Results 1 to 6 of 6
Thread: Orange TH30 Channel Switching
    Nov 2018
    223
    Received: 29/0
    Given: 5/0
    2
    Hi, I have another post about this in the electronics subforum. I have an orange TH30 that is switching unreliably from the front panel switch only without the footswitch plugged it. I thought it may have been the relay, but if it was, it probably wouldnít be working at all. Just wondering if anyone has any ideas of what it could be. I know a faulty jack could cause something like this. Itís a 3 tab cliff style jack. It says on the schematic that all 3 tabs should be grounded when there isnít anything plugged in, but the middle one doesnít ground at all. Itís probably a very simple fix but itís been kind of confusing. Iím not too familiar with these amps and their common issues. Thanks!
    Hereís a schematic: https://music-electronics-forum.com/...3&d=1521589896
    Feb 2010
    12,037
    Received: 1,800/24
    Given: 4,639/11
    23
    Quote Originally Posted by Steelwitch View Post
    I don't see that anywhere on the schematic you posted?
    The relay or the switch could still be intermittent. Or a shaky solder connection.
    Nov 2018
    223
    Received: 29/0
    Given: 5/0
    2
    Sorry, I misunderstood the schematic diagram. After looking around a bit more thereís only 1.5vDC on the supply. Iím thinking C8 and C9 may be faulty. Iím going to replace them and see if the supply voltage looks closer to whatís stated
    Feb 2010
    12,037
    Received: 1,800/24
    Given: 4,639/11
    23
    I’m thinking C8 and C9 may be faulty.
    Also C7.
    May 2010
    Sioux Falls, SD
    6,459
    Received: 1,308/1
    Given: 1,007/1
    16
    You can measure AC on the rectifier side of C8 and C9 to verify AC is getting to the rectifier without having to shotgun the caps.
    ďYeah, well, you know, thatís just, like, your opinion, man.Ē
    Nov 2018
    223
    Received: 29/0
    Given: 5/0
    2
    Replacing C8 and C9 did it. Supply is back up to 5V. Thanks yíall!
    1 Not allowed! Not allowed!
  1. Orange TH30 switching IC
    By Steelwitch in forum Music Electronics
    Last Post: 11-29-2019, 05:50 PM
  2. Orange TH30 OT replacement
    By wynken in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-12-2018, 11:17 PM
  3. Orange TH30 schematic
    By Steve A. in forum Schematic Requests
    Last Post: 03-21-2018, 08:46 AM
  4. Need Schematic for Orange TH30
    By goldtop5 in forum Schematic Requests
    Last Post: 11-29-2016, 10:04 PM
  5. Orange OR100 channel switching issue
    By Leo_Gnardo in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-01-2014, 02:18 PM
