Page 2 of 2 FirstFirst 12
Results 36 to 55 of 55
Thread: Silvertone 1484 Restoration - almost there, but need assistance!
  1. #36
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Yeah - it is strange. If I take a reading from the voltage doubler it is also only pumping out around 450v when it should be 480v. I did replace all the old caps in here with 100uf / 450 caps. Will need to double check my work as seems odd that it’s 30v shy of where it should be.
    All of the original diodes in the doubler tested ok using the diode test on my DMM so left them in there. Could a degraded / poorly functioning diode cause this? I could always replace them with IN4007s I guess.
    0 Not allowed! Not allowed!
  2. #37
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,145
    Blog Entries
    1
    Thumbs Up/Down
    Received: 347/5
    Given: 239/0
    Rep Power
    11
    What's on schematics doesn't always match up perfectly. Typically it's higher B+ readings since line voltages were lower back when these amps were made. Maybe there were versions of the amp that had lower B+ with certain batches of transformers than what's on the schematic. Not sure if the diodes could drag down the B+ voltage. How accurate is your bias probe?
    1 Not allowed! Not allowed!
  3. #38
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,369
    Thumbs Up/Down
    Received: 1,802/1
    Given: 1,028/2
    Rep Power
    5
    They might be rated at 30 watts and not 25 watts.
    Good point, indeed.
    Would like to add that there is absolutely no good reason to bias a 30W 6L6 hotter than a 25W one. Bias determines idle current and idle current (not idle power dissipation!) determines performance (crossover distortion etc.) As all 6L6 and 5881 types can be expected to share more or less the same operating characteristics (otherwise they wouldn't be 6L6/5881 types) independent of limiting data, optimum idle current should be the same for all of them.
    Major difference is that a 30W 6L6 can be used with a higher plate voltage than a 25W tube at the same idle current. But within the 25W PD limit operating conditions and electrical performance should be essentially the same.
    2 Not allowed! Not allowed!
  4. #39
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,369
    Thumbs Up/Down
    Received: 1,802/1
    Given: 1,028/2
    Rep Power
    5
    I wouldn't worry about a difference of 6%. That's well within the daily variation of line/mains voltage. What was your mains voltage during measurements? What exactly is your heater voltage?
  5. #40
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Helmholtz
    Heater voltage is 6.2v and wall voltage 122v.
    I’m not too worried - just wanting to be sure it’s all operating ok before I put it back together.
    Noting the 28ma bias - should I be reducing the value of the bias resistor to try and get it closer to 70%, maybe around 36ma?
  6. #41
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,145
    Blog Entries
    1
    Thumbs Up/Down
    Received: 347/5
    Given: 239/0
    Rep Power
    11
    As far as this internet lore of 70% of max idle dissipation, I don't follow along. Most traditional tube amps that I bias are somewhere between 40-60% max idle dissipation. I am all about tube lasting longer rather than running them hotter for a shorter life.
    In the case of the old silvertone amp being discussed. If the amp was on my bench I would be more interested in installing adjustable bias capability, so I could easily install an array of different output tubes and bias them easily.
  7. #42
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    You’re singing my tune.
    I’d just ordered a 50k linear taper pot just for that purpose.
    I’m doing some reading I am lead to believe these amps were generally biased cold from the factory. Which is why the power tubes last in them so long - and many still have the stock power tubes going strong.
    I’m not religiously about the 70% I generally use it as a guide. I usually bias largely by ear once in the ballpark to what sounds good to me.
    The bias pot will enable this to be done a little easier.
  8. #43
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,163
    Thumbs Up/Down
    Received: 1,891/7
    Given: 0/0
    Rep Power
    55
    Me too, forget the 70% internet thing. Most amp makers and many techs bias amps cooler than that, there is no right and wrong. Well... So cold you get massive crossover distortion is wrong one way, and so warm the tube get red hot is wrong the other way. Between those, whatever sounds good IS good. it is just a guitar amp, nothing precision about it.
  9. #44
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,369
    Thumbs Up/Down
    Received: 1,802/1
    Given: 1,028/2
    Rep Power
    5
    Now this is just perfect.
    Yes, 28mA cathode current looks a bit cold, meaning around 25mA real plate current. You may verify using the OT primary DCR biasing method (but pull the PI tube before measuring plate voltage to avoid oscillation).
  10. #45
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Once I receive the pot I’ll install and experiment and report back on where I settled in terms of bias.
    In the meantime I’ll recheck the voltage doubler circuit to ensure all connections are where they should be and are solid. May consider replacing old diodes in there with IN4007s but generally don’t like replacing parts for the sake of it. Though I suppose there is the argument these are now 55 year old diodes and putting new ones now is a good opportunity and good insurance. Something to cogitate on while wait for the bias post.
  11. #46
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    The 50k linear pot arrived today. I didn’t have a lot of time to play around today but got it installed and did a little bit of testing and adjusting. Appears noting is ever easy as I found the as I lowered the bias pot value I would only get a very slight increase in bias but a notable drop in supply voltage until I got to a point where there was notable background hum.
    I’m doing some brief research could be because these amps are grid leak biased as opposed to fixed bias? Did some quick reading on this and that the amp benefits from a “bias voltage doubler” - no as simple as just replacing the bias resistor with a bias pot it would seem. So now considering just putting the 100k resistor back in and leaving as is.
    PS I ended up replacing the old diodes. Thought it good insurance. Didn’t change any of the voltages however.
  12. #47
    Join Date
    Feb 2010
    Location
    Posts
    11,843
    Thumbs Up/Down
    Received: 1,672/24
    Given: 4,309/11
    Rep Power
    22
    What method are you using to measure bias?
    If B+ is dropping to the point of hum, you are making a big change in bias.
    For some reason there is a problem with the bias measurement and it is not showing the change.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  13. #48
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Hi g1,
    I’ve been using a Eurotubes bias probe and a fluke DMM. One I’ve had for around 10 years and use to bias all my other amps. Based on this I can get one about 29ma out of the bias pot(50k pot with a 50k resistor). But likely going to draw a line under this one. Based on the schematic for the bias mod I should be getting between -18vdc and -36vdc from the bias pot and I’m getting -32vdc. So I’m thinking that’s good enough. All preamp, reverb and tremolo voltages are all good. Per previous discussion the voltage doubler and power section voltages are slightly low but am lead to believe nothing to be concerned about. The amp is sound good where it is, with little to no audible hum, even when dimed. The reverb is working great and sounds pretty good. So all in all the amp is going great and sounds good. So I think this one is pretty much done.
    I’d like to thank you all for your very helpful input. This has been an enjoyable restoration and I really appreciate the discussion in this thread. Hopefully my update reverb schematic will come in handy to those who want to update the 1484 reverb with something usable at minimal cost and change in parts.
  14. #49
    Join Date
    May 2006
    Location
    Posts
    32,163
    Thumbs Up/Down
    Received: 1,891/7
    Given: 0/0
    Rep Power
    55
    How is your bias pot wired in? Just making the 100k resistor variable won't do it.
    There is no grid leak bias in this amp. The power tubes are using fixed bias. Adjustable bias is still fixed bias.
  15. #50
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Hi Enzo
    I follow this schematic that I found on a 1484 mods website:
    https://www.dropbox.com/s/sp0s2mifp9...%2013.jpg?dl=0
  16. #51
    Join Date
    May 2006
    Location
    Cornelius, Oregon
    Posts
    1,419
    Thumbs Up/Down
    Received: 111/0
    Given: 206/2
    Rep Power
    15
    As Enzo said, these amps are non-adjustable fixed bias. There is an error on the commonly available 1484 original schematic. Actually two errors. The first is that they show the grid resistors of the power tubes grounded where the negative bias voltage is coming in. Those are not really grounded there. Second error is on the trem tube...they have pins 6 and 8 reversed. Move the numbers and everything is correct.
    The bias supply needs to be voltage doubled and then it will work in the correct range. Add an adjustment pot in there and it works fine. I forget the values I used but it wasn't hard to do. I posted a whole bunch of info on the mods I did to my brother's 1484 over at the Hoffman amps forum maybe 10 years ago. These amps are only about 25 watts RMS btw.
    Greg
    P.S. If you really want to know what I did for the voltage doubler circuit to get adjustable bias, let me know and I can go look at my schematic in the garage. Too lazy right now to go find it.
  17. #52
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Hi Greg,
    Thanks for the info. I had stumbled across the documented errors in the schematic - so have been working around those. No problems there.
    I have seen your posts on other forums regarding the mods done to your brothers amp. I read this with much interest. I also saw your comments about the voltage doubler for the bias supply, but alas, could not find any schematics and would rather not attempt it without a schematic. I think I have a reasonable idea but would want to be sure before giving it a go. If you wouldn’t mind digging out the schematic that would be much appreciated. I am lazy too - hence the minimalistic reverb upgrade! I’m happy to give the adjustable bias another go using the voltage doubler.
    And yeah - had read these are rated 20-25w despite the 60w marketing!
  18. #53
    Twobie
    Join Date
    Nov 2019
    Location
    Brisbane, Australia
    Posts
    28
    Thumbs Up/Down
    Received: 9/0
    Given: 9/0
    Rep Power
    0
    Greg
    Stand down in looking for the schematic. I did some googling and found the schematic for voltage doubled bias for the 1484 from Gerard Weber’s book. I have installed this circuit and it works great. Bias now sitting around 34ma and seems to be happy there. Thanks very much for your input and advice.
    Time to put this old girl together and enjoying playing through her.
    Thanks again hi everyone for your advice and input.Another amp lived to fight another day!
    3 Not allowed! Not allowed!
  19. #54
    Join Date
    May 2006
    Location
    Cornelius, Oregon
    Posts
    1,419
    Thumbs Up/Down
    Received: 111/0
    Given: 206/2
    Rep Power
    15
    Quote Originally Posted by q9522678 View Post
    Greg
    I'm glad you were able to get it all sorted out! I just saw your messages today, so I'm happy I don't have to go look for the schematic.
    I've got one of these that is completely stock and reverb and trem surprisingly work perfectly, but the rest of the amp has issues and needs new resistors and caps in some areas. One of these days I'll get around to fixing it.
    Enjoy your amp!
    Greg
  20. #55
    Join Date
    May 2006
    Location
    Posts
    32,163
    Thumbs Up/Down
    Received: 1,891/7
    Given: 0/0
    Rep Power
    55
    Some schematics are harder to find than others. But in following the thread I have found it esiest yo just google SIlvertone 1484 and so many copies of the schematic pop up, I can choose almost at random.
Thread Information
Users Browsing this Thread
  1. Silvertone 1484
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-24-2013, 03:48 AM
  2. Silvertone 1484 Low Output. Possible bad OT???
    By 1WoodHippie in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-06-2011, 01:38 PM
  3. Silvertone 1470 restoration
    By wagdog in forum Repair and Restoration
    Last Post: 08-12-2011, 05:29 PM
  4. Silvertone 1484 help needed
    By waltk in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-19-2009, 01:30 AM
  5. Silvertone 1484
    By SavageHenri in forum Vintage Amps
    Last Post: 11-07-2006, 01:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
