    I would go with the MJE340.
  30. #65
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    They were not mounted to a heat sink, just folded down a little out the way from it. MPSW42 was the part fitted to the amp, even though SDS-7204 is on the schematic.
  31. #66
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    deleted
  32. #67
    Dec 2009
    Devon, UK
    3,604
    Received: 804/1
    Given: 624/1
    14
    Ah! In that case you've solved that problem at least!
  33. #68
    Feb 2010
    12,060
    Received: 1,830/24
    Given: 4,684/11
    23
    I hope those are not coming from China. Those MPSW42 & 92 are now extinct, hard to find, and probably being counterfeited.
    The SDS-7024 from Amplified Parts is the same style package as those MPSWs (TO-226). I'm guessing Peavey subs on that cross-x were the next size up that could handle the power.
  34. #69
    Supporting Member
    Aug 2017
    Portland, OR
    784
    Received: 277/1
    Given: 113/2
    3
    It's not like this is the only part that got fried in the unit.
  35. #70
    Nov 2018
    United Kingdom
    203
    Received: 53/0
    Given: 179/0
    2
    I have quite the pile of dead parts, but at least I'm learning a few things as I go
    I hope those are not coming from China. Those MPSW42 & 92 are now extinct, hard to find, and probably being counterfeited.]
    They are coming from a UK ebayer who has a great number of audio parts, mostly old used parts and new old stock. Fingers crossed
  1. Replies: 36
    Last Post: 12-22-2016, 10:13 PM
  2. Peavey XR-696F Powered Mixer - Strange Noises
    By misterc57 in forum Other Amps
    Last Post: 12-11-2014, 02:39 AM
  3. Peavey XR-696F (XR696F) Powered Mixer
    By misterc57 in forum Schematic Requests
    Last Post: 11-15-2014, 02:38 PM
  4. diode rectifier in a 5f2-a princeton - did I booboo?
    By mort in forum Debugging Your Build
    Last Post: 07-22-2014, 05:48 AM
  5. Peavey Delta Blues - No Sound - All Tubes Glow - Powered "On", Made a "Hum", and died
    By Renegade44 in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2009, 06:24 AM
