Attenuator bypass?!?
  • Attenuator bypass?!?
    A strange thing happened to me today with my amp and my attenuator. Usually I use an attenuator at home, and sometimes I like to push up the volume for overdrive. And suddenly, it's like the attenuator bypass him... and don't actuate over the amp... I can't regulate the atteunator volume knob, he goes from no sound to a full sound.
    Anybody can explain what happen?
    The attenuator might have lost a ground connection. But how could we really know without seeing what's inside the attenuator or having a schematic?
    - Own Opinions Only -
      It's a Harley Benton power attenuator. This is the schematic:
      https://blog.brixit.nl/static/image/hbpa/schematic.jpg
      https://blog.brixit.nl/blog/2016/2/h...-and-teardown/
        I would start with checking all ground connections with an Ohmmeter. Should measure below 0.5 Ohm with a calibrated meter.
          The grounds seems okey.
          I measure the resistance of every input:
          4Ohm:
          lpad min: 8.3R
          lpad max: 16.6R
          8Ohm:
          lpad min: 12.3R
          lpad max: 20.6R
          16Ohm:
          lpad min: 16.3R
          lpad max: 24.8R
            I think that I solved. The switched jack from 16Ohm are always open. The attenuator was always at 16R!!!!
              Seems the "L-pad" (actually a simple power pot) is not properly grounded.
                I replaced the switched jack from 16Ohm, and now I have this readings:
                4Ohm:
                lpad min: 4.2R
                lpad max: 5.7R
                8Ohm:
                lpad min: 8.5R
                lpad max: 9.8R
                16Ohm:
                lpad min:16.3R
                lpad max: 24.4R
                  I disassembled the lpad and it's burned...
                  https://ibb.co/rf9GbrP
                  My amp is a Bassman aa864 50W I can use this Attenuator no?
