Results 1 to 5 of 5
Thread: Peavey VTM 120 Won't Turn On
    New Member
    Nov 2019
    2
    0
    Hello everyone, my Peavey VTM120 was plugged in at my apartment in my home recording setup. It was working fine for an hour of playing. I then turned it off and when I turned it on it powered on and then the lights seemed to get brighter on it and the whole amp shut off. It will now not power on at all with no lights showing at all. What could have happened and how could I possibly go about fixing it?
    May 2010
    Sioux Falls, SD
    6,703
    Received: 1,505/1
    Given: 1,118/1
    17
    https://www.thetubestore.com/lib/the...-Schematic.pdf
    You likely blew a fuse in the amp. There are 4 fuses and if one blew, it's for a reason. If you can tell us which, if any fuses blew, it might point us in the right direction. The most likely cause is a bad tube or tubes.
    1 Not allowed! Not allowed!
    New Member
    Nov 2019
    2
    0
    I appreciate the schematic but I'm a bit of a novice when it comes to electronic repair. Could anyone give me a place to start looking for problems?
    May 2010
    Sioux Falls, SD
    6,703
    Received: 1,505/1
    Given: 1,118/1
    17
    Post edited. See above.
    NYC
    1,658
    Received: 9/0
    15
    You'd have to find the fuse that blew.Replace it and plug into a current limiter (light bulb in series) and check for a short.If you get a short indication on the light bulb,begin pulling the tubes one at a time til the bulb dims and locate the short.Or take it to a tech.
  1. What's happens to the PT when I turn my amp up?
    By leadfootdriver in forum Theory & Design
    Last Post: 12-15-2016, 12:37 PM
  2. Peavey XR684 turn on/off thump.
    By Check.. 1,2 in forum Other Amps
    Last Post: 06-22-2016, 12:30 AM
  3. What to do with my 5E3? What can I turn it into?
    By jrdamien in forum Guitar Amps
    Last Post: 03-26-2014, 11:53 PM
  4. Peavey Combo 300 won't turn off
    By booj in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-23-2010, 06:28 PM
  5. peavey classic 50 won't turn on, burnt cap.. help!
    By rasdestroyer in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-11-2008, 09:23 PM
Tags for this Thread
