Results 1 to 8 of 8
Thread: Need Schematic for Splawn Quick Rod
    May 2010
    Sioux Falls, SD
    6,365
    Received: 1,254/1
    Given: 969/1
    16
    As the title says, looking for a schematic for the Splawn Quick Rod. I need the early version with only 3 12AX7 tubes. I have the newer version schematic with 4, but not the same. Someone has gotten into this thing and made a mess of it doing mods. The customer wants it back to original.
    FWIW: I contacted Splawn. They said they do not even have schematics. I call bullshit. Who builds amps without schematics? If you don't want to release schematics, just say so. Don't tell me you don't have them.
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    1,226
    Received: 432/1
    Given: 361/0
    6
    Dude, we just had a Splawn in last week. Same thing. We called up, and he said he never made any drawings (schematics) of the amps. We thought the same thing. I call bullshit too.
    You're trying to tell me you designed 2-3 PCBs with Eagle or some 'board house software, but didn't bother to make any schematics??
    ...to check them against?
    1 Not allowed! Not allowed!
    Supporting Member TomCarlos's Avatar
    Oct 2009
    Roseville, Ca.
    756
    Received: 120/0
    Given: 230/0
    11
    May 2010
    Sioux Falls, SD
    6,365
    Received: 1,254/1
    Given: 969/1
    16
    Well (no thanks to Splawn) I figured out the amp anyway, so no rush on finding a schematic. Someone had decided to turn the "SOLO" footswitch into a switch for the "EFFECTS LOOP". They had cut traces, removed resistors, glued a relay to the loop board, and other fun messes. I got it all back to right with just some common sense and thinking about what I might do if I were going to modify the amp for this purpose. Everything works as it should now.
    A little kicker at the end of the repair, though. I had very little clean channel volume. Traced out all the LDR's trying to figure out if something wasn't switching right. Everything was switching correctly, but I noticed that when the clean channel is switched to the PI circuit, some of the controls for the OD channel were still in line. Turned up the OD gain and the clean channel was nice and loud. Chased this around for a while thinking there was a problem. After a little web research, it turns out the early Quick Rods worked this way. The overdrive channel gain also drives the clean channel. A bit odd, IMO.
    2 Not allowed! Not allowed!
    May 2010
    Sioux Falls, SD
    6,365
    Received: 1,254/1
    Given: 969/1
    16
    Thanks Tom, but both of those are the 4 12AX7 versions. It's deceiving because they don't show the PI in some of those schematics. I do appreciate the effort, though!
    Nov 2013
    305
    Received: 118/11
    Given: 39/0
    7
    do you mean there is only the gain channel,not the clean one?
    i have a Competition schem ,it should be like what you have,can you post a couple pics of the preamp part?
    May 2010
    Sioux Falls, SD
    6,365
    Received: 1,254/1
    Given: 969/1
    16
    Quote Originally Posted by alexradium View Post
    The amp has already left the shop. There are/were 2 channels- a clean channel and a dirty channel. The dirty channel also had a more/less drive switch, so kinda sorta 3 channels. The gain knob was grouped with the overdrive channel controls, but also controlled the clean channel gain. Sort of odd, I thought. However, through gain structuring, the gain knob did not provide as much overdrive to the clean channel as it did to the dirty channel. I hope that makes sense. If not, I'm happy to elaborate.
  1. Quick question on old schematic... Not sure what to use.
    By tubedood in forum Theory & Design
    Last Post: 06-11-2018, 09:47 PM
  2. Quick quick question re Series resistor power handling
    By emenasche in forum Guitar Amps
    Last Post: 04-01-2017, 09:55 PM
  3. In need of a Splawn Pro Mod schematic.
    By Redline in forum Schematic Requests
    Last Post: 02-25-2017, 03:38 AM
  4. What did I break? Splawn content
    By Exodus5 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-03-2017, 06:55 PM
  5. Splawn amps
    By Valvehead in forum Theory & Design
    Last Post: 09-18-2007, 04:18 AM
