Results 1 to 11 of 11
Thread: Superior TV-11 Tube Tester
  1. #1
    Join Date
    Jan 2018
    Location
    Mass. U.S.A.
    Posts
    216
    Thumbs Up/Down
    Received: 10/1
    Given: 6/0
    Rep Power
    2
    I was just given a Superior TV-11 tube tester. It needs a little work that will not be to bad.
    The main problem is the meter adjustment is not working correctly. I opened it up and found that a couple of winding's on the the adjuster are burnt. SCHEMATIC AND PHOTOS ATTACHED.
    Would like to know what could be used to replace it?
    The schematic shows it as a 250 Ohm but the one installed reads 350 Ohm.
    0 Not allowed! Not allowed!
    It's all about the bass. Lock in the groove and stay out of everyone else's way.
  2. #2
    Join Date
    Feb 2010
    Location
    Posts
    12,040
    Thumbs Up/Down
    Received: 1,812/24
    Given: 4,652/11
    Rep Power
    23
    I would call that 'line adjust' rather than meter adjust. I doubt it gets used near either end so a 250 or 350 should both work there, the wattage rating would be the important spec.
    Is it working aside from those bad spots? And they are right in the area of most use? If so, if it was mine I would swap the wires to the ends around which should move the bad spots to an unused section.
    1 Not allowed! Not allowed!
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  3. #3
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,514
    Thumbs Up/Down
    Received: 2,047/7
    Given: 0/0
    Rep Power
    55
    Agree^^^
    Value is not critical. Wattage is though. The 0.27A rating on the part with the 350 ohms leads me to think it is a 25 watt part. It LOOKS like a 25w part.
  4. #4
    Join Date
    Jan 2018
    Location
    Mass. U.S.A.
    Posts
    216
    Thumbs Up/Down
    Received: 10/1
    Given: 6/0
    Rep Power
    2
    G1
    It is used to set the meter in the center of it's range. Appears to be in the area of most use.
    When turning it to set the meter the needle starts to move up but before it is centered the pot reaches the broken spot. When it's turned past the break, the meter jumps up past the center and I can hear a growl.
    Tried the tester without centering the meter with the pot set just before the break. Everything appears to work OK. I haven't checked any of the resistors in the unit. I bet both of the caps in it are bad.
  5. #5
    Join Date
    Jan 2018
    Location
    Mass. U.S.A.
    Posts
    216
    Thumbs Up/Down
    Received: 10/1
    Given: 6/0
    Rep Power
    2
  6. #6
    Join Date
    May 2006
    Location
    Posts
    32,514
    Thumbs Up/Down
    Received: 2,047/7
    Given: 0/0
    Rep Power
    55
    Should work, yes.
  7. #7
    Supporting Member
    Join Date
    Dec 2009
    Location
    UK
    Posts
    3,585
    Thumbs Up/Down
    Received: 307/0
    Given: 43/0
    Rep Power
    14
    The tester has a 2-wire mains connection with no earth and no isolation, though.
  8. #8
    Join Date
    Jan 2018
    Location
    Mass. U.S.A.
    Posts
    216
    Thumbs Up/Down
    Received: 10/1
    Given: 6/0
    Rep Power
    2
    Thanks Enzo
  9. #9
    Join Date
    Jan 2018
    Location
    Mass. U.S.A.
    Posts
    216
    Thumbs Up/Down
    Received: 10/1
    Given: 6/0
    Rep Power
    2
    Mick
    You are correct
  10. #10
    Join Date
    Feb 2010
    Location
    Posts
    12,040
    Thumbs Up/Down
    Received: 1,812/24
    Given: 4,652/11
    Rep Power
    23
    One side of the line goes straight to that pot. That's why I call it line adjust. It affects the meter by adjusting the voltage going to the whole unit.
    I still say you should swap the end wires around and see if it is still a problem. I think it will work fine that way.
  11. #11
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,585
    Thumbs Up/Down
    Received: 1,948/1
    Given: 1,114/2
    Rep Power
    5
    I wouldn't use the thing without an isolating transformer.
Thread Information
Users Browsing this Thread
  1. Bought a tube tester and need 9 pin adapter for octal tube socket
    By kka in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-02-2012, 06:34 AM
  2. Tube tester
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-23-2011, 10:03 PM
  3. bk 747 tube tester
    By oo3 in forum Music Electronics
    Last Post: 08-09-2010, 09:55 PM
  4. B&K Tube Tester & output tube question
    By Chevy in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-13-2008, 02:08 PM
  5. How to use a tube tester
    By MitchK in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2007, 10:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
