Page 2 of 2 FirstFirst 12
Results 36 to 42 of 42
Thread: Assistance Using Scope to Troubleshoot
  1. #36
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,313
    Thumbs Up/Down
    Received: 1,164/102
    Given: 162/36
    Rep Power
    12
    Quote Originally Posted by Chuck H View Post
    Just to be clear, this guy knows about amplifier electronics? Not always the case. Confidence and vaguely related credentials aside,.. We are here if it comes up
    Guitar electronics half a volt of electricity Vs Amp Electronics hundreds of volts of Electricity.
    That's like saying I'm a painter I can paint cabinets(and I do at work) but I ain't no Van Gogh....
    nosaj
    0 Not allowed! Not allowed!
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  2. #37
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,802
    Thumbs Up/Down
    Received: 2,661/4
    Given: 3,105/0
    Rep Power
    30
    Quote Originally Posted by nosaj View Post
    nosaj
    That's where I was going with my post. But often a guitarists tech also maintains their amps. That doesn't necessarily mean they KNOW about electronics either. Especially WRT modern amplification. Basic on stage problem troubleshooting, biasing and cleaning contacts is often all this position requires. That's a far cry from knowing what causes instability in an unknown circuit. But I put the caveat of the possibility that the guy could be an amp tech in the question because that also happens. Example...
    It's interesting to me that no one credited or acknowledged my recognition of no 0DC reference at the downstream end of the channel switch. That should be addressed and I'd only trust this 'known guitarists tech' if he/she recognizes it as well. If they don't mention it or correct it I think Perkinsman should return here or find an actual "electronics tech" for advice on matters of amplifier repair and modification.
    JM2C
    "In fact when I run into problems working on electronic circuirts, there are so many times that when I finally track it down, the source of the problem is located between my soldering iron and my seat." SoulFetish
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
  3. #38
    Join Date
    Feb 2010
    Location
    Posts
    12,060
    Thumbs Up/Down
    Received: 1,830/24
    Given: 4,684/11
    Rep Power
    23
    I just assumed they were using a MBB type switch there.
    Seriously though, I did notice your valid statement with regard to the switch. Some of us may get a bit of 'tunnel vision' in terms of fault finding, which is why it's so good to have many eyes looking at problems as we do here.
    1 Not allowed! Not allowed!
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  4. #39
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,802
    Thumbs Up/Down
    Received: 2,661/4
    Given: 3,105/0
    Rep Power
    30
    Quote Originally Posted by g1 View Post
    Ah, Yes. That would make sense too. Like any commercial design I would still have a safety resistor there. But if it's not an immediate problem I suppose it doesn't need fixing.
  5. #40
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,593
    Thumbs Up/Down
    Received: 1,963/1
    Given: 1,119/2
    Rep Power
    5
    Quote Originally Posted by Perkinsman View Post
    The owner dropped by and brought an attenuator & hi wattage speaker so we were able to hear the feedback at low volume. We put the master at mid and the JCM started feeding back at 4 or 5. No feedback on the other channel at any volume. It would also feedback when we raised the tone controls at higher volumes. No feedback on the other channel at any level of the tone controls. None of the tubes emitted microphonic noises. Same Les Paul used on both channels. We're lucky enough to have a high profile guitarist's tech nearby so we decided it's best left to an expert. Thanks for the assistance and especially for the tip on Jack Darr's book.
    Feedback requires gain. The more gain the more likely is (unwanted) oscillation. The "2203/2204" channel can be assumed to have way more gain than the other channel, so no surprise here. Actually I like the 2203 circuit for its (controllable) feedback capabilities. If it's not controllable but rather squeals it's likely due to microphonic PUs.
    2 Not allowed! Not allowed!
  6. #41
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,802
    Thumbs Up/Down
    Received: 2,661/4
    Given: 3,105/0
    Rep Power
    30
    Yep. Like I suggested in post #9. Now we know an attenuator is being used as well so there's a possible reaction from that unit. Though the guitar was a Les Paul, which usually means humbuckers and they cancel external EMF's, but if it has p90's...??? Or it's instability. I think this is still a possibility because Perkinsman described being able to hear the feedback at low volume because the attenuator was being used. So all these possibilities should all be tested for if the described symptoms don't make it obvious to any local observer. In all immodesty I would know which of the three is causing the problem immediately had I been present for the test. I sincerely hope the guy taking charge now is qualified for the same confidence.
    "mic drop"
  7. #42
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,313
    Thumbs Up/Down
    Received: 1,164/102
    Given: 162/36
    Rep Power
    12
    "mic drop"
    It's a shame he had the tools to figure it out , just needed a dummy load. The sig Gen would've ruled out the guitar. Hopefully we will hear the final result of this.
    nosaj
Thread Information
Users Browsing this Thread
  1. Vox V125 Assistance?
    By phydauex in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-09-2019, 01:16 AM
  2. Need a new scope. USB scope used with a laptop ??
    By blindboybenton in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-06-2013, 10:01 PM
  3. Spitfire Assistance Please
    By ncusack in forum Build Your Amp
    Last Post: 10-25-2012, 06:55 PM
  4. PT Thoughts and Assistance
    By defaced in forum Theory & Design
    Last Post: 04-04-2009, 03:40 AM
  5. A hello and an SVT assistance request
    By kent in forum Guitar Amps
    Last Post: 11-03-2008, 03:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
