Results 1 to 17 of 17
Thread: Quick question regard biasing
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Hello,
    I wonder what is happen from a biasing point of view if one triode , say 12ax7, is cathode biased through fixed resistor say 2,2 k, for a certain potential point, say 1.6 V, but I put in the grid a large 10M resistor as grid leak, to serve as convenient load for previous stage ? As know such of big grid resistor create by "leaking" current a voltage potential I wonder if the initial bias fitted by cathode resistor will change, please? Thanks
    Or...if is changed it will be disturbed by operational input voltage condition swing ?
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    Quote Originally Posted by catalin gramada View Post
    Hello,
    A tube needs a negative bias voltage. Bias is grid voltage minus cathode voltage. So if grid voltage is zero and cathode voltage is +1V, bias is -1V.
    A large grid leak resistor develops a negative grid voltage caused by the negative (electrons) grid leak current. This tends to cause more negative total bias, decreasing tube idle current. But as lower tube current means less cathode voltage, actual bias changes much less. In other words, the cathode resistor provides negative DC feedback, which tends to stabilize the idle current.
    Just measure cathode voltage with a 10M grid leak and compare with grounded grid.
    1 Not allowed! Not allowed!
    - Own Opinions Only -
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Thanks, I can measure , but just edited for an additional question,please:
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    Thanks, I can measure , but just edited for an additional question:
    If " operational input voltage condition swing " means an AC signal, average DC cathode voltage (determing the bias point) will not change. To be precise, this only holds for linear operation. Asymmetric plate/output signals generally cause a bias shift independent of biasing method.
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Thank You.
    I.m trying to figure a "better" volume control with better frequency characteristic over a more consistent impedance. A second order in this position also hope to get some tonal benefits. (It is a bass aplication) This is my plan:
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    Thank You.
    What benefits do expect over connecting the grid directly to the vol pot wiper?
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Think freq reponse will be more consistent preserved over volume control range. Does it works ? Thanks
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    I can't think of a reason why the frequency response should improve.
    Connecting the grid to the pot wiper eliminates the second coupling cap and actually gives slightly better bass response.
    What's wrong with the frequency response?
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    I did not expect to improve into tonal way, just to have more consistency over volume pot position. I cannot manage a bypass cap over pot in a way to keep consistent tone from low to loud volume. Trying everything from 100pF to 1nF
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    This is the first pole, the second one will be determined by input capacitance of the valve itself in conjunction with series resistance and input impedance whatever the signal is shunted to the ground...I thought...
    What I tried to do is to preserve the big input impedance of second stage and to present a series capacitor, as second pole in a way to not load suplimentarry the first stage as well.The second grid will "see" a more consistent condition in this way, no matter by volume pot position...if it have any sense...
    It is 10 times diference, should be better 100x, but practical consideration...
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    What I tried to do is to preserve the big input impedance of second stage and to present a series capacitor frequency compensation in a way to not load suplimentarry the first stage as well...if it have any sense...
    Anyway the second coupling cap and grid leak resistor don't improve anything. You can't compensate a low pass filter with a high pass filter having a much lower corner frequency. A bright cap of 100pF to 200pF should be a better solution. I don't understand why it didn't work for you.
    I deleted my earlier post because it was based on a calculation error. What tube do you use?
  12. #12
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Understood. 12AX7 btw.
  13. #13
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    OK, from tube data the gain of your 12AX7 is G=72. From this the input capacitance calculates as 120pF. Real value will probably be closer to 150pF, because of wiring influences.
    Worst case treble attenuation happens at max. source impedance as seen by the grid. This is around the 50% setting of the vol pot, amounting to about 280k.
    Means that at this setting the upper corner frequency will be about 4kHz.
    A treble cap of 150pF should be sufficient to compensate the treble loss at this worst case setting.
    Edit: The gain of 72 above is with bypassed cathode cap. Without cap, gain drops to 40 and input capacitance will be around 100pF. Treble attenuation can be expected to start above 5kHz.
  14. #14
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Thank You Helm.
    Have another newbie question then, as follow:
    From a triode perspective the grid leak it count just as load for previous source ? Otherwise, the valve didn't care if the signal swing at its input into 1k or 1M grid leak resistor as input impedance supposed the source can drive it in any circumstances? (don't talk about charging/discharging timing caused by possible capacitive coupling, as can be fitted for any time constant),please ?
  15. #15
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    Thank You Helm.
    Sorry, not clear what you mean (double language barrier). Maybe you give an example.
  16. #16
    Mar 2008
    832
    Received: 101/0
    Given: 229/0
    12
    Alles klar!Kann night spreche in gutte Deutsch auch. Tut mir leid.
  17. #17
    Supporting Member
    Mar 2018
    Germany
    2,557
    Received: 1,907/1
    Given: 1,104/2
    5
    Maybe this helps:
    For the tube only the voltage between grid and cathode matters, consisting of DC bias and AC signal.
    The grid leak resistance always should be smaller than the internal grid resistance, which is typically very high (>>10M) but strongly drops at large positive signal peaks.
    So I would expect an influence of grid leak value on large signal/distortion behaviour. There may also be a difference at very high frequencies.
  1. Quick quick question re Series resistor power handling
    By emenasche in forum Guitar Amps
    Last Post: 04-01-2017, 09:55 PM
  2. Quick Pot Question
    By Landon in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-18-2010, 08:59 PM
  3. quick smt question
    By CarlZ in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-13-2008, 04:15 AM
  4. quick question about biasing a 5150
    By MitchK in forum Theory & Design
    Last Post: 12-08-2006, 11:23 AM
