Results 1 to 3 of 3
Thread: Randall MTS module volume difference
    Supporting Member
    Dec 2009
    UK
    3,572
    Received: 297/0
    Given: 40/0
    14
    I have a Randall MTS with a volume difference where the owner considers the Deluxe module is lower in overall output than the Top Boost or SL Plus. It doesn't actually seem too bad to me - just a difference where the level knobs need to be set to get equal volume. So with the Deluxe module the level would need to be set to 8.5 where the others are set to around 5 (other controls being set the same).
    The transistors and optocouplers check out OK and the tubes have been recently swapped.
    Is anyone more familiar with thee amps and is this normal? It just seems to me to be the same kind of thing where customers complain that "my mate's amp is on 4 and blows your head off but I need to set mine to 7 for the same volume and they're both 100W"
    Nov 2013
    318
    Received: 124/11
    Given: 40/0
    7
    Quote Originally Posted by Mick Bailey View Post
    yes,the last one,never understood why people are afraid to turn knobs....
    one reason can be because of the different topology,the BF module has more loss after the tonestack than a Vox/Marshall and there is a big attenuation between 2nd and 3rd stage,while the british ones are more straight forward.
    Supporting Member
    Dec 2009
    UK
    3,572
    Received: 297/0
    Given: 40/0
    14
    I wondered if there was an internal level compensation somewhere to even things out, but taking a look at some of the schematics for the modules agrees with what you'e saying - the topology is fairly consistent with the original amps and this accounts for the differences. If the gain control is raised with the Deluxe to give a similar saturation to the SL+, then the level controls pretty much agree and the volume is consistent when switching channels. I'm as certain as I can be that there isn't a fault.
  1. Randall RH150 volume cutting
    By Durrant Pickups in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-08-2013, 07:05 AM
  2. Randall RG50TC Volume problem
    By UnluckyFett in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-18-2012, 01:51 AM
  3. Modding Randall MTS Plexi module
    By Bukak65 in forum Mods & Tweaks
    Last Post: 08-21-2012, 07:15 PM
  4. Power/Volume difference Tube vs Solid State
    By 888guitars in forum Guitar Amps
    Last Post: 05-07-2011, 12:33 PM
  5. Randall RG50-HT low clean volume
    By Prairie Dawg in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-17-2011, 05:22 AM
