Results 1 to 26 of 26
Thread: Roland Super Cube 100 LED
  1. #1
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    I have a Roland Super Cube 100 (not bass version) with an power indicator LED that isn't lighting up. The circuit is foreign to me and is different than what you see in the schematic for the bass version. I'm uploading images of the bass version schematic and my own sketch of the circuit in question including voltages. All the surrounding components that are pictured check out as in spec on the DMM. In my experience these small red LEDs typically run with around a 2V voltage drop and I tested this one outside of the amp and it checked out as such and lit up normally. I tried adding different values of resistance at different points in the circuit to try and adjust the voltages on either side of the LED hoping that if I could modify it so that the voltage drop across the LED was in the 2V neighborhood it would work as it did in my experiment outside of the amp. But any change in voltage was negligible with the resistors I tried (e.g. 1K, 100K) and the voltage drop on the LED remained the same.
    I need guidance please!
    ..and thanks,
    - B
    0 Not allowed! Not allowed!
  2. #2
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    32,514
    Thumbs Up/Down
    Received: 2,047/7
    Given: 0/0
    Rep Power
    55
    First off, this is a commercial unit, and one presumes it worked at some point. Likely Roland did not ship products with non-functioning power lights. My point is that redesigning the circuit is not the approach, we just need to fix it.
    Is there anything else wrong? I mean the power light is dark, so does that mean it also won't amplify? Or is the LED the ONLY problem?
    LEDs MAKE the 2v (varies with color of LED) by their nature, we don't light them by putting two voltages on the ends that are 2v different. HAven't you got one of the diodes in your drawing backwards? Zeners do not zene in forward bias. They break down predictably in reverse bias. As drawn the current freely flows through the zener.
    So the bass version we see is different, but do you have similar power supplies? In other words do you have roughly 54v main power rails? And they are made from a roughly 38 - 0 - 38 VAC center tapped power transformer? If so, and you want to change something, why not just steal the LED circuit from the bass version? A resistor, a diode, and an LED.
  3. #3
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    Quote Originally Posted by Enzo View Post
    I had a feeling you might be burning the midnight oil :-)
    Point taken about redesigning the circuit, I guess I was just experimenting hoping I could learn something at the same time. I have to admit I don't fully comprehend the relationship between the AC and DC voltages observed and/or the effects of the components in that circuit. We use capacitors to block DC from passing to subsequent gain stages (coupling caps). In my diagram there is 122VAC at the power switch end of the 1nF cap. On the LED side of that cap I measure 55VAC and 85VDC. I would have expected 0VDC. That's just the tip of the iceberg as far as how confusing it is to me. So borrowing from the other diagram makes sense but I'd like to learn the concept of this particular design and why it isn't working and why I'm seeing the voltages that I am.
    Regarding the zener, I jumped to a conclusion based on the appearance of it. In fact there is a symbol drawn on the component side of the PCB showing it is a regular ol' diode. Here's my corrected diagram:
    Edit - Yes, the power light is the only problem.
  4. #4
    Senior Member vintagekiki's Avatar
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Quote Originally Posted by bobloblaws View Post
    Your diagram is incorrect
    - LED diode is not galvanic separated from AC main voltage.
    - If the AC socket turns 180 degrees and no phase coming to the on/off switch, LED diode will not illuminate.
    - When the fuse burns LED diode still lights.
    Isn't it easier to replace in kit R47, D8 and D9.
    Who does not know and knows that he does not know - teach him Confucius)
    Who knows and does not know that he knows - wake him Confucius)
  5. #5
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    Quote Originally Posted by vintagekiki View Post
    There's a chance I may have overlooked something, but I went over the circuit pretty thoroughly. Where would you suggest I look specifically for where you think it is incorrect? Or are you just saying it wasn't designed correctly?
    Do you mean the LED should be isolated via the power transformer as in the bass version schematic? You would think so, but not the case with this amp.
    In what circumstance would the AC socket turn 180 degrees? You mean an wall outlet that was incorrectly wired up?
    Maybe, but if this is the way they did it I'd like to figure out why it is not working given that the LED itself seems fine, for my own education.
  6. #6
    Join Date
    May 2006
    Location
    Posts
    32,514
    Thumbs Up/Down
    Received: 2,047/7
    Given: 0/0
    Rep Power
    55
    The cap is a reactance at AC and passes AC to the circuit. The diodes rectify the AC into DC, though it is unfiltered. LED lighting current need not be filtered, why waste a cap?
    Just idly looking at it, it looks like one or both diodes could be open.
  7. #7
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    All which is incorrect writes in post # 4. Let me repeat.
    There's galvanic connection AC main voltage with chassis.
    What is the problem to replace R47, D8 and D9?
    1)
    LEDs constantly illuminate regardless without position of on/off switch
  8. #8
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    OK, so in my question I was referring to the DC voltage at the on/off switch end of the LED. But do I need to be thinking in terms of electron flow as opposed to "conventional current"? Because my first thought is to question how the voltage measured at that point has been rectified since it has only "seen" one terminal of the first diode (the LED). Further, I can't grok how there could be 85VDC there when a complete half cycle of 120VAC is only 60 volts.
    They appear to be OK on both the diode check and resistance check on my DMM.
  9. #9
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Dear colleague constantly questions, little theory will not bother anyone.
    Why thinking when it's simpler replace R47, D8 and D9?
    May be cold soldered in the LED connection.
    1)
    Question
    Either D8 and D9 are accidentally inverse soldered or one of the terminals (R47, D8, D9) is interrupted.
  10. #10
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    13,005
    Thumbs Up/Down
    Received: 569/3
    Given: 300/0
    Rep Power
    28
    Here is a crop from the Cube 100.
    Cube-100 Pwr S.pdf
    Super duper easy.
    A diode, a resistor & an LED to ground.
  11. #11
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    Quote Originally Posted by Jazz P Bass View Post
    Cube-100 Pwr S.pdf
    Super duper easy.
    Thanks Jazz. I may end up going that route. I didn't want to give up on the existing circuit without a fight though.
    1 Not allowed! Not allowed!
  12. #12
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Please explain difference between these two attachments:
    https://music-electronics-forum.com/attachment.php?attachmentid=56103&d=1575005854
    https://music-electronics-forum.com/attachment.php?attachmentid=56114&d=1575047278
    And what did you learn from fight?
  13. #13
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    My point is I see the situation as a challenge and I wasn't prepared to immediately throw in the towel without figuring out what is going on with the original circuit. I obviously don't have the same knowledge as most on here. I'm trying to learn as much as I can. Enzo suggested borrowing the configuration from the bass cube in post #2 and I acknowledged that possibility in my reply to him.
  14. #14
    Join Date
    Feb 2010
    Location
    Posts
    12,040
    Thumbs Up/Down
    Received: 1,811/24
    Given: 4,652/11
    Rep Power
    23
    Both circuits have AC source, 2 diodes, and 3.9K resistor in series. (cap steps down AC in one circuit, transformer does it in other)
    Diodes are biased reversed in one circuit, but should not matter as long as source is AC, and both diodes in circuit biased same way.
    What does not look right is that your drawn in DC voltages are positive instead of negative, and show the LED diode turned off.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  15. #15
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    Quote Originally Posted by g1 View Post
    Please clarify for me. For the LED to be lit should the voltage be negative on both sides? (in this configuration)
  16. #16
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    In any event I went ahead and tapped off the secondary AC and used the existing components to implement the suggested fix. Working as advertised. Thanks for your help and patience guys!
  17. #17
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Draw how connected LED so we can learn something new too.
  18. #18
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    OK, I just discovered something that should shed some light on this snafu. In my diagram I drew the one end of the 3.9K resistor as grounded based on a continuity check with the DMM. I'm not sure where the ground connection is but it turns out that end of the resistor is in fact already connected to the same leg of the bridge rectifier that I tapped for my AC voltage. So I've put both ends of the resistor back to their original places and left my jumper to ground connected to the cathode of the LED and everything is peachy keen. Why the cathode was connected to the 1nF cap on the circuit board instead of ground as in the other instances I've seen remains a mystery to me.
    Thanks again for all your help with this.
  19. #19
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    There is no 1nF capacitor in the schematic for the LED indicator (see attachments), only R47, D8 and D9 are connected in half seconds PT.
    I have to ask. Are you sure understand schematic?
    R47, D8 and D9 must not come with primary AC voltage of 117 VAC
  20. #20
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    I have to ask, have you been paying attention? Did you look at the diagram I made of the Super Cube 100?
  21. #21
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Yes I have paying attention and your diagram in post # 1 LED_circuit.jpg is incorrect.
    Which is incorrect writes in post #4 and post #7.
    People say who knows understands, who doesn't know he doesn't know.
  22. #22
    Supporting Member
    Join Date
    Jun 2017
    Location
    Ontario, Canada
    Posts
    411
    Thumbs Up/Down
    Received: 34/0
    Given: 43/0
    Rep Power
    3
    I appreciate your willingness to help, VK.
  23. #23
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Thank you!
  24. #24
    Join Date
    Feb 2010
    Location
    Posts
    12,040
    Thumbs Up/Down
    Received: 1,811/24
    Given: 4,652/11
    Rep Power
    23
    So it turned out the resistor was getting it's AC source from the PT secondary like in this schematic?
    And you were missing the ground between the LED cathode and the 1nF ?
    I'm going to guess someone installed 3rd prong ground, clipped the ground side of C31 ("death cap"), so you no longer had the ground for the power light circuit.
    No part of the circuit should have ever connected to the primary, but someone clipped the wrong end of C31 and did not restore the ground to D9.
  25. #25
    Join Date
    May 2006
    Location
    Posts
    32,514
    Thumbs Up/Down
    Received: 2,047/7
    Given: 0/0
    Rep Power
    55
    So none of the parts were ever bad?
  26. #26
    Join Date
    Jul 2006
    Posts
    1,693
    Thumbs Up/Down
    Received: 295/2
    Given: 260/0
    Rep Power
    16
    Road to hell always has been paved with good intention.
Thread Information
Users Browsing this Thread
  1. Roland Super Cube 100 Schematic
    By bobloblaws in forum Schematic Requests
    Last Post: 01-04-2020, 04:16 PM
  2. Help please Roland Cube CH 60 (Cube Chorus) schematic needed
    By Panacha in forum Schematic Requests
    Last Post: 08-19-2018, 03:41 PM
  3. Roland Super Cube-100 Bass
    By MarkusBass in forum Schematic Requests
    Last Post: 11-11-2016, 06:54 PM
  4. roland cube 15 amp
    By d.glover1 in forum Music Electronics
    Last Post: 02-22-2015, 09:49 PM
  5. Roland SCB-100 - SUPER CUBE BASS
    By nanodocl in forum Schematic Requests
    Last Post: 11-12-2014, 02:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
