Results 1 to 4 of 4
Thread: Marshall JCM900 rebiasing
    Mar 2010
    35
    0
    Hi
    I have this JCM900 Model 4100 which is originally fitted with 5881 tubes. A friend bought 4 new 6l6s and asked me to replace them. After fitting them, when I turn on the amp, there is some low hum from the amp. The bias was at -50V, when I set the bias to minimum (-63V), the hum has reduced very much but it is still there. How do I set the bias. I heard that some resistors value need to be change. If so, which are the resistors and what are the values. Please assist.
    May 2010
    Sioux Falls, SD
    6,459
    Received: 1,308/1
    Given: 1,007/1
    16
    Was the hum there before the tube change? Did the old tubes work- no hum? If one or more of the old tubes was bad, you could have open screen resistor(s) or some other problem. I'd check pin 4 of all the output tube sockets and make sure you have screen voltage at each. If the old tubes worked, you may have gotten a new defective tube or tubes. Sadly, it's not all that uncommon these days.
    As far as setting bias, the proper way would be installing 1 ohm cathode resistors for measurement, using a bias probe, or OT shunt method. You would also be able to tell if a tube is bad or they are horribly mismatched. Just setting the bias voltage doesn't tell you much about what's actually going on.
    2 Not allowed! Not allowed!
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
    Supporting Member
    Staffordshire UK
    3,815
    Received: 549/1
    Given: 482/2
    18
    I think it would be better not to put forward the OT shunt method, as itís needlessly hazardous. Especially so for an inexperienced operative.
    If installing 1 ohm resistor per cathode isnít feasible (just a momentís work with a dremel to create a break in the cathodeís pcb track), then measure the resistances of the OT primary (CT to each plate leg) and then the Vdc at idle across those resistances. The plate current per side is then a simple calculation.
    I think it good practice to remove the phase splitter tube when probing a power tube plate, in order to eliminate the potential of oscillation being induced by the additional coupling provided by the probe cabling, and so disturbing the idle status.
    But really, with a 4 tube power amp, itís far preferable to be able to assess the status of each tube (ie 1 ohm resistor per cathode) rather than be limited to that of each paralleled pair (via OT current assessment).
    May 2010
    Sioux Falls, SD
    6,459
    Received: 1,308/1
    Given: 1,007/1
    16
    I agree with your point of view regarding the shunt method. What I meant was the method you describe measuring the OT resistances. I inadvertently used the wrong terminology. Apologies.
  1. Marshall JCM900 Help
    By marcumh in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2012, 03:49 AM
  2. Marshall jcm900 oscillating
    By pontiacpete in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-08-2012, 06:59 PM
  3. marshall jcm900 mkIII mods?
    By vic in forum Mods & Tweaks
    Last Post: 01-17-2011, 07:32 PM
  4. Rebiasing Original Fender Blues Deluxe
    By TheGrandWazoo in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-23-2010, 01:40 PM
  5. Marshall JCM900 4100
    By titan7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-13-2008, 03:48 AM
